Question about Health & Beauty
How to open battery case on a Rascal 320
OPEN THE BATTERY CASE ON A RASCAL 320 TO REPLACE OLD BATTERIES
    Scholar:
  • 61 Answers
Remove the battery pack from the chair and turn it over. Make sure you do this on a flat surface. I usually put a towel or rag under it. Turn it upside down. You will have to use a Phillips screwdriver to remove the 8 screws on the bottom. Once they are all loose you will have to turn the battery case back over. The 8 screws should fall out. This is the reason for the towel so they don't bounce or roll away. At this point you can lift off the top to remove the batteries. Each battery had a sensor taped to the side. You need to remember their placement and then remove. Then you can remove the connectors from the batteries. You just reverse this procedure to install the new batteries.
Posted on Apr 19, 2014
Testimonial: "I discovered this on my own 2 days ago."
gewiz
  • 1263 Answers
SOURCE: electric mobility Rascal 265 LE scooter won't run
Are you sure the batteries are charged ? Is the Battery charger charging ok ? Are the batteries connected ? take off seat and cover to check battery leads, does the key fit in the lock okay ?
Posted on Jun 13, 2009
mcdevito75
  • 1970 Answers
SOURCE: batteries do not charge but charger is working.
mcdevito75 here, You may need new batteries, if they are 2 years old or more.
Posted on Jul 02, 2010
  • 2418 Answers
SOURCE: I HAVE A RASCAL MOBILITY
I do not know of a Scooter graveyard, but I will look for one. I found a site that sells many different types of 24volt battery chargers. If you have a special port on the scooter and you still have your old charger you can cut off the end of the bad charger and wire it onto a new battery charger. Now as with most lead/acid battery's any charger with a built in volt/amp regulator will work.Your old charger spect's are for a 4amp max rating, Any constant 2.5amp or better should recharge your battery's overnight. I am sending you a link to a site called Battery Stuff.com where you can find a 24volt charger for as low as $89.oo, Now I understand this may be a bit out of your range, but a new battery charger for a laptop computer will run about $115.oo. So for a Heavy Duty scooter that is not to bad. Plus it may out last 2 sets of battery's. Now use this site as a reference and maybe you can find one you like local. Hope this helps Fixya up.
Posted on Apr 12, 2011
  • 50 Answers
SOURCE: Could use a workshop manual for Rascal Taxi 4.
HI
YOU CAN GET A USERS MANUAL, NOT A WORKSHOP MANUAL FOR YOUR RASCAL BY CALLING 1-800-MOBILITY OR GO TO ELECTRIC MOBILITY.COM
GOOD LUCK
TIM
Posted on Apr 29, 2011
gopakumarg43
  • 74630 Answers
SOURCE: Rascal 240 scooter Battery charged ,scooter
Hello
There is an overload protection switch in it. It will look like the the protection switch that can be seen under the mixes. The picture of the overload protector is added here. Its press button will only seen outside. Just putsh it once and check. The motor has carbon brushes inside it to get armeture contact. If these burshes are worn out, the motor won't turn, and the scooter won't move. There will be two of them in opposite directions. They are replacable parts. The picture of it is also given here. Check these first. If you need anymore assistance from me, feel free to get me by FixYa.
gopakumarg43.gifgopakumarg43_0.gif\
OK
Posted on Aug 05, 2011
Electric Mobility: Replacement scooter charger
Rob, If need be, possible you can adapt you old chargers connector onto new charger if not the same plug. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
24 Volt 4 0 Amp On Board Battery Charger for Rascal Scooters and Power...
RASCAL 600 600t HANDICAP MOBILITY SCOOTER PRISM 24V BATTERY CHARGER...
Aug 17, 2016 | Electric Health & Beauty
What type of batteries does this model take?.jb.
you need 12v 33ah sealed deep cycle battery most likely it may need two batteries any thing above 33 amp hours would also be ok. A higher Ah the longer the batteries last. This information on the type of battery is from the user manual.
http://www.hardwarexpress.co.uk/rascal-388-mobility-scooter-battery-1949-p.asp
Any battery type store should be able to supply this to you .
Feb 10, 2015 | Electric Mobility Rascal Scooter...
Find vin number on rascal scooter
Depending on with Rascal scooter you have, The 600's number can be under the foot plate which means turning the scooter onto its back supports to have a look. The numbers can be stamped into the metal support for the seat post or even a sticker stuck on the rear frame work of the scooter. But about the batteries the other answer you got is correct.
Feb 07, 2015 | Electric Mobility Rascal Scooter...
Rascal 230 wiring diagram
Check the multi pin connector on tiller and where it connects under the seat between the batteries. Most common problem.
Oct 09, 2014 | Electric Mobility Rascal Scooter...
How to change batteries in a Rascal
The Rascal 600/300, remove the seat, lift off the cover, unplug a battery, replace the old battery with a new one, putting the cable connections on the same way, red is +, black is -. Do the same with the next battery, reconnect the anderson plugs,reinstall the cover and seat and plug in the charger with the key on watch to see the needle raises up toward the full mark, allow to charge fully, overnight is good. keep the bats charged up not allowing them to drop below half way for the first 20 charges to break in the batteries. as a rule charge the scooter after every use!
Scooter Doctor App
Jun 29, 2014 | Rascal 300 Electric Scooter - Used...
Rascal 600
Neil wood, the Rascal 600 DOES use an on board charger. What signal is the white wire looking for to make the scooter move is the question. 28v?
Apr 20, 2012 | Electric Mobility Power Electric Scooter...
Connecting battaries for a Rascal Autogo
When you put the second battery in the case paying attention to polarity position, the longer wire will go to the top connector. If you have a voltmeter you can identify which wire has 12 volts on it. It should be the brown wire but verify anyway. This wire has to be connected to the NEGATIVE terminal of the second battery in order to get 24 volts to the scooter. The remaining wire connects to the positive terminal of the battery.
May 04, 2017 | Cars & Trucks
On my rascal fold and go 370 scooter the battery is long battery that just slides and clicks into place at the rear of scooter,when i try to order a new battery ,all the dealers keep trying to sell me a...
  1. Two small batteries fit inside the outer case. What you thought was a battery is actually holding two batteries inside it. The batteries you need are not difficult to find.
Dec 30, 2011 | Health & Beauty
Health & Beauty Logo
235 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
