Question about Intermatic Inc. ST01C Digital In-Wall Timer
Kintex heated throw - Intermatic Inc. ST01C Digital In-Wall Timer
I want to know if my throw is under warranty. I think I probably registered it as a gift, probably two years ago, a Christmas gift. Serial #D105VT07176010612B86112.
Hi Judith
your heated throw has a 5 year warranty! Warranty is covered on this page, specs are on the bottom link.
http://www.sunbeam.ca/en_CA/service-and-support/product-support/product-faqs/bedding/warranty/bedding-warranty-faq.html
Sunbeam Velvet Plush Heated Throw Mushroom Sunbeam Canada TSV8WS R772 26A50
Dec 02, 2015 | Sunbeam Fleece Throw Electric Heated...
To continue from my last Question, to do with HVAC Evaporator/Condenser Cycles, how often should the System go into Heat Standby, Heat Defrost, and Heat Modes? What are Heat Standby and Heat Defrost?
In this type of system (heat pump), the evap and condenser swap functions by means of a reversing valve, according to the mode selected. Evaps throw off cool air, condensers, warm air. In heat mode, the condenser is the indoor coil and it throws off heat from the outside air. Vice versa for the cooling mode. Heat Standby would be whenever the temperature thermistor has reached set point by the user and shuts down the system. Heat defrost is the cycle that reverses refrigerant flow and defrosts the outdoor coil by sending warm refrigerant liquid to that coil. In heat mode, the outdoor coil builds frost and ice on its surface.
Feb 05, 2015 | Refrigerators
Soft heat warming throw quit
The heating element may have failed.
Apr 16, 2014 | Perfect Fit Industries Llc Home
Lennox elite heat pump throws cold air
The unit should give you an error code if something is wrong.
Here's the manual:
http://instalacionesindustriales.com.gt/pdf/Lennox_Minisplit_HE.pdf
Mar 25, 2014 | Lennox 7 Series MS7-HO-18P MS7-HI-18P Heat...
My front heater is throwing very little heat the back is throwing more heat could hear the back blower but not the front
If you cant hear the blower on the front side, its probably gone out. If you can hear the blower and theres cold air coming out the vent, its the flap that switches from hot to cold thats not working
Jan 08, 2014 | 2005 GMC Envoy Xl
I wish to replace or buy a new control for my Automatic Heated Throw. The P.N. number is: 105190-000. Please advise. jaclapp@gmail.com
I'm sorry, but I'm confused! This question references grill SG7621sp but mentions the Heat Throw, the only reference I can find that involves most of your information is a Sunbeam "electric blanket" item. Can you help me narrow down the search parameters?
Jan 10, 2013 | Sunbeam SG7621SP Grill
My heating unit is throwing out black smoke - why?
Check the fan motor, and the filter. A bad motor will smell, too.
Mar 16, 2012 | Heating & Cooling
I RECENTLY INSTALLED 3 LG INVERTER MINI-SPLITS.TWO 12,000'S AND ONE 24000 BTU.THE 12'S SEEM TO WORK GREAT THROWING NEARLY 140' HEAT. THE 24 IS LUCKY TO THROW 90' HEAT AND I DON'T SEEM TO BE ABLE TO CHANGE...
I think you keep in Auto mode. If in Auto mode, you can't change fan speed. Keep in cool/heat mode and then press fan button in remote to select desired speed.
Dec 16, 2010 | LG Heating & Cooling
After fan is on for awhile the motoe feels hot to the touch..Why??
That is because small motors like this are very inefficient.
Almost everything in nature that has inefficiency throws off energy as heat.
The motor is probably throwing off 100 watts of waste heat total, which compares to the heat of a 100 Watt light bulb, so getting hot is not surprising.
Dec 15, 2009 | Jenn-Air JED8230 Electric Cooktop
Intermatic Inc. ST01C Digital In-Wall Timer Logo
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Hippy_dd
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
