Question about Whirlpool Dehumidifiers
AD50GEUSX User manual
Can i get user instructions for ebac Z850E
This site might be able to help you. For the ebac 2850E manual. I could not find a "Z"850E
Dehumidifier Instruction Manuals User Guides
Nov 16, 2016 | Ebac Dehumidifiers
Need manual to operate
try searching for a manual on Google we have no make to search for you
Jun 27, 2015 | Dehumidifiers
Dehumidifier manual
Hi, consumer. We're sorry to hear about the difficulty with your dehumidfier. Below are links to our Use & Care guides, Parts Diagrams, Troubleshooting information and the Service are of our website. We hope this helps! http://bit.ly/112Lu7q
Aug 24, 2014 | Whirlpool Dehumidifiers
WHy does P2 code come on display for my Westpointe DeHumidifier
I could not find the user manual for your particular model but the manual for the MDF1-30AE model indicates that the P2 code is when the bucket is full or not in the right position.
If you have already emptied the bucket and the error remains I would recommend checking around where the bucket goes as there should be a switch that gets pressed by the bucket when it is in the proper position.
My guess would be that when you are putting the bucket in it is not properly hitting this switch.
Source: User manual for MDF1-30AE
Oct 25, 2012 | Midea MDF1-40AEN3-BA5 Westpointe, 40 PT,...
I got a new Whirlpool dehumidifyer (AD50GEUSX) I put the hose in and the green light on "continuous" and the water will not go through the hose. The machine stops when the bucket is full. Your...
Christianeta, first let me clarify one thing. The FixYa website you posted the problem on, is not the Whirlpool website, nor the Canadian Tire website.. And we don't sell appliances of any type. But, I can help you with your problem.
Despite it being a new unit, there may be some packing material clogging the inner tubing of the the hose connection. Or the hose you're using is to long (over 48") or is kinked or is not sloping down and straight to the floor drain. It relies on gravity to drain, so it will not drain up. When any of the aforementioned happens, water is diverted into the water collection bucket.
To clear any potential packing material or a clog from the inner hose connection tubing, please do the following:
Turn the unit OFF and Unplug it and disconnect the hose.
Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reconnect the hose, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor the hose end for water flow. It may take 10 to 15 minutes for water to start flowing. So, be patient.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
I hope this helped you. Thanks for choosing FixYa.
Aug 24, 2011 | Whirlpool AD50USS Dehumidifier
User instruction
Here is the link for the Owner's Manual off the Ebac website:
http://www.ebacusa.com/technical/Manuals/HD.pdf
Jun 30, 2008 | Ebac HD880 Dehumidifier
Dehumidifiers Logo
153 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike
Terry Schneider
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
