Question about Christie LX45 Multimedia Projector
Lamp is fine. How do I figure out how many hours the lamp has used or remaining?
    Master:
  • 623 Answers
The amount of operating time should be found in a utility menu. Unfortunately, knowing that doesn't really tell you how much longer you have on the lamp. Some won't make it to their rated time, some will excede it by as much as 2x. It depends on how well it has been treated. It will last longer if it has been used for long periods than it will if it's only on for a few minutes at a time.
Posted on Apr 16, 2014
Lamp hour reset NEC MT1060
The NEC MT1060 lamp hours is stored in an EEPROM chip built into the lamp. As soon as you put in a new lamp (MT60LP or MT60LPS), the hours will be reset. If you remove and put back in an old lamp, the unit will see the hours on that lamp. Thus if the lamp has reached 2100 hours, the projector will remain in standby. See page 53 of the manual for the replacement and reset information.
Most of the manuals for the NEC projectors are available here: http://www.nec-display.com/dl/en/pj_manual/lineup.html . The direct link to the manual for the MT1060 is http://www.nec-display.com/dl/en/pj_manual/mt1065.html .
I hope this helps.
May 24, 2016 | NEC MT1060 Multimedia Projector
How to reset lamp hours lt265 nec
Select the Menu [Reset] → [Clear Lamp Hour Meter] to clear the Remaining Lamp Time and the Lamp Hour Meter
Mar 05, 2011 | NEC LT265 Multimedia Projector
Lamp replaced 1.5 years ago, now the picture goes out but comes back on every few minutes, as if it gets to hot and needs to cool down. Fan comes on.
Lamps only last for 5,000 hrs -8,000 Playing hrs
It means every hour you Play TV Lamp burns up the hours, so after 5,000hrs on most Lamp needs replacing, some Lamps dont even last this long DLPs are not like Projection you can play them 24-7 and Tubes will remain good, But Lamps are like a light bulb they all burn out after so many hours.
Best thing is to turn TV off if you are not watching it, in order to Save Hours burt on Lamp.
Mats has Lamps for $99.00 1-800-628-1118
Replace the Lamp.
Mar 05, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
What would cause the green lights to come on, then the lamp light flashes without turning on the lamp? The lamp is showing 1240 hours remaining. Have tried unplugging projector to reset with no results.
possibly hasn't been able to complete cooldown mode. if you unplug it before it shuts down completely, it'll turn on by itself when you plug it in and complete the cooldown. once it stops by itself, it'll work fine.
Aug 26, 2009 | Sharp Office Equipment & Supplies
Infocus 4805 blinking red light problem
My first questions is:
Is this the first lamp you have placed into your Infocus pj? If not, did you reset the hours when you did it last time? Otherwise that can also confuse the projectors internal system thinking there is NOT a new lamp in there and there for make it stop working once the clock hours are expired and over the 3000-6000 suggested hour life.
Let me know so I can help trouble shoot other possible problems.
Oct 27, 2008 | InFocus ScreenPlay 4805 Multimedia...
BenQ MP610 Multimedia Projector Problem
I don't have the manual on this one, but in general if the lights indicated that the lamp needed to be changed because of hours of use, then until the lamp hours have been reset, the lights will remain. The owner's manual should have the procedure for resetting the lamp hours. Try that and update this if you still have a problem. Also, check to be sure that the lamp access door is closed completely. There are safety switches that get activated when the door is not installed correctly.
Dan
Sep 25, 2008 | BenQ MP610 Multimedia Projector
Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Dec 26, 2007 | Panasonic PT-50LC13 50" Rear Projection...
XG-C50 Problem
Hello
Replace the fly-eye lens of projector.
Viren
Nov 09, 2006 | Sharp (BQCXGC50X1) Projector Lamp for...
Christie LX45 Multimedia Projector Logo
105 people viewed this question
Top Christie Office Equipment & Supplies Experts
jasbo
jasbo
Lawrence Oravetz
Are you a Christie Office Equipment and Supply Expert? Answer questions, earn points and help others
