Question about JVC HD-61Z456 Television
Jvc hd61z456 screen "no program" - JVC HD-61Z456 Television
2 Suggested Answers
josetejas
  • 300 Answers
SOURCE: JVC TV: Model # HD61Z456 61 inch - what is the
The bulb part number is: TS-CL110UAA. Take out the bulb and look inside from the front side. Visually inspect any physical damage inside. If it looks clean, lamp might be good
Posted on Jan 26, 2010
I lost remote to 2005 jvc screen tv model #HD61Z456. How can i program channels without remote?
You can get a replacement remote online. I checked this site and they do have a remote for your model. $62
1 800 Remotes Factory original replacement remote controls
Jun 14, 2014 | Televison & Video
Why my jvc television hd61z456 not showing in high definition
What is the signal source that you are watching on your HD61Z456?
The problem you describe usually happens when you aren't using an HD source or have downgraded the signal by the composite input on your TV. (Composite cables only support 480i SD signals.)
You will only see 720p HD content from HD sources, if you use HD compatible inputs. Some OTA channels are also broadcast as only analog signals (usually the -2 and higher sub-channels). If you have cable or satellite, make sure that you have the HD programming and have tuned to the HD version of the channel.
The HDMI and component inputs both support HD signals.
I hope this helps. If you are watching an HD source and the problem persists, I recommend trying new video cables. Next, check if you are getting interference from your devices by using a cable with a Ferrite core. See http://www.monoprice.com/Category?c_id=102&cp_id=10240 for HDMI cables with Ferrite cores. The cores help block interference. If you have very long cable runs, check the behavior with shorter cables between the source and the TV.
(I am assuming you aren't using an SD set top box (VCR, older cable box, low end digital-to-analog converter).)
Dec 19, 2013 | Televison & Video
The power light and lamp light are both blinking and nothing is on the screen and i just replaced the lamp
1,Check the fans ,if the fan is running
2,if the Lamp ballast is work well?
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Sep 19, 2013 | Philips JVC HD-61Z456 HD61Z456 Lamp with...
How to replace a jvc HD61Z456 lamp
check on sides of tv you should see a little square cover, open it remove the lamp and replace it, and put it in. that should fix your problem, if you need more help please feel free to call me at anytime. 602-810-7149
Dec 31, 2010 | JVC HD-61Z456 Television
HOW DO RESET THE HDMI INPUT? JVC , HD61Z456.
Set the remote to "TV" and 'VCR". Press the sleep timer once and "0 Minutes" will show up on the screen. Afterward, press and hold the "Display" and "Video Status" buttons simultaneously and then let go. A menu will show up on the screen, then press "#2" on the key pad. A new menu will show up on the screen, then shut the power off. I was told it could take up to 3 times for this to work. Hope this helps.
Jun 11, 2010 | JVC HD-61Z456 Television
JVC TV: Model # HD61Z456 61 inch - what is the modet number of the bulb that I need to replace. I have no picture on my screen.
Jan 22, 2010 | JVC HD-61Z456 Television
I HAVE A JVC HD61Z456 HOW 2 REMOVE THE LAMP
HELLO Iit can be accessed thru the front of the set. you will have to remove the screws that hold the speaker panel on the front of your set. !!! after removing the speaker panel you will see a small square box with a handle with two screws holding it on, you will have to unscrew those and pull on the handle to remove. hope this helps. "GOOD LUCK"
Aug 09, 2008 | JVC Televison & Video
JVC 61" Rear Projection HD61Z456. Need to take the front screen off.
IF this is in the screen... there has been issues where the entire light engine has to be replaced...
Dec 03, 2007 | JVC HD-61Z786 61" Rear Projection HDTV
JVC HD-61Z456 Television Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
