Question about KitchenAid KSF26C4XYY 26.0 cu. ft. Side by Side Refrigerator with 4 Spill Shield Glass Shelves, Humidity-Controlled Crispers, External Ice/Water Dispenser and LED Theatre Lighting: Monochromatic Stainless Steel
Inside led lights of KitchenAid KSF26C4XYY not illuminate
    Problem Solver:
  • 22 Answers
There is a switch (somewhere on the door frame) that has to close to turn the lights on when a door is opened . They are pretty reliable, but if a switch fails due to a mechanical problem, you can sometimes tell by the feel when you operate it manually. If your switch seems OK, then I'd wonder about the power supply for the lights (which I know nothing about).
Posted on Apr 19, 2014
Should I Go For LED High Bay Lighting from LED Light Expert?
Yes, LED High bay lighting is a solid illuminant from the online store LED Light Expert. I installed a few, both at my home and at my factory. It comes with Preinstalled Hook, and the setup was very easy for me. The light can be a perfect replacement for the illuminants that you are using at present. It is very efficient, with 135 Lumens to watts efficiency. It has a nice design and comes with components of premium quality. Although it is smaller in size, do not believe that it is less efficient. It might be compact in size but the lights are amazing in performance.
The lights come with aluminum housing and there is heat sink integrated that make them stay cool even after many hours of operations. The light is DLC and UL rated, and you can be assured of the safety of these illuminants while using them. To buy or check a wide array of amazing products offered by Led Light Expert, check out Amazon.
Apr 16, 2018 | Dryers
Changed water filter red light still on
Check for a reset, or unplug just for a min or two. Then check.
Sep 11, 2015 | KitchenAid KSF26C4Xyy Side by Side...
Heat Dry LED is very dim.
This is going to sound like a lame answer, but please trust me on this...
Don't mess with it. It is either an LED going bad, or a corrosion/resistance problem where it is wired in. It is a _very_ minor thing, and messing with it could cost you an entire computer board; (hundreds of dollars).
Do yourself a big favor and live with it. (really).
Sincerely,
Gregg
May 18, 2015 | Dishwashers
How do you remove the, RL40 SBSW model Samsung fridge cover to replace the bulb?Thank youAdele
There are 2 plastic extrusions that clip in place. Pull sharply forward, or lever the sides gently up and down with a flat screwdriver above the bits that clip in. The bulb unscrews.
Apr 21, 2014 | KitchenAid KSF26C4XYY 26.0 cu. ft. Side by...
Inside lights of KitchenAid KSF26C4XYY not illuminate
I bet your fridge was put into Sabbath Mode.
Sabbath Mode is designed for those whose religious observances
require turning off the lights and dispensers.
In Sabbath Mode, the temperature set points remain unchanged,
but the interior and dispenser lights turn off, all sounds and alarms
are disabled, the dispenser display screen backlight turns off, and
the dispenser levers are disabled
To turn on Sabbath Mode, press and hold LIGHT and
OPTIONS at the same time for 3 seconds. When the feature
turns on, "Sabbath Mode" will appear on the dispenser
display.
To turn off Sabbath Mode, press and hold LIGHT and
OPTIONS at the same time for 3 seconds again.
Apr 15, 2014 | KitchenAid KSF26C4XYY 26.0 cu. ft. Side by...
I have a reebok crosswalk rt 5.0 treadmill. I can calibrate the incline and it goes up and down. however when you press the button to raise the incline the incline number will change but the machine does...
Step 1:
see this details and proceed according. God bless you
The SCR lower board is designed with diagnostic LED lights. The LED's are color coded according to
their specific function. Green indicates a properly operating treadmill; the green lights should always
be ON when power is supplied to the treadmill. Yellow indicates a treadmill function. Red indicates a
treadmill malfunction. Here is a list of each LED and what it signifies:
MOTOR (yellow) - The MOTOR LED illuminates when dc (direct current) voltage is sent to the drive
motor. The LED gets brighter when the dc output is increased.
RLC (yellow) - The RLC (R = Reactance / L = Inductance / C = Capacitance) LED illuminates when
the filtering system is properly working. The filtering system includes the capacitor and filter choke. If
there is a short in either component then the RLC light will not come on.
DN & UP (yellow) - The DN and UP LED lights tell us if the elevation DN and UP relays are
functioning properly. When the LED lights, it tells us that the relay has energized and is sending high
voltage (110vac or 220vac) to the elevation motor.
AC PWR (green) - The AC PWR (Alternating Current Power) illuminates when AC line voltage is
delivered to the treadmill. It then passes through the in-line fuse (110)/s(220) and lights the AC PWR
LED.
+12V (green) - When the proper AC voltage is delivered to the treadmill, passes through the in-line
fuse/s, through the full wave bridge rectifier (changes AC to DC), through the transformer (steps down
Step 2:
This the board LED, who control the DC to +12vdc) then the +12V LED lights.
signal for Main Motor+Elevation Motor. You must see, the LED DN+ UP( both will be Lit) in any position down or Up.
2) The RELAY board is designed with diagnostic LED lights. The LED's are color coded according to
LED.
VDC (green) - The VDC LED will light when it receives DC voltage from the DC power supply.
UPSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper display
board to the elevation UP relay. This low voltage dc is what energizes the coil of the relay.
DNSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper display
board to the elevation DOWN relay. This low voltage dc is what energizes the coil of the relay.
BELTSW (green) - This LED will illuminate when the low voltage dc is delivered from the upper
display board to the belt (motor start) relay. This low voltage dc is what energizes the coil of the relay.
SPD (yellow) - The SPD LED flashes on and off (relative to speed) when the speed sensor is
operating properly.
PWM (yellow) - This LED will light when the upper board is sending a speed signal to the PWM.
Both the PWM LED and BELTSW LED must be lit for belt movement.
Finally this this Relay Board, the Each Led will be Lit, for any Relai control for DN down, or UP for elevation Motor. You must clean contact of the Relay with Special Spray(Radio Schack).
With this you must fix it.
Jan 07, 2013 | Reebok Exercise & Fitness
Funny noise coming from the air filter
probably bad ice maker
http://www.shopjimmy.com/
Sep 06, 2012 | KitchenAid Refrigerators
KitchenAid KSF26C4XYY 26.0 cu. ft. Side by Side Refrigerator with 4 Spill Shield Glass Shelves, Humidity-Controlled Crispers, External Ice/Water Dispenser and LED Theatre Lighting: Monochromatic Stainless Steel Logo
97 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
