Question about Eureka Vacuums
Eureka capture too loud - Eureka Vacuums
4 Suggested Answers
SOURCE: belt change for eureka capture
Lie the vacuum down so it's completely flat, the back of it facing up. On the bottom of it, on the grey plastic, there are instructions. They say, to access the belt, remove the screws numbered 1, 2, 3 & 4. Then look at the four corners of the bottom of the vacuum and you'll see these numbers. You may need a flashlight to actually see the screws because a couple of them are pretty deep inside the plastic. Loosen them with a long shafted, Phillips screwdriver. Stand the vacuum back up and the screws should just fall out. Then you can easily pop off the cover to change the belt.
Posted on Feb 07, 2009
Vac Belts
  • 701 Answers
SOURCE: why is my eureka capture upright vacuume so loud
You need to replace the belt. You can get a replacement here:
Eureka Capture Belt
Posted on Jan 31, 2010
SOURCE: My Eureka capture bagless vacuum has just started
definitely check the belt condition, but I would check the airpath first. Start with the hose, it is very easy to remove and if you hold it to the light can see a clog. Remove clog with a straightened hangar with a rigid wire tied to the end, like a large pipe cleaner. Make sure not too heavy wire, it may rip the hose. Move from the hose to the hepa filter eliminating any possible obstructions. You'll probably be surprised the amount of debris if you do this...do it in your garage.
Posted on May 12, 2010
Why does the Eureka capture plus pet lovers put off a loud tornado siren sound when you turn it on. I cleaned the filters checked everything and it sounds like a tornado siren in the south. Email...
I would check your fan and see if any of the blades have been fractured. I had this happen recently when my vacuum caught a screw and the sound and vibration was deafening.
Dec 22, 2009 | Eureka Vacuums
How do you change a motor for a eureka model 8851
All of these vacuums capture the motor assembly between two plastic case halves, or are held in place by a band. Take out the phillips screws (sometimes the screws are under decorative plugs to hide them) and carefully pull one half off. You'll have a lot of taking apart to do, but if you actually got a replacement motor, it will be worth it.
Nov 25, 2009 | Eureka Capture Upright Vacuum Vacuum
Not picking up. suction okay on tools. I think belt is broken but how to get to it and change it?
Yes, you probably need to replace the belt. Below I have listed a link to the owners manual which has instructions on how to change the belt and a link to the replacement belt you need. Hope it helps you!
Eureka Capture Owner's Guide
Eureka Capture Replacement Belt
Nov 01, 2009 | Eureka Capture Upright Vacuum Vacuum
Vauum and loud noise
Euther you have a clogged hose or the dirt inlet by the brush roll is clogged, or the motor is bad, But if you have only used it 4 times, and you bought it new, it should have a years warranty on it. Take it to a warranty shop to have it repaired under warranty.
Mar 09, 2008 | Eureka Capture Upright Vacuum Vacuum
Vacuums Logo
14 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
