Question about Karcher Garden
Karcher binford 1650 power washer
Remove front panel -- how many screws?
  • 351 Answers
SOURCE: removing front panel on maytag washer
some maytag panel just pull off from the bottom,they are just a tight fit.and some have screws under the hob.
Posted on Mar 21, 2008
aborcass
  • 2651 Answers
SOURCE: how do i remove the front panel
along the front bottom there are( 3) torx 20 screws to remove the lower acess panel
Posted on Oct 14, 2008
SOURCE: removal of front panel of a stack washer and dryer mod
Their are screws between the washer and dryer. Undo those and the screws inside the dryer, next too and below the lint trap.
Posted on Feb 07, 2009
SOURCE: HE4T How to remove the front panel
if you want to take the top panel off,there are 3 screws at the back of the machine,remove then lift
Posted on Feb 25, 2009
jsrock516
  • 5911 Answers
SOURCE: removing front panel from kenmore elite HE-3 front load washer?
If you've removed the screws and the panel sticks, tapping on each side will knock it loose. The panel should drop down, then off. You can also try propping the two front feet of the washer up slightly for better access. A 2x4 works real well. This will allow more room for the panel to drop and gives better access to the screws. The washer is very heavy, so you may need some assistance to lift the front. Either lift from the bottom, or place your hands on the front facing of the cabinet to push the washer back. DO NOT push on the door or control panel.
If you still need assistance, please let me know. I hope this helps you.
Posted on Jul 05, 2009
Where is the spill valve on my 3.550 pressure washer
The only washer that I know that calls their pressure control valve a "spill valve" is Karcher. On their 3500 units it is under a 3/8" cap screw... which may have a marker seal of yellow or red paint on it. Removal is best acheived by removing the cap with a screw driver, note the orientation of a small bushing and remove it and then turning on the washer, with water supply attached. Be careful to hold a small bucket over the hole as the parts will pop out. The spill valve is the most common cause of the pressure not "kicking in". The first symptoms are usually a hesitation to "kick in", progressing to.... not kicking in at all. Unless the spill valve is broken at the stem, it can be "rebuilt" by replacing the orings, cleaning the housing cylinder and re-lubricating with "waterproof" grease.
Oct 21, 2012 | Karcher K2.26 Electric Power Washer
Hi my name is Garry, My Karcher pressure washer is not getting gas and won't start. If I pour gas directly down the carburetor it will start. What could this be I replaced the spark plug and cleaned...
Hi Gary,
Looking at your owners manual I see this is a Honda GCV 160 engine. (owners manual)
http://www.karcherresidential.com/support/downloads/pdfs/usermanuals/9139-1650.pdf
Download this carb check sheet and follow the steps:
http://www.honda-engines-eu.com/en/images/59139.pdf
You have debris in the main orfice jet or tube. These are removed from the threaded area of the float bowl nut with a screwdriver that fits EXACTLY into the brass slots of the orifice and after orifice removal the main fuel tube. IF you damage these during removal i..e you use the wrong screwdriver or damage the thread slots you can end up having to change the carb. Just make sure the screw driver engages the orifice and fuel tube slots fully.
After cleaning the main fuel orifice and fuel tube check fuel flow into he float bowl. It should fill a spray paint can lid in around 10 seconds. If you do not have this kind of fuel flow.. investigate from the float needle back to the fuel tank outlet for restricions.
Thanks for choosing FixYa,
Kelly
Jun 18, 2011 | Karcher 2500 PSI Pressure Washer
I have a Karcher Pressure and cannot get any pressure out of the unit.
karcher K3.97 MB when connected up to tap and switched on pressure poor and motor seems slow cleaned hose end, and filter looks clean
Apr 19, 2011 | Karcher Garden
Can I take off the front panel of a Kenmore/Whirlpool washer to change the bellow?
Removing the boot will require that the front panel, door switch and console be removed.
To remove the front panel first remove the three screws securing the toe panel to the front of the washer and lift the toe panel up slightly pulling it forward.
Next remove the two screws securing the top front panel to the washer. The front panel can now be removed.
Jan 27, 2011 | Kenmore 44102 Front Load Washer
ALLAN KEYS TO FIT
The fixing screws for the front panel and lance are 'torx' screws - Most hardware shops sell the drivers in sets
Apr 09, 2010 | Karcher PSI Electric Pressure Washer
Karcher is spraying water from inside the unit, it actually a k2.97, any ideas please
Hi I have water spraying from air vent/intake on side of my k370 can you help ?
Mar 01, 2010 | Karcher K2.26 Electric Power Washer
Door boot seal on a front load washer how to change
front gasket/door boot.... replacement isn't easy but do-able. first remove three screws that hold front lower panel on and remove panel (where lint filter is). then remove 3 screws that hold on top panel (screws located at rear of top of washer), next remove 3 screws on top front of washer, then remove 4 screws that secure the contol panel. you must remove the washer door at this point, just a few screws and pin hold the door on. now, remove control panel by gently pulling the top away from the washer, it's held by a few plastic snaps. then, remove three screws that secure front panel of washer. now you're ready to remove the old boot/gasket. first look toward lower right side of gasket and pull the spring and remove wire that secures front of gasket. next... at about 3 o'clock on the gasket you'll find a longer screw (about 3 inches) that secures the rear of the gasket. loosen this screw until you can remove the gasket. remove the water inlet and hose from the boot/gasket.... now remove gasket from washer. you're ready to install new boot/gasket. find the small triangle on the new gasket and line this up w/the triangel at the top of wash tub. begin working the gasket onto the lip of tub, make sure to align the triangle and water outlets of the gasket w/the triangle and outlets of the washer tub. once back of gasket is on install the rear wire holder and tighten screw to former tightness. now work front of gasket onto the lip of washer, install spring wire to secure the front. place water inlet and hose into respective holes on the gasket. put front panel back on, put door on, put control panel on, put top on... and wash. like i said, not easy but do-able... i completed it in 1.5 hrs w/no instruction.
Nov 11, 2009 | GE WSXH208A Front Load Washer
Karcher 1650 leaking water from trigger
i believe the spring is the actual trigger spring that pushes the trigger switch back in place and the water leaking out is probably a seal issue
Aug 25, 2009 | Karcher Garden
No high pressure no leaks motor runs off and on when trigger is released
check filter in wand and clean out nozzle hole for starters
May 04, 2009 | Garden
Garden Logo
81 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
