I got a hotpoint wshmachine aqarias and havent got no manuala to show me about the belt or how to remove the vack safly
Model CX-NMT720 replace tape drive belt/belts
If the model does not appear in the PRB Pdf file then you will need to measure and subtract 5% and order those from a supplier. The service manual will not tell you how to put them in it just shows location. You need a speed test tape and frequency counter to set the speed anyway- best done by a Technician.
Nov 30, 2014 | Audio Players & Recorders
Hotpoint TVF760 Aquarius + change belt
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. 9 rib stretch tumble dryer drive belt Contitech 144001958 9PHE 1860 How...
Aug 06, 2013 | Dryers
How to replace drum belt
Nov 04, 2012 | Hotpoint TVF770 Tumble Dryer
Need to replace belt on vtd20g hotpoint tumble dryer
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts How to Repair Home Appliances
May 10, 2012 | Dryers
How to change belt on Hotpoint CTD00P Tumble dryer
There should be a belt tenstioner and small pulley that is spring loaded if there is not a belt on it the pulley is in the bottom of the dryer.You have to place the tenstioner back in a slot or holder and then the pulley will keep the belt in place.
Apr 22, 2012 | Hotpoint Dryers
I Need to change the belt on a hotpoint TDC62 dryer, but I cannot see how to remove the front panel
first take off the top then remove the back most tumble dryers dont have a removable front pannel
Nov 27, 2009 | Hotpoint TDC32 Electric Dryer
Kenmore 80 series dryer. The drum will not turn.
You Take the front off.Screws under endcap trim ,flip console back. Remove screws along vack and top slides forward. take bottom panel off and then door and front panel.
eric
Jul 04, 2009 | Kenmore 63942 Dryer
The belts come off, its a hotpoint aquarius wm63.
Remove the complete rear panel of m/c if it is a washer dryer, you will see the drum pulley in the center, and the motor pulley is at the top of the m/c
Put belt round motor pulley first, and feed belt round drum pulley.
If it is a washer on its own, remove the small center cover at rear of washer, and remove top cover also.
Put belt round motor pulley first and carefully feed belt round drum pulley, you will find this easier to do if you unhook the rear retaining spring.
Please leave a fixya rating for my solution.
Thanks.
Feb 12, 2009 | Hotpoint Aquarius WD63 Front Load...
Broken belt on hotpoint vtd65 tumble dryer
turn the macine aroun you wiil see3screws on the top holding the lid on remove these and take the top off there are 3or4screwes on the top in front of machine remove these lay the macine back at45degres and on the bottom of machine you will find 4more screws remove these and the front will come off place new belt over the drum and with a small crow bar linked through the belt and under the drive apply a lot of down presure to get it on to drive this is realy hard and you mey think the belt is to small it is not make sure u align drum in to front door or machine this is very simple then re assemble and away you go approx time45to hours work
Dec 06, 2007 | Dryers
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
