Question about Pool & Spa
Catalina spa last year the the transformer went on my catalina spa with a Balboa CL8000 controller. I just installed a new transformer. Everything works but the control display doesn't work. It looks like I have no power coming out of the board to the display plug
  • 717 Answers
When the control panel does not light up this means the panel is not working and needs to be replaced.
Rod
US Parts Center
Posted on Apr 15, 2014
Healeyman
  • 1198 Answers
SOURCE: we have a spa quip 2.5 maxi flow spa pump,tried to
Hopefully you have not fried the motor. To free a stuck motor: try to reach past the strainer to the impeller and turn it. If you can't do that, remove the electric end cover and find a double flat for a wrench where the shaft goes into the motor. Or maybe you can remove the spring thing from the end of the motor and move the shaft with a pair of vise grips or pliers. Don't damage the place where the spring thing mounts. Don't try to move the motor with the plastic fan thing near the pump, you'll just break it, and then you really have problems.
To keep a motor from sticking, thru off season occasionaly spin the pump, just a few seconds will do, don't need water.
Posted on Apr 17, 2009
Coastsider
  • 331 Answers
SOURCE: I have an older Catalina spa with acura controls.
These older style controls are easily repaired but require some electrical diagnosis expertise to determine the problem.
1. Check the pressure switch to make sure it is working properly - Use a continuity checker to see if the pressure switch is closed when pump is running. If not then check for proper water flow. Dirty filter, obstruction in plumbing. If flow is good, replace the pressure switch and see if heater works.
2. Check to see if the heater has 220V at the heater terminals when heater circuit is running. If not, then check to see if the heater contactor (relay) is actuating. Check Hi-limit switch, Thermostat and pressure switch for continuity. If heater has voltage, check for current draw, using a clamp style amp meter around on of the heater wires. look for about 20 amps. If voltage is present but no current draw, the heater is bad.
3. The spa light is a completely separate circuit, check the air switch, air line, button and light bulb. Its a 12V AC circuit.
Posted on Apr 16, 2010
Ian  Hot Tub
  • 77 Answers
SOURCE: looking for manual tech info on balboa spa control
If you have a user manual check the filter duration isn't set to continuous.
Regards,
Ian
http://hottub.synthasite.com
Posted on Apr 17, 2010
Coastsider
  • 331 Answers
SOURCE: We have a Great Lakes spa with a Balboa control
Contact Balboa's Customer support department directly at 800-645-3201, follow the prompts to customer tech support (or press 0 and ask for customer support). You will need to be at the spa, control panel open and ready to read off the chip number, and you will need to be proficient with a test meter (AC voltage). The SN error is related to a bad sensor(s), but can also indicate a failed board. An incorrect sensor set will also create this problem, so confirm you used the exact or compatible replacement. If the SN code issue is no longer a problem, but the spa is still not heating, look and see if the heater led is on. If it is, you likely have some burned relays on the board, which can be replaced cheaper than replacing the board. If you need more help, email me at info@coastsideservices.com
Posted on Aug 30, 2010
adamh294
  • 310 Answers
SOURCE: I have a Dream Maker Spa Model # 8300 Eclipse.
Either the top-side control is not sending the signal to the pump relay to close the circuit,
or the pump relay is stuck "open" or the pump relay fuse has blown.
I would start with replacing all fuses on the control panel. If you are electrical savy and want instructions on how to trouble shoot this with a multimeter, contact me here @ adamh@newconceptchem.com . i only post electrical help for those who feel comfortable with it.
Posted on Nov 19, 2010
Where may I obtain a schematic diagram for Balboa Spa control board H716R1A
Probably the only one who can provide you is the distribuitor of the board.
Nov 13, 2014 | Balboa Instruments BALBOA BOARD 100 MORGAN...
My catalina spa keeps popping the breaker and won't turn on
First, we have to establish what you mean by turn on the unit. Is the GFCI breaker set on when you try to turn the "unit" on? What are you activating to turn the "unit" on? A switch, a disconnect, a button on the topside controller, etc.? Need clarification before we proceed to diagnose. At what level do you understand electricity? Is there a licensed electrician available?
Please answer and we will take it from there. OK?
Jul 14, 2014 | Balboa Instruments Duplex Digital Panel 2...
How do you turn a balboa spa on?
FYI...
Balboa does not make spas, just control systems.
but that is enough info to begin a troubleshoot process...
  • do you have anything displaying on topside control panel?
  • Fault codes?
  • When you say no power after connection to circuit what do you mean exactly?
  • Have you checked for burned system fuse?
May 04, 2014 | AO Smith Pool & Spa
Spa Heater problems- Balboa VS-501 controls #54356.
Use a high quality external temp probe and make sure the temp sensor in your system is correctly reading the water temp.
If the water is truly 110 then you may need to replace the board completely.
Jun 20, 2017 | Pool & Spa
I need to replace my Weslo Spa Comand Panel, 4 button, ovel. will the Balboa work.
The best suggestion in this case would be to replace the spa pack and upgrade. this is a really old system. You can replace the entire system for around $500.00 and have the latest working technology along with a new topside panel, overlays, heater, system, etc. The Balboa Value Pack Retrofit kit comes with everything you need along with cables. Since you have Weslo with an oval panel, the best suggestion would be the Balboa 54219-Z Value Pack Retrofit Kit. you can get it online by clicking on the link I have provided.
Hope that helps.
Balboa Direct
Sep 10, 2011 | Balboa Instruments Duplex Digital Panel 2...
I have a balboa board #55098 and nothing works. I have disconnected everything and then tried powering up and it only clicks until the breaker trips any suggestions?
As with any troubleshooting over the Internet, this is like giving a haircut over the phone. So, that being said, this problem could be any number of reasons.
Here are some things you should have a spa technician look at (not in any specific order):
  • Power connections
  • Relay
  • Whether the transformer is seated properly
  • Whether there are loose wires
Disconnected all the components and see if it still does the same thing. If not, then one by one, reconnect the components until you isolate the problem. If the problem persists, then you might have a larger problem like a blown circuit board, etc.
Hope that helps!
Jun 17, 2011 | Balboa Instruments BALBOA 30 kW HEATER W...
Older catalina spa with top controls showing two jet speeds but only the low speed jet is working???
Please provide your catalina spa model and year, as well as the spa control system info... You can contact us directly at info@coastsideservices.com. we are a Catalina Service Center and can help you troubleshoot this
Apr 06, 2010 | Pool & Spa
I have a catalina spa with BALBOA CONTROL PANEL
Where are you from?
If you live in the UK give me a call/email as I have worked on lots of Catalina Spas over the years.
Regards,
Ian.
Jun 07, 2009 | Balboa Instruments Duplex Digital Panel 2...
Pool & Spa Logo
88 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
