Question about Konica Minolta Office Equipment & Supplies
How to open konica fuser unut copier - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,161 Answers
Depend on the model ######################
Posted on Dec 30, 2015
2 Suggested Answers
SOURCE: konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of the 220V. Immediately the malfunction code (error code) of "C05" appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found the "Trouble Reset Switch" (not shown in the user manual) by opening the upper back panel and pressing the small black button in the lower right hand corner of the middle circuit board (green).
It worked perfectly!7df26b9.tif
Posted on Jan 16, 2009
Help My konica minolita magicolor 2430d is showing media fuser jam
Fuser need to be replaced. HOT Part. or a previous paper is wrapped around the roller in the fuser remove the fuser and see.
Oct 06, 2015 | Konica Office Equipment & Supplies
How to reset the counter for my fuser unit on my Konica Minolta c552 copier
Utility/Counter, Details, Stop 00 Stop 01, (Password if required 92729272) Counters, Life,, New Release, Open the front door (Not the Toner Door), Select Fuser or Transfer Belt, and press the Start Key. Then exit all the way out.
May 26, 2015 | Konica Minolta Office Equipment & Supplies
How to solve code C0510 on konica minolta di552
Open the front door upper left access cover, open press trouble reset if the code comes back do not reset as this deals with fuser can catch on fire will ruin perfectly good day
May 01, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
My Konica 7165 has a problem handling the paper as it moves from paper tray to fuser tray, paper is laying benieth fuser unit tray every time. Is there a sensor that needs tio be cleaned that will tell the...
Open the paper draw and check that the paper orientation matches he operation panel. mite be a fuser unit drive problem. Open the front door and using some paper acturate the door sensor, allowing you to see if the fuser unt is moving when paper get to it. Most copiers have a fuser exit sensor not a pre-enter fuser.
Feb 09, 2010 | Office Equipment & Supplies
How 2 unlock c 0500
on a c350:
1.leave the machine on and open the front door
2. locate a small rectangular hole inside the front dooron the bottom right side corner
3. insert a small object such as a small ball point pen to actuate a switch that resets the error code the screen will indicate door open when the error is reset.this is a fuser error code so if the error keeps coming back the fuser will have to be replaced
Nov 14, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Paper jam
I strongly recommend a service tech. It sounds like you will need a PM kit,fuser claws and a few DFP rollers.
Mar 21, 2009 | Konica Minolta DiALTA Di200 Copier
Konica photocopier
My service info doesn't go back that far either, but this procedure should work to reset the code. However, I would make sure there's no toner build-up on the fuser thermistor or thermostat first, otherwise the code will reappear.
Here's the instructions on clearing the code:
Enter the 25 mode by holding down the 2 and 5 keys while turning on the copier.
Press the P key, then enter 47, then press P again.
Enter 0 and press the Print key.
Turn the machine off/on to exit the 25 mode.
If the code reappears, then theres a problem. If it doesn't, you're good to go!
Nov 11, 2007 | Konica Minolta DiALTA CF910 Copier
Konica minolta EP2010 error code c05
Nov 08, 2007 | Konica Minolta DiALTA Di200 Copier
24 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
