Question about Maytag MAH8700A Front Load Washer
Water will not drain form tub
What to do/how do I fix the problem water not draining
  • 89 Answers
Does it sound like it wants to drain?
if the pump does run. you would have to remove the pump and clean it out. its possible that the impellars on the pump could be broken, meaning you would need a new pump. but usually its change, or small objects jammed in the pump impellar.
Posted on Jun 18, 2009
    Problem Solver:
  • 5 Answers
Try these steps:
1.) Take the washer outside. 2.) Loosen the two screws on the back panel and remove the back panel. The pump sits on the left-side of the opening. There's a black water hose with a metal clamp; 3.) squeeze the metal clamp with your fingers until it's loose enough to slide away from the pump. 4.) Separate the hose from pump and the trapped water will pour out and the door will then open; and 5.) clear any blockage from the drain hose and the pump.
Posted on Jul 10, 2009
How do I fix water not staying in the wash tub of Twin tub, LG WP 750R?
If your drain is not high enough the water will siphon out while filling. Check your owner's manual for correct height, usually about 39 inches from ground
Jun 20, 2014 | LG Washing Machines
Water entering twist mechanism which closes K-7160 tub drain and dripping on outside of Kohler cast iron tub into basement below. Is the solution to tighten gasket on outside of tub or fix water backsplash...
If the water is entering through the overflow on the twist mech. then the gasket should be tightened and or adjusted. If possible feel around on the top of that fitting from the back side to rule out water leaking from other source, such as backsplash or faucet from escutcheons. It sounds like you have a pretty good idea of how to fix it. I hope this helps.
May 20, 2010 | Kohler CLEARFLO BATH DRAIN K-7160-TF-BV
My water is draining out of my machine as it is filling, Why?
This is a condition known as syphoning. Your drain hose on the washer needs to go up before it connectes to the house drain. It needs to rise as high as the washing machine top then hook over the drain pipe. If the drain hose is pushed too far into the drain pipe this can also cause syphoning.
Here are some tips to help describe this better.
Is the drain hose extending more than 8" (20.3 cm) into the drainpipe?
The drain hose may be too far down inside the drainpipe (standpipe) or laundry tub. Drained water can siphon back into the washer if the drain hose extends too far. Make sure that the drain hose does not extend more than 8" (20.3 cm) into the drainpipe or laundry tub. Using the U-shape drain hose form (as described in the Installation Instructions), will provide the correct length of drain hose in the drainpipe or laundry tub.
Drain hose form
Is the drain hose taped onto the drainpipe? Is top of the drainpipe covered in tape?
Do not seal the drain hose into the drainpipe with tape. The drain hose should be loose, yet secure. There must be a gap between the drain hose and the drainpipe to allow air to flow. The air gap will break the suction. This will keep water from being continuously sucked out of the machine (siphoning) as it fills.
Is the drainpipe (standpipe) less than the minimum height of 39" (99 cm)?
Make sure that the top of the drain is at least 39" (99 cm) high (as measured from the floor.) If the drain is below 39" (99 cm), the water will start to flow out of the machine due to gravity. The flow of water can create suction (siphon) and the water will continue to drain out of the washer.
Apr 19, 2010 | GE Washing Machines
I have to drain my washing machine through a front hole drain opening in the bottom corner of machine. Water comes out, it has been left in machine. I drain my machine every six loads. WHY did Bosch design...
you have a blockage some where in the drain hose.most likely in the hose the comes form the bottom of the tub to the pump.you attach a wet dry shop vac to the end of the drain hose and remove the water this way while the vaccum is working look at the hose that comes form the tub to the pump and if it colapses then there is something restricting the water flow.also make sure to check in side the drain pump cover for any thing that is obstructing the pump
Feb 23, 2010 | Bosch Axxis WFL 2060 Front Load Washer
The machine doesn't drain 100% of the water out. You can move the tub and hear the water sloshing around in the machine bottom and the moisture is now starting to form mold on the front seal
All the water does not drain. The front tub has ballance ring with water sealed in it to off set off ballance loads. The sump hose on the pumpwill also hold water. You can clean your pumps clean out trap to make sure the pump is working good. Also a drain hose higher than 6 ft off floor will cause pump not to drain all water. Front loaders all have a mold problem. no air gets in when your done washing because you close the door. If you dont use bleach and hot water washes it makes matters worse. Fabric softner is even worse.
You need to clean your washer with bleach in the front seal by hand some times.
Its the price you pay for saving water.
Nov 17, 2009 | Kenmore HE2 Plus Front Load Washer
I have an Eljer jet bathtub with a smell to the water when we bat
What you smell is algae forming in the pipes. If you have small black particles in the tub when running the jets, it is algae. Fill the tub with hot water, add 2 teaspoons of cascade dish soap and 1/2 cup bleach. run the tub for 15 minutes and drain. fill tub with cold water, run for 15 minutes and drain, tub is now ready to use. repeat as necessary.
Aug 02, 2009 | Home
DRAIN
I take it that you removed the drain trip linkage and stopper through the vent hole .
You must now run a small hand or small power snake the less than eight feet to open the drain.
You can also plug up the vent,tightly and  try a flat plunger on the tub drain .
Apr 20, 2009 | American Standard 1583.470 Universal...
Bathtub leakes when the drain plug is activated, no leak when not
This usually is caused by a detiorated O ring that compresses to make a watertight seal at the transistion points from them drain shoe and overflow tube to the trap adapter. However it may be the trap adapter as well. Either way the best solution is to access the tub waste from the wall behind the tub drain and replace the necessary parts. Your issue is showing up because the gallons per minute/hour rate that the tub drains is far greater than the tub valve is allowed to fill the tub. This causes a greater volume of water to fill the tub waste and as such the backpessure is greater as the entire volume of water in the trap weir must be evacuated as opposed to when the tub is not plugged and the valve is ran requiring the trap weir to evacuate gradually. Some tub wates are made of metal and may have developed holes in them but they generally form along the pathway the water uses to drain. Unfortunately the only real solution is gain access to the tub wate and replace the defective part. Thanks for using Fix Ya.
Mar 10, 2009 | Kohler Model 7202: Drain For Purist® Baths...
Jets are draining my jaccuzzi tub
Check to see if there is an open valve where the water exits the tub. If there is a valve, shut it and your problem should be solved. good luck
Jan 15, 2009 | Jacuzzi 8730-829 Bath Rotary Drain Kit,...
Maytag MAH8700A Front Load Washer Logo
304 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
