Question about Lindhaus Vacuums
Order part Aria Not getting good suction. told to order a new latch to keep top closed
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 100 Answers
Duct tape latch. See if there's suction.
Posted on May 06, 2014
Y bissel revolution won't suck up dirty water I've checked and remover any hair etc from brushs
There must be a seal that isn't closing all the way. Check around the intake tank, and make sure it is seated correctly. If you still don't get suction, you may need to order a new intake tank. Good luck.
Sep 11, 2017 | Vacuums
The clear cylinder is full and I don't know how to remove it. I can't find my manual.
Do you mean how do you change the bag?
If so, there is a latch for the front cover below the on/off switch. Lift the latch and remove the cover. There is a lever at the top left of the compartment near the top of the bag. Push this lever to the left and pull out the cardboard collar on the bag and remove bag. Put in a new one in reverse order. If you don't have the bag in correctly the cover won't close.
Good luck,
Handie Andie
Mar 21, 2011 | Eureka Smartvac 4870 Bagged Upright Vacuum
Suction through hose but not base
mine did the same when new, i checked all as above then i noticed that i could twist the round peice that will unplug) (right behind the carpet-bare floor knob) and then i got suction at the base to be able to vacuum the floors, then i notice that there was a peice of plastic broken off that actually pushed a black latch down when either pushing the handle all the way up or down this lets the round piece i'm talking about swap over from base suction to handle suction! hope this helps and everyone can understand what i'm talking about! you have to look close to see where the 2" by 2" piece of plastic is missing!
Feb 25, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Poor Suction
I recently bought a second hand Dyson DC07. Its suction was poor. I removed all the un-clipable pipe bits and to remove any blockage but it all looked clear. The Final Sponge and hepper filter did have a lot of dust in it and the rotating brush was full of hair but nothing bad.
I eventual gave in to curiosity and removed the three screws in the top or the yellow removable dust collection tube and cyclone bit to see what was in there. The mechanism to release the flap at the bottom of the collection tube does not allow you to remove the lid completely but it does open far enough to get inside. I found the whole top section of the yellow plastic bit blocked by a big plug of compacted dust and a champagne cork. If you are willing to take the risk and have a torx 15 screwdriver handy it that part may be blocked. It did get a bit messy.
If I was going to attempt the same procedure I'd remove the dust collection unit from the vacuum cleaner as I did before, but leave the clear tube attached and the emptying flap firmly closed to reduce the mess from the dust falling out the bottom while cleaning the top part.
Oct 23, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Carpet cleaner will not suction up solution
Check for any cloggs in the hose lines. And make sure the recovery tank is not filled. Close to %95 of carpet cleaners have a shut off float of some sort which will close off the suction to the head of the machine if the water lever gets too high. Also check the shut off float to make sure it is clear of any build up. If the float is clogged, it will keep the suction closed off from the head. If this is the case, clean the float off and it should open the suction path.
Jun 17, 2008 | Hoover Vacuums
Low suction
Replacing the motor cover solved the problem, it must have been warped and was letting suction out thru it.
Jan 03, 2008 | Vacuums
Hoover Agility, No Suction!!!
I had the same problem. Lower the handle to the floor and check the black spiral suction hose at the neck of the machine. The lower hose in my Hoover split. Check and see if yours has done the same thing. If so, the lower suction hose will have to be replaced. Hope this helps.
Oct 04, 2007 | Hoover F6212-900 / F6215-900 SteamVac...
Vacuums Logo
Top Lindhaus Vacuums Experts
JoeVacs
Are you a Lindhaus Vacuum Expert? Answer questions, earn points and help others
