Set date and time anyka mmc disk - Computers & Internet
I use spypen 16gb i required anyka usb web camera driver & time.txt for change time dt. for my spy pen
How To Update Time Automatically of Spy Pen Camera
1)
Connect the camera to computer via USB cable
2)
Download GetSysTime at http://diganet.net/downloads.html
3)
Click GetSysTime.exe to update the date and time, the
time of the camera will synchronize with the time of computer after restart of
camera upon reconnecting.
Nov 27, 2010 | Computers & Internet
MMC cannot open the file C:\WINDOWS\system32\dfrg.msc.
It seems that the disk fragmentor component for mmc in your saved item is corrupt. I assume you are running Windows XP.
I suggest to perform the following: Click on START and then RUN, type in MMC and then click OK.
The MMC Console will now start up.
From within the MMC console ... click on FILE and then ADD/REMOVE CONSOLE
In the STANDALONE tab towards the bootkm of the screen ... select ADD
Disk Defragmentor should now appear
Select Disk Defragmentor and then select ADD After the above is complete. Select CLOSE Then select OK
Disk Defragmentor mmc console is now opened.
I suggest to save this to your desktop or anywhere else by selecting FILE and then SAVE/AS
Give it a file name and then click OK
Your disk defragmentot should now be up and running.
Good Luck. :-)
Sep 29, 2010 | Computers & Internet
Mobile restarts several times before opening
Try restoring or re formatting the phone, but first backup all your needed data such as phone book entries etc, for this step or steps erases the phone completely of its contents,
Turn off Phone Remove MMC(memory card) Simulteanously pres (*) (3) AND green KEy(CALL) dont release them then press power on, still do not release the three keys until you see the NOKIA handshake logo startup. Release three keys when you do, Then you will be prompted to set country, date and time settings and you are done.
I would like to suggest to have your MMC scanned for viruses too, to prevent any failures again, if the MMC have a virus on it.
Jul 15, 2010 | Nokia 6630 Cellular Phone
I attach Nikon CoolPix S550 (off) directly to USB port of iMac (OS 10.5.8), then turn camera on. Nikon Transfer (Preferences set to launch when camera is attached) does not launch. No sign appears on...
Some Macintosh computer systems support using a digital camera using SD/MMC card in two modes: 'Digital Camera' mode and 'Disk Drive' mode. At times, when try to use the camera using SD/MMC card in 'Digital Camera', it is not recognized by iPhoto or Image Capture. To solve such behavior, you might need to reformat the digital SD/MMC card and use backup to restore the lost files. But sometimes, you observe certain issues while restoring from backup or the backup is not available. To cope up with such situations, you should use Photo Recovery application to recover the lost files efficiently.
For an instance, consider that you perform following sequence of steps:
  • You connect your digital camera that uses SD/MMC card to a Macintosh computer in 'Disk Drive' mode
  • You switch to 'Digital Camera' mode and observe that the camera is no longer recognized by iPhoto or Image Capture
Similar behavior is also observed if you use FireWire or USB card reader to connect the SD/MMC card to your Macintosh computer and try to switch to 'Digital Camera' mode.
Solution
To prevent such errors from occurring, you should continue using the camera in 'Disk Drive' mode. You can then successfully access it through iPhoto or Image Capture. However, to solve the existing problem of the SD/MMC card, follow these steps:
  • Connect the camera in 'Disk Drive' mode or use FireWaire or USB card reader to access the card.
  • Backup all the files to your system
  • Use your digital camera to reformat the card.
Note: A digital camera using SD/MMC card uses different protocols in different modes so that to communicate with the Macintosh system. But it can only be accessed through Desktop, when connected in 'Disk Drive' mode.
After reformatting the SD/MMC card, sometimes you observe that backup is not valid and couldn't provide the required results. In such situations, you are suggested to use Digital Photo Recovery products to recover them. Photo Recovery utilities are competent tools to scan a logically crashed media using powerful scanning algorithms. Also, they provide interactive user interface that allows easy implementation
Nov 25, 2009 | Cameras
I need anyka usb webcam driver
After googling for quite some time I found one finally and added it to my Windows Live SkyDrive. I've put it in my Public folder for all users to download here
http://cid-b719bca07f035283.skydrive.live.com/self.aspx/.Public/Anyka%7C_PC%7C_Camera%7C_Driver.zip
Aug 13, 2009 | Computers & Internet
Blinking speaker light
Did you try to set the time and date again ? MMC # 55 sets the time and date in a 24 hour format even if you have a 12 hour display set. YY MM DD W HH MM must be set in this format.
W=Dayof week with 1=Monday, HH MM must be in 24 hour clock. Good Luck
Jul 28, 2008 | Samsung Prostar 824 Keyset Telephone
Setting date/time display
First, you have to Enable Customer Programming. - With handset on-hook, dial #06. The display shows [MMC DISABLED]. - Dial the passcode and '1' and then dial #. (If you don't know the password try 1234, 4321, 9999, etc.) At this point, customer programming is open... Next, Setting the date and time. - Dial #55. Display shows [YY MM DD W HH MM]. - Dial new information as follows: YY = Last two digits of the year MM = Month (01-12) DD = Day of the month (01-31) W = Day of the week (1-7; week begins on Monday (1) and ends on Sunday (7)) HH = Hour (use 24 hour clock) MM = Minutes (00-59) - Dial # to set current date and time. The phone returns to normal use.
Oct 30, 2006 | Samsung Prostar 816 Phone
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
