Question about Breville Kitchen Appliances - Others
One side of 4 slice toaster does not work
Right side of toaster is not working
  • 883 Answers
SOURCE: 4 slice toaster
open the unit. look for disconnected wires from sloppy factory
Posted on May 21, 2007
SOURCE: only toasts part of bread
The solution I got from the FixYa team was: "Get a new toaster." Which is how I ended up with 4 new toasters that don't work. I'm glad I didn't PAY for THAT answer.
Posted on Sep 05, 2008
SOURCE: 4-slice egg & muffin toaster
On my fourth one now...love the idea, but the egg poacher keeps burning out.
The 800 number is 1-800-688-1989
Calling them now...this last one only lasted 3 weeks.
Posted on Jul 28, 2009
SOURCE: T-Fal Avante Bagel Tpaster - 4 slice
Energized coil (Magnet) which holds down lever mechanism may be coated and in need of scraping for it to make full contact
Posted on Aug 31, 2009
SOURCE: tefal avanti hi speed 4 slice toaster one side not
When the push down lever hits the bottom it pushes another little lever which makes contact with the positive and negative terminals. over time, these terminals get ever so slightly bent, especially if you start pushing the lever down hard. what you have to do is take the toaster apart, get to the positive and negative terminals and pinch back into shape with some pliers. you should understand once you look at it. Then put back together. if it doesn't work then it's likely a component has gone so, unless you have a multi-meter and a soldering iron I wouldn't suggest doing this.
Oh yeah, unplug it before you do anything.
Posted on Aug 19, 2010
Russell-Hobbs 18140 4 slice compact toaster
See the diagram attached:
You will see the fuse you will problema 1) Ground 2) Live wire touching the chassis 3) Heating elements in short 4) Control Relais in short. 5) Test Diodes,You must test every components.God bless you
May 17, 2012 | Russell Hobbs 18140 4-Slice Compact...
Tefal avanti hi speed 4 slice toaster one side not working, Not staying down Left side right side ok
Jun 03, 2010 | Tefal Avante Deluxe 4 Slice Toaster
Right side stopped working
In the manual:
Check to see if the toaster is plugged in; if it is, unplug the toaster, then plug it back in again.
A tone will sound when the toaster is plugged into a live electrical outlet.
If no tone sounds, check the electrical circuit the toaster is connected to -
is a fuse blown or a circuit-breaker tripped in your home?
At least with "unplugging and plug it back again in the electrical outlet" the right side of our toaster works again. The tone that should sound with plugging in didn't work...
Aug 15, 2009 | KitchenAid KPTT890 Pro Line 4-Slice...
One side not working
Sounds like the element has failed. Not much you can do as even though they cost more than a 2 slice, parts availability is slim and none.
Jan 28, 2009 | Waring WCT810 4-Slice Toaster
One side will not heat
check your timer board at the back of unit
Nov 27, 2008 | Hobart ET27 4-Slice Toaster
Only toasts part of bread
Sep 04, 2008 | Cuisinart CPT-140 Cool Touch 4-Slice...
4 slice toaster
May 20, 2007 | Cuisinart CPT-140 Cool Touch 4-Slice...
Kitchen Appliances - Others Logo
64 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
