Question about Samsung Washing Machines
J845 Samsung Front Loading Washing Machine KNOCKING NOISE.
Knocking sound during wash/drum spin. Had it looked at and fixed before - technician said a loose screw??? Now happening again.
jsrock516
  • 5911 Answers
SOURCE: Knocking Whrilpool Duet
The "cleats" inside the wash tub are actually called "fins". If they are loose try tightening them to see if the sound goes away. You should be able to tighten them from inside the wash tub. Some models have mounting screws that are accessible from inside the wash tub. However, if your machine is knocking like you say it is, it could be sign that one or more of the mounting shocks under the wash tub could be bad, the rear tub bearing could be going bad, or the drive pulley could be cracked or warped. Remove the lower kick plate and watch the shocks during the spin cycle. The shocks should vibrate some, but should not be excessive to the point that it causes an unbalanced spin. To check the drive pulley, remove the 3 screws from the washer top in the rear of the machine. The top should slide back some and then lift off. Watch the drive pulley behind the wash tub during the spin to make sure the rotation is smooth and even. Sometimes one of the arms on the pulley can crack or become bent and cause the pulley to wobble. More than likely, though, the drive belt would slip off. I have also seen where the hole in the center of the drive pulley starts to "round out". The hole is not perfectly round and has to flat sides. Sometimes over time the drive shaft will start to slip around the flat sides, causing the pulley to rattle during the spin cycle. If the rear tub bearing is starting to go, the washer will be very noisy during the spin cycle, and you may start to notice some stains on your clothes if the bearing seal has been breached. You can reach inside the wash tub with the unit turned off. With one hand, push up on the wash tub and release. If you can feel the tub moving up and down (even the slightest) this could be a sign that the bearing is worn out. Now this should be a noticeable metal on metal type feel. Not the normal motion of the wash tub moving up and down from the motion of the shocks. The tub bearing is not a cheap (or easy) fix. The entire back section of the rear outer tub shell has to be replaced, because the bearing is molded into the plastic. Check all the easy things first. Let me know if this helps.
Posted on Jun 28, 2007
SOURCE: Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Posted on Feb 17, 2008
SOURCE: machine making a knocking noise during spin cycle
If your machine is making louder than normal noise during spin it could be the failure of the basket. Mine is just under three years old and the basket became looser than normal in the tub. I diassembled the machine...a lot of work...and found the aluminum casting around the shaft and bolted to the basket had rotted away. It looks like it was attacked by the bleach since I had my water checked and its pH is fine. It is likely the root of the smell we have experienced with our clothes when they sit too long in the machine. I spoke with GE and they gladly agreed to replace the parts needed but it is a ton of work to install them. I plan to treat the new part with some zinc chromate if I can get some before the parts arrive. See the picture if it attached correctly.
cid:07d1be63-2d47-407a-89ca-6090b4131d58
Posted on Nov 17, 2009
  • 153 Answers
SOURCE: loud knocking and a loose inside aluminum drum.
One or more of your tub supports is broken. Unfortunately there is no cheap fix but wiil be cheaper than a new machine.
Posted on Mar 05, 2010
miket756
  • 2702 Answers
SOURCE: The drum inside our front loader washing machine
it could be fixed,,, but it sounds like drum bearings worn out thats not going to be cheep,,,or it could be the steady spring/s if one has fell off or just snaped the other is trying to hold all the weight of the drum and it cant do all the work so the drum swings around on the spin cycle battering the inside of the washer,,,this will pull off the water pipes and wiring to other parts like the motor,,,you could wip the top or back off and look inside you will see if the spring has come off,,it will be laying in the bottom
Posted on Jul 03, 2010
Washing machine knocking.
Does the drum wobble quite a bit or does it look normal? If it's wobbling it could be the drum casing knocking the internal structure. Might need a new drum spring if this is the case
Oct 20, 2014 | Washing Machines
Front loading washing machine makes loud knock on spin cycle
Move the empty drum by hands upp and down listen for noise, drumbaring my have been worne. Or is there some loose outside drum?
Feb 08, 2018 | Kenmore Washing Machines
Washing machine making a knocking sound
On this washer the problem is the washer drum rear bearing is worn out, a common problem and often caused by not using the correct detergent for a front loader, detergent is very corrosive, so special types are used in front loads to prevent soap residue corroding the drum bearing. Once the bearing go out then the struts that cushion the drum during the spin quickly follow.
Jan 20, 2012 | Hotpoint WMA44 Front Load Washer
I have a LG front loading direct drive washing machine (WM1812CW) that is 5 years old that is making a loud knocking noise during the spin cycle and is emitting a burnt smell after the cycle ends. ...
It seems you need to have a new sealing rubber fitted. IN THE MEANTIME, if the knocking happens again when the spin starts, stop the machine, let the washing drop to rest, and then start it again, the re-positioning of the fabric inside the drum should even out. Also, do not load with say.. only towels, that way the weight is one sided and will make the drum spin in an uneven way.
Oct 07, 2017 | LG WM1812C Front Load Washer
Washing machine drum out of balance when spinning. have balanced machine and it does not vibrate or jump around. worse when on slow spin, real knocking sound
mine is also making noise during the spin cycle. Just paid $95AUD for the repairman to tell me it needs news bearings and that will be a further $300!
Oct 10, 2009 | Electrolux Washing Machines
Loud noise in final spin
Verify that the inner drum isn't broken. Sopin by hand it should trun smoothly and staight.
Aug 30, 2009 | Frigidaire ATF6000ES Front Load Washer
Knocking in washer
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
good luck.........
Mar 28, 2009 | Maytag Performa PAV3200
Drum noise
Good day.
Maybe there are coins left in the pockets that stucked within the drum during drain process. You can also check the bearing holder of your washing machine for this is also one of the reasons why noises occur during oepration
chris
Mar 11, 2008 | Washing Machines
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
466 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
