Question about Amana ARB190ZC Bottom Freezer Refrigerator
Arb190zc ice maker broke - Amana ARB190ZC Bottom Freezer Refrigerator
2 Suggested Answers
  • 10865 Answers
SOURCE: broke off the ice maker shut off arm. want to
Hi. Go to the site called sears parts direct. Enter the model number and see an excellent parts diagram. Order the part and u will have it in a couple of days. J.
Posted on Jul 30, 2010
My ice maker does not make crushed ice anymore, it comes out in big pieces and regular cubes.
Hey Barb.. does it make "popping" sounds?.. if so..the ice "bucket" shaft has broken the plastic at the drive end.. or either the blades have lost their sharpened edges or the rod that runs through the ice tray is not working...
...... I have a GE.. the ice maker broke at about 13 months..I replaced it... it broke again.. its plastic and will break again...so I get no crushed ice... just big cubes..I am not replacing again!!..
Jul 17, 2017 | Refrigerators
How to repair Refrigerator ice maker that not making ice
Any chance you may have the model number of that refrigerator that you're having problems with the ice maker?
Appliance 911 Sea Breeze there are some ice makers that you can repair but as far as cost is not worth it ice makers wear out after several years there's a lot of work involved in making ice just replacing the part that broke doesn't fix the rest of the Ice maker
Sep 01, 2016 | Frigidaire Refrigerators
Making hardly any ice
Are the ice cubes being formed the same size as before? If freezer temperatures are increasing above 5 Degrees Fahrenheit in freezer this will slow down and at times stop ice production. Look around the rear wall of your freezer to see if a layer of frost is building. If yes this will indicate a defrost problem that in turn raise freezer and fresh food temperatures. Here is a Whirlpool Ice Maker Troubleshooting PDF You can find this info on this page HERE You will need Adobe Acrobat Reader to view these documents. The Adobe Acrobat Reader is available as a free download. I will be here should you have any questions, Thanks Sea Breeze
Aug 08, 2012 | Amana ARB190ZC Bottom Freezer Refrigerator
Ice maker wont make the ice
a few things to check... 1st if you have a filter on this unit has it been changed regulary and when was the last time you changed it.. next make sure you are getting water to ice maker itself... is there frozen ice in tray ...if there is no water in unit then pull white cover on icemaker and check gear assembly does the white plastic gear look broke or anything... see if the gear turns to the right with hand freely it should not ... if this has a phillips screw in the middle of gear turn screw to the right it will be a little difficult turn it about half a turn and stop does the ice maker gear keep moving on its own this will advance the timer and should go through a cycle.. if your ice maker has a "t" and "h" terminal take a jumper wire small gauge will work jump these 2 terminals out and the gear will start to turn when you here a click pull the jumper out... watch it see if water ever enters ice maker and that teeth in ice maker actually rotate. these are a few things to start with you didnt post alot of info so hard to tell you where to start... could be a bad water valve,filter, the fill tube coming into ice maker make sure it is not frose up ,gear to ice maker head broke,heater on ice maker bad... hope this helps you start at it...good luck to you
Jan 27, 2011 | Maytag MSD2454G Side by Side Refrigerator
Ice maker not making ice. motor is making noise,
Hi, Reach in and see if you can feel ant ice laying on top of the ice maker fingers that might be jamming the ice maker. The motor making a noise is why I suggest this. If you can remove the ice maker and look, it would be better. Another option is to pop the ice maker head cover off and see if the drive wheel is trying to turn or maybe even broke.
Please let me know what you find so I can assist you further.
Vic
Jul 12, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
I need an ice maker for my GE refrigerator, made in the 70's
PART NUMBER IS WR30X10093 @ $148.00 available from AP Wagner or Marcone appliance parts
Apr 09, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Magic chef MCIM30TS table top ice maker shovel breaks
I took 4 small nails, cut them to the proper length, heated them up with a lighter, and pushed them into the plastic creating 4 metal posts that the motor could push against. Just did it and it is working. Not sure for how long.
Nov 21, 2008 | Eastern Tabletop 7002 Stainless Steel 24...
Amana ARB190ZC Bottom Freezer Refrigerator Logo
15 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
