Question about Cell Phones
HELP MY PHONE NOT WORKING
JUST FLUSHING AND DISPLAY 3D814011
How can I set a right hand tab
I assume you are talking about Flush Right Tabulation.
To set a flush right tab:
(1) Position the carrier (or cursor) at the point where you want a flush right tab to be set.
(2) Hold down the Tab set/clear key and press the 2 key.
To clear a flush right tab:
(1) Press the Tab/back tab key to move the carrier (or cursor) to the flush right tab position.
(2) Hold down the Code key and press the Tab set/clear key.
To use a flush right tab:
(2) Type the text. Characters will appear on the display as they are typed. Corrections can be made on the display before the text is printed.
(3) Press the Print key. The text is printed aligned with the flush right tab position.
To find out more about your Swintec 7040 typewriter, you can buy a PDF manual for only $10 at:
Swintec Typewriter PDF Operations Manuals 10 emailed
May 15, 2014 | Swintec 7040 Typewriter
How can i reset or flush my phone after putting a password and cant remember it
what type of phone are you using. please provide more details.
May 04, 2013 | Cell Phones
Is there a product you can use to flush your radiator that works. My heater on my 2001 Siverado does not work anymore and last week it was working very well. Thermostat is working at 195deg.
What you need to do is feel the heater hoses that are going into the fire wall.They should both be hot.If they are then the cooling system is working properly.If not then you could back flush the heater core.Preston makes a good cooling flush cleaner kit.If they are both hot then you could have a bad temp control actuator or control module.My guess it is the latter because it just happened all of the sudden not gradually.There is a service bulletin for the control module for these vehicles.The bulletin number is 04-01-39-007.The part numbers are 15126604 for celsius display and 15126603 for control module with out cesius display.Hope this helps.Good luck.
Feb 17, 2010 | 2000 Chevrolet Silverado
Split display, LCD problem?
As you said you have already changed the LCD display.... so now you just need to flash(reinstall the software) your mobile.
Jun 15, 2009 | Nokia N70 Cellular Phone
Weird keypad
Your phone may need a firmware flush. Please take your phone to the dealer so they can flush the firmware and install newer firmware.
Jan 27, 2009 | Nokia 6300 Cellular Phone
Flash is not working:
Hi , try to test the flush bulb by multi tester if reading display okey/if not reading replace flush bulb .
Jan 13, 2008 | Aiptek DV-3500 / DV5 Digital Camera
N7610
pls check it another display
check it display connecter
Oct 10, 2007 | Nokia 7610
Nokia 7610
This might be a hardware as well as software problem. As on hardware part the chip which is interacting with the screen and the processor of the handset get heated up and so ur screen fades too white in 5 min . on the software part may be a virus issue . Kindely get ur handset scanned with a antivirus .concern with some hardware expert also.
Oct 04, 2007 | Nokia 7610
Display Washout after 5 minsutes of Booting
Your phone is shortcircuiting. The wiring is probably loose and it seems as if it messes up during a particular fuunction of the phone.
Sep 18, 2007 | Nokia 7610
Cell Phones Logo
23 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
