Question about Philips Senseo HD-7810 Coffee Maker
Switches off -won't heat water - Philips Senseo HD-7810 Coffee Maker
My Bosch aqua star water heater lights but won't heat my water
Unplug micro switch located on bottom of water heater if it has one
Dec 30, 2012 | Bosch AquaStar Indoor Natural Gas Tankless...
Error code e01
do the following steps: God bless you
To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
POWER SCRUB PLUS = Heater fault
REGULAR WASH = Water filling fault (over or under filling)
RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
If more than one fault occurs, more than one light will be lit.
Jul 21, 2012 | Dishwashers
New battries in Duracraft Programmable Thermostat for A/C...still won
Remove the thermostat and just touch the wires together and make it run until heat wave is over then figure it out. Kinda of a pain but at least it be cool
Aug 07, 2017 | Honeywell Electronic Programmable...
Won't heat the water
Continuity check from the input to the output. If open, then check from the heater element to the out put and then the other side, then the switches and other safety switches. When you find an open component that shouldn't be you have found your problem. You need and ohmmeter or continutiy checker. If don't know what I am talking about get it looked at by someone who does. If you do, then I should have to tell you any of this.
Nov 11, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Water won't heat up in my bosch tassimo coffee maker, what do I do?
I unfortunately got my vivy emesred in water. When I switch it on it stars brewing cold water splashing all over the place and does not stop!
Any idea how I can salvage the machine?
Oct 22, 2011 | Bosch Tassimo TAS4511UC Coffee Maker
Water won't drain
Do the diagnostic test:
SHU 53 MODELS
To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button.
To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show “88′ when REGULAR WASH button is pressed and “8h” when Delay Start button is pressed.
To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4).
0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault
1 = Aqua Sensor (“Sensotronic”) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test)
If water level switch (f1) has failed (opened), display will show fault code “4′ and unit will continually fill and drain where testing won’t be completed. If flow switch (e5) has failed (opened), display will show “0′, water won’t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code “8′ immediately and testing will end shortly after water has started circulating.
The dishwasher not draining is most probably faulty drain pump or drain hose is got bit loose.It has to be checked and confirmed
.You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 27, 2010 | Bosch 24 in. SHU53 Built-in Dishwasher
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Aug 01, 2009 | Bosch SHU5315UC Dishwasher
Blinking "Normal" button
PROBLEM: STOPPED RUNNING, WILL NOT START AND
CLEAN LED BLINKS 7 TIMES, THEN REPEATS
(WATER HEATING FAULT)
Control is programmed to stop
running and not allow any
further cycles if it detects a
water heating problem (no
temperature increase detected
in heated Main Wash on
3 consecutive cycles). Control
blinks the Clean LED 7 times
repeatedly and disables the
Start/Resume key until
cleared.
Running Diagnostics clears the
control and allows it to operate
again. The water heating problem
must be fixed or the control will
stop running again. See potential
causes below.
Heater circuit problem:
■ Open in heater.
■ Open connection or
component in heater circuit.
■ Faulty heater drive circuit on
control.
1. Check operation of heater in
Diagnostics cycle.
2. Unplug dishwasher or disconnect
power.
3. Check resistance of heater and all
components and connections in the
water heating circuit or heat dry
circuit.
Wash pump not pumping water
past the heater efficiently.
See “WASH PUMP WILL NOT
PUMP”.
Door switch not making
contact consistently:
■ Faulty or sloppy door latch
assembly (which can be
aggravated by high door
closure force keeping strike
plate from fully seating).
■ Faulty door switch (high
resistance).
NOTE: Neutral switch on
plastic tub models is only in
series with motor and heater;
other loads are not affected.
1. Unplug dishwasher or disconnect
power.
2. Measure resistance of door
switch contacts while checking
mechanical operation of latch
assembly. Confirm switches not
loose from assembly. Check strike
plate and door closure.
Lack of water to heat. See “WILL NOT FILL OR LOW
WATER”.
PROBLEM: WON’T START AND START/RESUME K
Sep 21, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Philips Senseo HD-7810 Coffee Maker Logo
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
Lisa
Lisa
just-ice
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
