Question about Cuisinart TOB-175 1500 Watts Toaster Oven with Convection Cooking
Faceplate Plastic faceplate that has controls melted. Does anyone sell a replacement faceplate
Why wont myoven stay off? I have to unplug it everytime because it turns itself back on and goes to the stay on setting?
The problem should be a melted wire of a melted control., either of which allows the electricity to flow constantly.
To prevent a fire, please stop using this appliance.
Mar 05, 2018 | Toaster Ovens
Not heating, but light works? How do I fix this problem?
Your oven is obviously getting power if the light is on. If your heating elements are not getting hot you may have had a switch go bad, a wire come off it's terminal, or possibly a fuse that blew if your unit has one. There is really no way to know exactly where the problem is without taking the unit apart and visually inspecting it. If all the connections and switches look good, some electrical diagnosing is needed to see where the problem is. If you find any wires or switches that have any melted or burned plastic, you will need to repair the connection or replace the switch. If there is no obvious problem, you should have it looked at by a technician who can properly diagnose the unit.
Apr 21, 2014 | Euro-Pro TO160L 1380 Watts Toaster Oven...
Fan motor quit. I need a replacement fan & motor unit. Where may I purchase this?
My Euro-pro to241r toaster-oven may have some electrical problems internally. I have owned it for over a year and a half and am now smelling something like burnt plastic or rubber coming from the vents on the right side near the control knobs. I am concerned it may cause an electrical fire. Has anyone else had this problem? I will take it to Wal-Mart where I bought it to see what they say.
My friend tried to look at it but said you need star shaped screw driver heads to take it apart. Look for an online manual to see if you can find information about a fan, but it may not be easy to get to with basic tools.
Did you try looking at there website www.Euro-pro.com which is posted by the model number?
Radioshack may be a possibility.
Good luck, Tom
Jan 17, 2013 | Euro-Pro 0.7 Cu. Ft. Convection Toaster...
Does anyone need the glass front door and handle for ov 300 maxim oven?
Yes, I would like to buy the door if you are still selling it.
Oct 02, 2011 | Toaster Ovens
Light turns on, but no heating.
Pull apart again. you will see leads insulated with cloth-like insulation. feel for a bulge or two - usually a fuse is hidden in one of those insulations. Find it test it for continuity. If flown, cut it out, replace or just short out that connection.
Jul 21, 2009 | Krups 296 ProChef Ultra 1500 Watts Toaster...
''start'' toast button no longer works on my kenmore toaster oven
Salton Model KTES8 toaster oven disassembly and repair
DISASSEMBLY
Remove two rear feet, each held by one screw.
Remove 8 screws holding back on.
Twist AC line cord grommet 90 degrees and slide off back.
Remove one screw on inside 2-1/4" from top on control side next to bell
(hard to see - hidden by wire insulation).
Remove 4 screws from bottom of wraparound case.
Push up case about 1/4" at the front to disengage locking tabs, then
gently slide back and spread sides of case, lift wraparound lip over the edge
it screws into, and then work the case towards the back until it easily
slides off.
Remove 3 knobs from right hand control panel (use flat blade of dinner
knife to gently pry on one side, then the other).
Remove screws that were hidden by knobs.
Remove two screws holding plastic control panel.
Remove 4 long screws and spacers holding circuit boards to plastic control
panel.
Remove plastic control panel.
Move circuit boards forward so they can be accessed. (be careful that after
disengaging the temperature control shaft from the circuit board that you
do not twist either the temperature control shaft or the knob shaft - they
will be reassembled by putting the shaft back into the slot.)
REPAIR
ZD1 Zener diode shorted - replace with 1N4742A (12V, 1W, NTE 142A, $0.99)
REASSEMBLY
Reverse ASSEMBLY instructions
Mar 21, 2009 | Kenmore KTES8 Toaster Oven with Convection...
The timer controler is toasted.
WELL I FOUND THEM BUT . your timer and over where made in china . the people that made the oven sells no parts the timer people will sell timers but the order min $1000.00 per order . there where no part orders in there history , so what i get from that is there are NO timers sold for parts on the globe ....
Mar 16, 2009 | Toaster Ovens
OSTER TOASTER OVEN --- TIMER TWIST KNOB BROKE
you can get on amazon for sure. take a look here Thanksgiving essentials from the Oster brand. p.s. take a look on seller reviews. I hope this was helpful. cheers
Jan 19, 2009 | Oster 6232 / 6233 1500 Watts Toaster Oven...
Cuisinart TOB-175 1500 Watts Toaster Oven with Convection Cooking Logo
Top Cuisinart Toaster Ovens Experts
D. E. Hev
Lawrence Oravetz
J.D. Browning
J.D. Browning
Are you a Cuisinart Toaster Oven Expert? Answer questions, earn points and help others
