Image is cut off left and right sides On toshiba flatscreen ?
    Master:
  • 388 Answers
Whatever the source of your video is, it may not be formatted for widescreen. You can try changing the screen format with your remote control.
Posted on Apr 15, 2014
3 Suggested Answers
SOURCE: Toshiba 57LX177: Right side of screen darker than left
I am not sure...but I have the identical problem. I believe the vertical lines are caused by the inverter board and the darkness is caused by the one of the back lights that needs to be replaced. I am tearing my unit apart now and will find out.
Posted on Aug 09, 2010
gopakumarg43
  • 74136 Answers
SOURCE: TCL L46E5300F flatscreen half right side screen is darker than left side
If it is an LED LCD TV, the backlight inverter board should be troubleshooted. Contact any service technician.
Posted on Jan 09, 2014
Jan 09, 2014 | Vizio VW46LFHDTV10A 46 in. LCD TV
We have a Canon imageRUNNER 3230. Starting this morning, it has been printing everything off center. If you send a document to the copier for printing, it shifts the image to the left so that the far...
I would make sure that the paper guides in the paper tray are tight against the paper. And make sure the adf guides are close togather so the paper will not go in crocked Good Luck.
May 20, 2013 | Canon imageRUNNER 3230 Black and White...
The blade on my cricut expression won't stay down and cut the entire image, only part of it. how do i fix this?
you have something under the mat or the mat is bent. If you are using Expression which I assume you are if it is cutting on the right then make sure you haven't got your mat kinked. It should line up with the side on the left and the little bar on the base of the machine on the right. Try putting it in portrait made and doing some cuts to see if the same things happen.
Flo
Apr 21, 2013 | Provo Craft Provocraft Cricut Expression...
The image on my Toshiba 24V4210U tv is cut off on the left and right sides. Also, the Info shows 480i whereas the input from the service provider is 780p.
If closed evenly with a shaded area on each side that is the 4x3 format, I can look but so can you: some of the sets (Toshiba) are only 4x3 and not full screen (16x9) and to boot only work with HD on one input.
480 I or not is not HD.
YOU Using a box of some sort here for this set?
Dec 05, 2012 | Toshiba 24v4210u Tv & Dvd Combo
Dear sir, i have toshiba e studio 212 photocopier machine I change new toner but give the massage toner low
on out side tray the actual image is garbage left side 1 inch but in side tray select the image is actual printout
Aug 16, 2012 | Compatible Toshiba T1810 For E Studio 181,...
Image goes to black on Sharp flatscreen.
An LCD unit? Sounds like the backlight is failing. When it goes black next time, use a strong light next to the screen and look for a faint image on the screen....
If it is the backlight, its a service shop issue.
Mar 23, 2010 | Sharp 19 in. LCD HDTV
Monitor image is not centered
it's your graphics driver which normally fixes this.
Please check out if it's properly installed.
Mar 14, 2010 | Computers & Internet
How to center a screen?
Horizontal centering is performed in the service menu. Beware! You can mess up a lot of stuff in this menu.
Aug 02, 2009 | Toshiba Televison & Video
PRINTER CUTS OFF RIGHT SIDE OF PAPER
First, on your computer desktop. left click on START. Next, left click on CONTROL PANEL, and left click on PRINTERS. Find your printer on the PRINTERS window, and RIGHT CLICK on the icon. From the drop-down menu, left click on PRINTING PREFERENCES. Use the settings to set up the printer for the paper size and orientation you want to use.Click APPLY , then OK buttons to apply any changes you make. If that does not help,check the side paper guides in the paper source you are using. If they are not against the paper on both sides, the paper will not align properly with the image. Move the guides snug but not tight against the paper. If the guides are too tight, paper may not feed. If moving the guides does not solve the problem, try loosening the guides and reposition the paper until the image is properly aligned. Then see in your owners manual if there is an adjustment called SIDE-TO-SIDE REGISTRATION, and follow the proceedure to adjust the side-to side paper alignment.
Jul 16, 2008 | Dell 3100cn Laser Printer
IMAGE IS ZOOMED ON SCREEN
use the format button, might be called screen size. You are looking at a format that the screen cannot show completely, I can cut the top and bottom off or make it widescreen and lose the edges on my TV
Feb 24, 2008 | Toshiba MD20F51 20 in. TV/DVD Combo
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
