Question about Watts Onan Portable Generator - 4000 , Model# 5500
I am need of a starter for a Honda RV generator EV 4010. Where is the starter located on the EV 4010? What do I need to remove on the unit to get at the starter?
  • 76 Answers
ELECTRIC START WILL BE MOUNTED BETWEEN THE POWER UNIT AND THE GAS MOTOR IF YOU TAKE THE OUTER COVERS OFF YOU SHOULD BE ABLE TO SEE IT IT WILL LOOK LIKE A MINI CAR STARTER IF YOU NEED MORE HELP I MAY BE ABLE TO GET SCHEMATICS FOR YOU BUT I WOULD NEED MOTOR INFO MODEL BRAND SERIAL #S AND FROM THE POWER UNIT ALSO
Posted on Jun 24, 2009
  • alex MACHELL Jun 26, 2009
    how goes your problem do we need to find the diagram
How many watts are needed to start the aircon unit
The minimum wattage needed to start a air-conditioning unit is usually 3000 watts but there can't be anything else at all using power at the time. If this is on an RV there are components such as the refrigerator, water heater, power inverter and house battery charger that will automatically start when the RV is connected to the generator. These may need to be manually shut off sometimes at the main power box.
Oct 23, 2016 | Honda Electrical Supplies
How do i remove the starter on a Honda ES6500 generator
Remove ground wire from battery post. Make sure unit is off too. Remove start wire and cable from starter and both bolts. Reinstall in reverse order.
Feb 11, 2014 | Honda Electrical Supplies
Took my ev6010 generator out and put it back in but hooked up the starter motor to the ground not to the positive and now it wont start. I also changed the oil and coolant.
On the ev6010 Honda generator the posive starter wire is black and was accidently hooked up to the chassis ground wire. Then the start button was pushed and nothing happened. I corrected the wire hookup to the positive side but will not start still
Aug 28, 2013 | Honda Ev4010 Ev6010 Rv Generator Inverter...
Onan 7000 watt generator rv starter problems
Can you be more specific than just starter problems?
Jan 17, 2013 | Onan Marquis RV Generator 7000 Watts Gas
Onan 5500 RV generator starting issue
Sound like a dead battery, or poor battery volatge getting to the unit. The clicking is fuel pump and or solenoid trying to pull in.
Sep 12, 2012 | Onan Cummins 5.5 HGJAB-901 RV QG 5500...
Honda rv generator.model#ev-6010/sn-ecb-1020622 when i hit the start button it will run but when i release button it dies the control board burnt up so i replaced it but still have same problem,the pilot...
one thing to try is if you can get into where the brushes are, remove them and take some emery cloth and put on the slip rings that the brushes ride on, they could be dirty with carbon and causeing it not to create power. that is a simple and cheapway of checking it.
Mar 02, 2011 | Honda Electrical Supplies
Honda EV 6010 generator, no pilot light. I am in need of the ohm resistance on the rotor and stator assy. Any help would be great.
Check for burnt stator, if that ok dismantle the generator end, remove the rotor and fully clean the rotor rings.
Mar 01, 2011 | Honda Electrical Supplies
If i am in the process of buying a generator to run 2 carrier RV rooftop ac units how big should the generator be?
You need to find out the maxamps of the rooftops which is located on each unit, then you will need to find out if these are 1phase, 2phase or 3phase units.
That information is also located on the unit and usually is marked 1P or 2P or 3P. If its 3Phase you
would need to talk to a electrical contractor or the
manufactuer of the generator you wish to purchace.
More in for is needed on the phase of the unit and amps that it draws
Feb 12, 2010 | Dometic Rooftop RV Air Conditioner
RV Onan Emerald 1 Generator
Check all the ground wires and make sure their not broken or loose. If the wires are good next check the neg. Wire to the coil. Too check the swiitch make sure you have continuity too all the post when the switch in the on position, this requires removing the switch.
Aug 09, 2009 | Watts Onan Portable Generator - 4000 ,...
I have a 247 03 Springdale RV trailer. I want a
Depends on wattage demand of ac unit. VXA=W 110x20amps=2,0200 Watts. A 2,00 watt generator is too small. Best go for a 3,kw genset. A 5 kw will leave you room to run appliances and the ac simultaneously., otherwise you will need to watch your margin usage. I think 4.5 kw gensets are also available. Happy trails.
Jul 25, 2009 | Heating & Cooling
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
271 people viewed this question
Top Watts Electrical Supplies Experts
rlev_7
Level 1 Expert
Steve
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
