Question about Measuring Tools & Sensors
In the Alfred Hitchcock film "Nortorious", what element must be recovered before Nazis gets hold of it?
Libtards are basically modern nazis without the means to inforce what they belive you should be doing?
After you see white supremacists getting voted into the cabinet, you seriously think that? Lol. Trump is no liberal, my friend. He's a conservative. A Republican. The question should be, "conservatives are basically modern nazis". The "libtards" don't have control over anything now. Jesus Christ lol. Since when have libtards supported white supremacy? I'm surprised so many people are brainwashed.
Jan 04, 2017 | Horoscopes
Why did Walter let Todd die?
Walt didn't care about Todd. He simply took him under his wing after Jesse quit. Walt only ever cared about Jesse and his family. Walt actually went to the compound with the intention of killing Jesse along with the Nazis. After seeing how Todd and the rest of the Neo-Nazis had treated Jesse, and feeling partly responsible for Jesse's capture; decided to save him instead. Given Todd's previously killing an innocent young boy, Andrea, torturing Jesse and forcing him into slave labour is what sealed Todd's fate. So Walt felt Jesse deserved to be the one to kill Todd.
Sep 04, 2016 | Breaking Bad (2008)
Is the movie Dirty Dozen based on a true story?
As far as I know there is no claim the film is anything but fiction and based on a novel as so many films are.
There were a great many agencies operating during the Second World War and quite a number of them operated in secret, from each other and even from the government, carrying on operations and initiatives that would usually be considered completely illegal or even totally unacceptable by normal people. I know of one such organisation, the details of which are still secret, that should England be invaded and occupied, planned to assassinate any puppet government installed by the Nazis.
Knowing such things it doesn't need much imagination to figure there could easily be a grain of truth in the plot of the Dirty Dozen - or perhaps more...
Jan 23, 2016 | Optics
ALFRED IS 22 YEARS OLDER THAN JACK. WHEN JACK IS AS ALFRED NOW HE WILL BE THREE TIMES HIS PRESENT AGE , HOW OLD IS ALFRED NOW?
Jack = x years old
Alfred = x+22 years old
when jack is x+22 he will be = 3 times x
so find x
22 = 3x- x
22 = 2x
11 = x
jack = 11
so Alfred = jack + 22
Alfred = 33
note: if this is your home work its not cool to have someone else do for you.
Aug 04, 2011 | Computers & Internet
The program will not load , error message not enouph memory
Hold the CTRL key down while this software is starting. This process will prompt you to recover the catalog. If you don't see this pop window then try it again as timing this right will ensure you see the window.
If your catalog cannot be recovered then rename the hidden file psa.prf - This file can located under your user profile folder:
Windows 2000 / Windows XP - C:\Documents and Settings\[username]Application Data\Adobe\Photoshop Elements\3.0\Organizer
Vista or Windows 7 - C:\Users\[username]Application Data\Adobe\Photoshop Elements\3.0\Organizer
Jan 28, 2011 | Adobe Photoshop Elements 3.0 plus Premiere...
Canon camera shuts off while filming a movie
Wow!...you get 35 min. of uninterrupted movie on a point-and-shoot camera before it shuts off and you're complaining? No Hollywood director would ever shoot that much without stopping....even Alfred Hitchcock never went that far! After your camera shuts down, can you start it up again and resume another movie session?
Jul 11, 2010 | Canon PowerShot SD950 IS Digital Camera
Computer will not boot to desktop
i) u said that your computer is going to safe mode menu, if it is really goes to safe mode, then try to click the safe mode option and see whether ur able to go onto the screen or desktop
       (or)
   let us even reseting jumper that ur agent or customer rep told, if you can dismantle your computer on your motherboard u will have CMOSbattery(which is slilver , circualar, i think u knowit) , just remove it by screw driver gently and waitfor few 5 minutes and replace and close the tower....... and there is no need of resetting your jumper after doing(removing CMOS battery)
ii) if you are unable to go the desktop by clicking safemode, then there defenitely a problem with your OS or operating sytem
 i would suggest u reload your OS or format ursystem or reload Windows XP or Windows Vista Freshly
 by tapping F11(incase of Vista) or F10(in case of XP) continously from the moment u power on ur system
here we are trying to bring ur system back to your factory settings(getting the system back to day u got ur system)
but there is problem that u will loose all the data that is present on system(risk at ur own will), i.e., what every that is present in My Documents.....
 when you do this recovery(by pressing F11 or F10) you will get an option to peform NDR and DR in order to save datain my documents(NDR: non destructive recovery, DR  : Destructive Recovery...)
select NDR to save data in my documents.... only in case of XP
Thanking you
M. Sridhar
Dec 31, 2008 | HP Media Center m1180n PC Desktop
INK SYSTEM FAILURE Ink system has failed. Unable to copy, receive faxes or print. Refer to printer documentation. error: 0xc19a0013 Press OK This is the error in which I am receiving and I need to...
Try the following reset:
Hold the OK and the Help button at the same time. While holding them down, plug the power in. Continue to hold both buttons until the unit shut off.
After shutting down, release both buttons and power on the printer.
Alternatively follow instructions on this document from HP.
May 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
BenQ DQ60 DVD RW Dual Layer Burner drive won't open
replace the belt of the tray and clean the tray side by side.
Sep 15, 2007 | BenQ DQ60 DVD RW Dual Layer Burner
Moving film by frame
try unistalling the prog and re install it windman
Sep 16, 2005 | ACI Pacific Image Prime Film PF3650 Pro...
Measuring Tools & Sensors Logo
23 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
