Question about KitchenAid Refrigerators
Icemake not working in kitchen aid refrigerator
fridgetech
  • 473 Answers
SOURCE: icemaker not making ice
First thing to check is to see if the optics are working properly. This is the red flashing light on right hand side of freezer wall. Close the flipper door, be sure not to block the beam, and the light should go to solid red. If it does then the optics are ok. If it continues to blink then that is your problem. If optics check ok then pull ice maker out and remove the white plastic cover. It just pulls off. Look at the center of the gear wheel and see if one of the plastic tabs is either broken or if they are sort of twisted and touching eachother. If any of these things with the gear have happened then that module will need to be replaced along with the ice maker thermostat. If your not sure how to replace these parts then just replace the whole ice maker. That is much easier and not much more costly.
After changing the parts or the ice maker out follow these steps to start the ice maker thru a cycle. 1. Remove the ice maker from the cradle but leave the harness connected. Remove the front cover from the module. Unplug the refrigerator. Get a small jumper wire with bare ends and jump T and H on the module, leave the jumper in and set the ice maker on the shelf. Close the door. Now plug the refer back in and wait 30 seconds. Open the door and the ice-maker should be cycling. Remove the jumper, put the module cover back on and set it back in the cradle. The fill should take place when the ejector blades reach the 12:00 position. Follow these steps exactly in order
Posted on Nov 10, 2007
SOURCE: kitchen aid built in refrigerator
compressor doesn't run and there is no cool air came out
Posted on Jul 05, 2008
Sea Breeze
  • 4654 Answers
SOURCE: Kitchen Aid Refer: KSSC42FMS01: The freezer, doesn't go below 32
How long have you had this refrigerator and is this the first time this has happened? Your refrigerator has a control board and I believe the board is causing the refrigerator not to defrost every 8 hours. Let me know these questions and I will help you resolve this. Thanks, Sea Breeze
Posted on Mar 19, 2009
  • 100 Answers
SOURCE: Kitchen Aid refrigerator KSRS251 - not
Sir Good Afternoon..
the problem of your refrigerator is lack of Freun gas
Bring it for Refrigerators Specialist because they are the to put that Freun gas..thanks
Posted on Mar 29, 2010
  • 66 Answers
SOURCE: The icemaker in my ksrs251 quit making ice any
Probaly a fault on water pump.
Posted on Apr 18, 2010
Water dripping under our kitchen aid supra refrigerator
Does it have an icemaker? Was the water line plastic tubing or copper? If plastic, it could have been dried out and cracked by the heat from the motor.
Feb 13, 2012 | KitchenAid KSRD25FK Side by Side...
Water leaking under kitchen aide refrigerator
Could be condensate from the refridgeration unit or the icemaker water connection if the refridgerator has one
Oct 23, 2011 | KitchenAid Superba Architect KSCS25INSS...
I turned my water off when we left town for a month. After turning my water back on the ice maker has stopped working. Our refrigerator is a Kitchen-aid superba model and is approximately 4 - 5 years...
The issue is likely that the icemaker fill tube is frozen due to poor water pressure. You can use a turkey baster to thaw this tube which fills the icemaker. Make sure you use plenty of hot water because they often freeze back several inches!
Sep 11, 2010 | KitchenAid KSCS25FKSS Side by Side...
It appears that no water is getting to the ice maker in my kitchen aid superba side by side refrigerator. I know it is not a frozen water line because I still get filtered water through the door. Any...
selenoid valve to the icemaker can be malfunctioned.they can be found at the back side.
Generally icemaker water line is seperate then the water dispencer so it is possible that it is frozen.
Jun 30, 2009 | Refrigerators
Icemaker not working
I adjusted the temperature control for the freezer form 0 to -1 and it started right up later I changed it back and it is still working so I suspect I have an electrical problem somewhere
Apr 14, 2009 | Refrigerators
Ice maker in my Kitchen Aid side by side is not getting water
there is only 2 things that would cause this. either the icemaker is bad and not calling for water or the fill valve that allows the water to come into the icemaker is bad. how old is the fridge ? also check the ice maker and make sure it has not accidently been cut off inside. if this is the old type theres a bar that raises and lowers. make sure the bar is down. in the up position this would turn your icemaker off
Mar 31, 2009 | KitchenAid (KSRD22FKST) Side by Side...
No ice production
Chances are the fill valve at the bottom back of the refrigerator is clogged or failed. This valve opens to allow water to fill into the icemaker.
It could also be that the fill switch in the icemaker has failed, or depending on type of icemaker, the ice level bar is flipped up, or the mold heater sensor has failed.
Please provide the refrigerator P/N for more information.
Jan 15, 2009 | KitchenAid Refrigerators
Kitchen Aid side-by-side (don't know #, but think it's Architect), ice maker not working, water fine. I can't find any solutions on troubleshooting pages. HELP!!!!
i bet the module on the icemaker is bad ,,,, if the icemaker set where you can pull off the cover and look at the gear and see if the center pin is broken or twisted then the module is bad and if you contact me i will check on the part for you ,,, if its not then you have a bad valve that supplys water to the icemaker ,,, your frig has a double valve so water in door can work but not icemaker / larry
Dec 08, 2008 | Refrigerators
Refrigerators Logo
60 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
