Question about Ryobi Garden
Ryobi chainsaw sprocket 4500
4500 drive sprochet
  • 149 Answers
SOURCE: Chain does n't rotate
Is the chain brake "on"?, can you pull the chain around the bar?
Is the drive sprocket teeth worn all the way through.
Does the engine high rev or is it loaded when you throtle up?
Posted on Feb 01, 2009
  • 5 Answers
SOURCE: Where can i purchase sprocket for mastercraft
the new company is Troy-bilt but i found the part in a Mcculloch dealer
part # MC-6228-120104P
Posted on Jun 29, 2009
  • 61 Answers
SOURCE: homelite chainsaw sprocket and clutch for chain
You can get the parts at your local tool rental store.. They should be able to do the service themselves to if you dont want to do it.. Let me know how you make out..
Posted on Jul 10, 2009
dontbother10
  • 2220 Answers
SOURCE: Hi, I'm looking for a Husqvarna 365 chainsaw sprocket cover
No response to CR.
Posted on Apr 09, 2010
  • 4088 Answers
SOURCE: need to replace clutch & drive sprocket
The threads are left-handed. Remove the spark plug and with the piston high enough to prevent entry into the exhaust/transfer ports, stuff some pull rope into the cylinder head and upper cylinder to block the piston from rising much further. You may need to get a special tool to remove the clutch core assembly--don't use an impact wrench as it will shear the flywheel key. If the clutch won't drive the chain and is full of oil, try washing the clutch drum out with spray carburetor cleaner and let dry. This might save the expense and trouble of replacing it. Hope this helps!
Posted on May 28, 2010
How to remove drive sprochet nut
Hello Rndrosse, You need to purchase a tool called a piston stop. You remove the spark plug and replace it with the piston stop. The piston makes contact with the piston stop so you can remove and reinstall the drive sprocket nut.
Oct 31, 2015 | Remington Garden
Can't find replacement sprocket/slip ring/washer for the newer 40volt brushless chainsaw model RY40511. Ryobi website sends to ereplacementparts.com, they don't have model in their inv
See if John Deere has a similar product. Ryobi & John Deere were together a while back and they carry more parts than the private label brand for identical items. If not your out of luck because it was probably mass produced in China for a limited time.
Nov 20, 2014 | Ryobi Garden
Sprocket removal on ryobi cs4046 chainsaw
takes a special tool and is left handed threads
Oct 20, 2012 | Ryobi Garden
My Ryobi 40cc chainsaw saw runs strong, but the chain binds and will not turn. The safety break is not engaged and the chain is not tighten to tight. I think it maybe the sprocket but it does not look...
If your chain has recently jumped off the bar while running, your chain may have "burs" on the drive links (part of the chain that rides in the bar groove). These burs will make the chain rub the inside of the rails and thus bind the chain in the groove. You can file these off with a flat file if there aren't very many, but you may need to just replace the chain. You can find files, bars, chains & sprockets for your saw at PartsBuggy.com.
Jan 18, 2011 | Ryobi Factory Reconditioned 18" 40cc...
Start procedure for chainsaw ncr 4550
The header says that this is an electric saw which doesn't have a start procedure--just push the button and it runs. Electrics also don't have a clutch because the motor doesn't need to continue running when not cutting like a fueled engine does. Most electrics, however, have a safety device that uncouples the chain drive sprocket from the drive shaft to protect the gearbox. Remove the bar and chain, then look for a broken/disconnected drive link or spring connected with the sprocket. If the shaft itself does not turn, then there is likely problems in the gearbox. Hope this helps!
Jun 03, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Have The split cylinders in the Ryobi RY10532 40cc chainsaws caused grinding problems?
check chain sprocket take a rag over chain and pull it around should be smooth rolling also check nose of bar there are rollers check them out lota sawdust can build up behind clutch/sprocket
Apr 08, 2010 | Ryobi Factory Reconditioned 18" 40cc...
Price and availability of gear for ryobi chainsaw CS214 gear that drives the chain
The drive sprocket is not expensive, but finding one is hard, The part runs about twelve dollars but its made in china and there are not very many dealers. TRy to contact them on line, Thats probably your best bet
Nov 25, 2009 | Garden
My ryobi chainsaw rcs 2040 keeps stopping but motor is still running, chain not moving!
RYOBI----- with the motor running at high revs the chain stops indicates that the sprocket behind the centrifugal clutch is worn out or the centrifugal clutch itself ,or the clutch shoes are worn out the way to tell is to remove the bar and chain and have alook where the chain was conected to the saw, i think you will see the sprocket is buggered and as that is attatched to the clutch drum that will have to be replaced along with clutch springs and shoes, i think you have been running the chain a bit too loose or not running it at realy high revs ,which is what they are designed to do ,cme back to me if you feel the need
Sep 21, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
My problem is how to remove the petrol chain saw drive sprocket from the drive shaft
There are a couple different ways. They make a special plug that goes into the cylinder to stop the rotation so you can loosen the sprocket or I have used an impact wrench to remove the nut. If you give me the brand and model I will look and see what I can do more to help you
Feb 26, 2009 | Ryobi Garden
Jan 31, 2009 | Ryobi Garden
Garden Logo
14 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
