Question about Sharp AR-5316 Advanced Digital Imager Copier
Error f5 in sharp copier ar5316e - Sharp AR-5316 Advanced Digital Imager Copier
sir fixalot
  • 146 Answers
SOURCE: add developer in sharp AR-5316
That model uses a TD cartridge so when you replace the toner the developer is included. The crum chip on the TD cartridge will reset the counters and sets the developer.
Posted on Jan 02, 2008
  • 2072 Answers
SOURCE: sharp copier AR5316
H2 or 2H is related to a fuser under heat or overheat.
Try this first,
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
If this does not clear the problem the fuser will need replaced.
Posted on Feb 21, 2008
  • 74 Answers
SOURCE: error f2 in sharp copier AR5316E
F2 sub code 00 - Toner Sensor problem, ID pattern reading error. You may have to replace the drum unit or have a tech clean the toner sensor
Posted on Mar 31, 2010
rezazadeh
  • 328 Answers
SOURCE: sharp copier simulation program how to do it?
I answered it right now
Posted on May 23, 2010
  • 27 Answers
SOURCE: my copier machine sharp AR5316E
remove the catridge to the machine and then insert it back. if it still display the same information the catridge might be damaged need to be replaced.
Posted on Feb 07, 2011
My copier machine sharp AR5316E shows error message 2U, please what is the solution?
Feb 07, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp Printer AR5316 error message 2U
EEPROM read/write error (serial communication
error)
Dec 02, 2010 | Sharp AR-5316 Advanced Digital Imager...
I can not set up my system with windows seven 7 please send softwere for my syetems . my sestem is sharp AR5316E
Drivers for Sharp AR-5316 are available at Sharp Official Support site. Make selection as under: -
Select
Photocopiers > AR5316E > Windows 7 (32-Bit OR 64-Bit)
Hope it helps! Good Luck!
CreativeTECH
Sep 27, 2010 | Sharp AR-5316 Advanced Digital Imager...
Error f2 in sharp copier AR5316E
Mar 29, 2010 | Sharp AR-5316 Advanced Digital Imager...
AR5316E error code h2
hi in put # + inroput + c + intrupt + 14 + start
Mar 07, 2009 | Sharp AR-5320 Black and White Copier
Ia m using Sharp Ar5316 it showing Error E7 11
E7-11 is 'shading error', probably your optics need a clean, take the glass out and clean the mirrors
Cheers
Nov 29, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
