Question about LG Heating & Cooling
Remote control doesn't change mode
Doesn't change the mode, like to change from cold to hot, the rest is all ok changed already to new batteries any good please and thank you
  • 884 Answers
If all else working, problem is not with remote. More likely valve in outside unit stuck.
Posted on Apr 30, 2014
  • 15 Answers
SOURCE: wont change mode
changing mode all the time, beeping all the time, sounds like my wife - slap it!!
Posted on Jul 10, 2008
SOURCE: Only working if I use the remote
There is no power even when the power cors is plugged into the power outlet
Posted on Jul 31, 2009
SOURCE: samsung aircon remote not working
Does your remote have batteries? If yes change them. Somewhere on the unit there should be a selector switch, put it into test and manually lower the thermostat setting
Posted on Feb 14, 2010
caroldon
  • 17129 Answers
SOURCE: problem with 6711A20010D remote control no longer
Possible that there is errrors in the remote controller unit Please find guidance on how to repair a remote .
Check the link below;
http://www.fixya.com/support/r6178946-tips_repair_remote_controller
Posted on Mar 31, 2011
  • 960 Answers
SOURCE: The unit only blows out hot air. It doesn't
Make sure the control or the remote has actually changed the mode setting to cool function. Try new batteries if necessary or see if the main unit has an overide or manual control to select cooling only. It may be that the compressor is not running at all. The hot air you are feeling may be the room temperature air... Can you hear if the compressor is running or is it just the fan ??
If it is still stuck on heat mode, the reversing valve may be jammed.
Posted on Jul 03, 2011
My Vizio HDTV32 remote control is not working, I changed batteries and doesn't work.
Check its battery contacts for any dust or rust. Clean the contacts first and then check.
Oct 25, 2012 | Vizio New Original VO320E Remote Control
Magic eye light is on, but the remote control doesn't work anymore
open the remote control, and clean the keypads from oxide, corrosion, dirty.
change the batteries and put a new ones.clena the contacts batteries with pencil erase.
retight the springs contacts batteries, for better contacts. and try again.
Otherwise you must go to the repair shop TV for fix it.
God bless you
Sep 23, 2012 | Televison & Video
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
I have a 2001 Ford Focus DOHC. Heater doesn't blow hot. Hot cold indicator switch clicks as i9t should when I turn indicator but it doesn't seem to change anything
Feel your heater hoses and see if they are getting hot..If so when your click from the switch ,,make sure the door is switching from hot to cold
Sep 16, 2011 | 2000 Ford Focus
My Technika LCD32-229 is just over 12 months old and has suddenly decided not to respond to the remote or on/off control on the TV. If I turn of the power at the mains for 30 seconds or so, it will then...
HERE'S THE ANSWER TO YOUR PROBLEM:
The possible reason why your TV doesn't respond to your remote is probably the battery of your remote. Maybe it has been used up to it's fullest capacity, so try checking it up. In case, it has been used up, try to buy a new one.
The possible reason why your TV doesn't stay on is still your remote control. Maybe you have accidentally set it to "sleep mode." When it is set into sleep mode, it turns on just for a shorter time. It cannot stay on longer.
So, here's what you've got to do. Check your remote. When the remote works already, press the sleep button remote again. I hope it works for you.
Thanks.
Jul 23, 2011 | Televison & Video
The unit only blows out hot air. It doesn't switch to ac mode @ all. What is the problem?
Jul 03, 2011 | Royal Sovereign ARP-3012 Air Conditioner
My remoute control joust change the volume and anyother keys doesn't work.
The remote's volume keys are "punch-thru" keys, meaning they'll work for the TV for which the
remote is programmed no matter what mode the remote is in. It seems your remote is not
in "TV mode," but the punch-thru keys (volume UP/DOWN) are working.
The Solution: change the remote from "AUX mode" or "DVD Mode" back to "TV mode", by
pressing the "TV" button at the top of the remote.
Either that, or your remote keypad has failed with the exception of the Volume UP/DOWN keys....
Also, your batteries may be failing, since it takes a tiny amount of energy to light
the IR (infra-red) LEDs at the front of the remote to change the volume.
Is your remote a "multi-function" remote?
Could help more if you could post your Samsung remote model number, since
www.samsungparts.com lists 37 pages of TV remotes (at 10 models per page).
Jul 02, 2011 | Samsung TV Remote Control
Akai airconditioner AC-KS24HRC Changed batterirs in remote can not get heat mode icon on remote therefore no heating.Still under warranty but can not find Akai repairer Newcastle N.S.W. Australia...
I had the same problem. Check the remote control section of the manual. When you change batteries the screen flashes the hot and cold icons alternating. press a utton when the hot one is on and it will activate the heat+cool mode.
Jul 15, 2009 | Heating & Cooling
Remote kcontrol don't work
refer to the manual, it will be using the module under bonnet and the fob / button.... usually the products online site will also have this info, dependant on the brand, I know cobra do...?
Ok good luck, Chas
Jun 04, 2009 | 2002 Volkswagen Jetta TDI
Heating & Cooling Logo
54 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
