Question about Ricoh Aficio 2035 Copier
Sc 547 in ricoh aficio 850 or 1105 - Ricoh Aficio 2035 Copier
  • 126 Answers
SOURCE: sc 481 on my ricoh aficio 1224
moz-screenshot.jpgmoz-screenshot-1.jpgThe problem (s) could be; defective main motor, image transfer belt out of position, belt mark blurred or absent.
A ITB belt inspection and/ or repair would be a job for tech.
Or you could just order a new PCU which would fix the problem.
Posted on Jan 08, 2009
  • 990 Answers
SOURCE: error code sc 172 on ricoh aficio 2103
Hello sir; This error code is indicate video process error, may be can be reset, the procedure as follow;
press "clear mode", "107", then press and hold down "clear/stop" key for about 3 sec., until SP menu display, touch "copier sp" on screen, enter 581002 then press 1, then turn power off and back on. see what's happen. good luck !
Posted on Feb 24, 2009
SOURCE: Ricoh Aficio 1232c is flashing SC 792
that appears to be a finisher communication problem. Check the connectors..
Posted on Mar 27, 2009
  • 161 Answers
SOURCE: Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Posted on Jan 16, 2010
joel_baleta
  • 155 Answers
SOURCE: Describe your ricoh aficio 350 functional problens
The applied power supply ac frequency
was detected at over 66Hz or below
45Hz, and the zero cross signals are
not detected within a certain period
within 500 ms after the main power
switch has been turned on. Pls check power supply board or try to use an AVR (autonatic voltage regulator)
Posted on Jan 24, 2010
Help with error code SC547-01
sc 547 mean fixing unit error ,you can reset by simply getting into simulation mode and then switch off an the machine ,getting into the simulation mode is simply by pressing 107 and press and hold c ,
Jun 19, 2013 | Ricoh Aficio 450 Copier
How can I reset a SC 547 error on a Ricoh Aficio SPC 811 DN? I've already replaced the fixing unit.
Hi
Error code sc 547 means "Zero cross signal malfunction". This error appears due to a faulty power supply. This error code may also appear if the input board is defective or the BIC Unit is defective. Turn off the printer and unplug the printer for 30-40 minutes and check if the error still appears. If you see he error still appearing then try and rest it using the following reset method--
To reset the SC code by entering SP5810 and select 1.
Now hold down the photo mode key and the # key at the same time for at least 3 second.
Then turn the machine off and on again.
If the same issue still appears, you'll need to check and replace the Power supply or the Input (IOCC) boardt.
Hope it helps...
Oct 11, 2010 | Ricoh Aficio 150 Copier
Eror sc547
The error sc 547 refers to a "Zero cross signal malfunction".
This means that the applied power supply AC frequency was detected at over 66Hz or below 45Hz, and the zero cross signals are not detected within a certain period within 500 ms after the main power switch has been turned on.
Possible causes are:
- Power supply board defective
- IOCSS defective
- BICU defective
Try to reset the SC code by entering SP5810 and select 1.
Then hold down the photo mode key and the # key at the same time for at least 3 second.
If the same issue still appears, try to replace the Power Supply Unit.
Jul 04, 2010 | Ricoh Aficio MP 2000 Black and White...
Ricoh aficio 1085 sc 547
Thie is a fuser error code enter service mode to reset. -Carl
Jun 09, 2010 | Ricoh Office Equipment & Supplies
Describe your ricoh aficio 350 functional problens Problem sc 547-00
Jan 22, 2010 | Ricoh Aficio 450 Copier
Error code facsimile error red wrench sc547 ricoh aficio 180
there may be a problem with your electric supply(wall outlet) , wrong voltage or power supply bad
Jan 07, 2010 | Ricoh Office Equipment & Supplies
I have a nashuatec D445 and it is indicating an error code CS 547-00 what can i do to solve this problem?Please help.
Press 'Function Clear', 1, 0, 7, then press and hold 'Clear/Stop' button for 3 secands. Machine displays SP Mode. Now turn MAIN power switch off for 5 seconds. Turn MAIN power switch back on. This should reset SC 547 code. (Main power switch is located on the left side of the copier)
Dec 15, 2009 | Ricoh Aficio 450 Copier
Error code, SC 547 on a Ricoh Aficio 1075
have you tried sc reset through the service mode and then turn off .. you can get to this by pressing yellow clear button then 107 then hold down the cancel stop button..wait for the screen to change then go to mode 5 and you need to arrow down to sp 5 810 sc reset execute turn off the copier and try turning on to see if it clears.. if not the ac board maybe defective caused by a power surge or static down the line..
Aug 05, 2009 | Office Equipment & Supplies
Code SC 547 00
SC 547 is a fuser problem. Press clear modes, 1, 0, 7, and press and hold clear/stop/ Enter copy sp. Select 5 for mode. exit all of the way out, and recycle the power. If something in the fuser is bad, it will do it again. If it comes to ready, then the thermister is probably dirty. As for the door, make sure all are closed tight, including the lower right door.
Mar 28, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 2035 Copier Logo
32 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
