Question about Sony Grand Wega 3lcd Kdf-46e2000 46 Projection Rear
3 blinks blinks 3 long red
    Sergeant:
  • 418 Answers
Check lamp door and lamp are installed/seated fully.
Posted on May 16, 2014
Panasonic 3 red blinks
a capacitor has broken down, or blown up. my book states bad monitor.
www.ask.com/panasonic/tv/3/red/blinks/lights/mean/
Oct 06, 2015 | Panasonic Televison & Video
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
Changed bulb for epson brightlink 455wi but its still blinking red
Is it just one light blinking red or all 3 blinking red? Be sure to 'reset' the bulb hours. Try another bulb. If it is all 3 lights blinking red then you are sol.
Mar 10, 2014 | Epson BRIGHTLINK 450WI Projector
Beeps red light hp pc
The blinking should be in a pattern.
Power Green On (S0) Computer on
Power Green 1 blink every 2 seconds (S1) Suspend Mode
Power Green 1 blink every 2 seconds (S3) Suspend to RAM
Power Green Off (S4) Suspend to Disk (if applicable)
Power Clear Off (S5) Computer off
Power Red 1 blink followed by 2-second
pause - Repeat
Power Supply failure
Power Red* 2 blinks 1 second apart CPU thermal shutdown
Power Red* 3 blinks 1 second apart CPU not installed
Power Red* 4 blinks 1 second apart Power supply overload (crow bar)
Power Red* 5 blinks 1 second apart No memory
Power Red* 6 blinks 1 second apart No graphics
Power Red* 7 blinks 1 second apart System board failure (detected prior to video)
Power Red* 8 blinks 1 second apart Invalid ROM
Hard Drive Green Blinking Hard drive activity
*Blinking
Aug 17, 2013 | HP Computers & Internet
Tv Wont Come on 3 red blinks pauses 3 red blinks pauses 3 red blinks
A 3 blink error on this model is saying that your lamp cover is not on properly. Check your lamp cover and door. Make sure they are seated sucurly. If this doesn't fix your problem. Then the switch or little board buy the lamp cover is bad and needs replaced. This is called the T board.
Mar 15, 2013 | Sony Kds-r60xbr2 60" Xbr Rear Projection...
The red light is blinking and when i turn it on it goes to green for a few seconds and then beeps and blinks red again.
You have "The red ring of death" If 1 corner is blinking: Turn it of and wait a few days for it to cool off. If 2 corners are blinking: Do the same, but check after 3-5 days to see if it works. If 3 corners are blinking: You HAVE to see a xbox repairer, because you can't wait after 3 rings. Saddly, a complete ring of red: You can't do anything about it, it can't be repaired, but check the power wire and reattach it, there's a little glitch where if you loosen the wire, it does that. Good luck!
Sep 04, 2011 | Sony Playstation 3 (PS3) Console
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Well i am having a problem with the blinking any1 help
Try the tips in these articles, they may help :0
<a href="http://ezinearticles.com/?Have-You-Got-Issues-With-the-PS3-Red-Flashing-Light?-Fix-This-Problem-Today&id=3629324">PS3 Red Flashing Light</a>
<a href="http://ezinearticles.com/?PS3-Red-Light-Fix---Quick-Guide&id=3512073">PS3 Red Light Fix</a>
<a href="http://ezinearticles.com/?PS3-Blinking-Red-Light-Problem-Solved---If-You-Have-This-Problem,-You-Really-Need-to-Read-This&id=3512063">PS3 Blinking Red Light Problem</a>
<a href="http://ezinearticles.com/?PS3-Red-Light-of-Death---How-to-Fix-it-Quickly-and-Easily&id=3512067">PS3 Red Light OF Death</a>
<a href="http://ezinearticles.com/?Thinking-About-Buying-a-PlayStation-3-Repair-Guide?-Then-You-Better-Read-This-Before-You-Do!&id=3676847">Playstation 3 Repair Guide</a>
Feb 12, 2010 | Video Game Consoles & Games
3red lights how do i find the code
Press and hold the sink button then press the eject button 4 time
and note the 4 digit code .
4 blinking reds = 0 3 blinking Reds = 3 2 blinking reds= 2 1 blinking red=1
The code doesn't relay matter ,the problem is broken solder connections.
under the G.P.U 90% of the time , and that chip need to be re-flowed.
if you have any questions just comment and ill respond.
Rob
Oct 19, 2009 | Microsoft Xbox 360 Console
Have a panasonic 47" HDL projection tv..under 5 years old model # pt-47wx53g, chassis Ap 825,manufactured August 2003 Purchased Oct. 2003. Have cable service..TV works fine until 2 weeks ago. Screen...
3 blinks means the convergence circuits are shutting the set down. Usually the convergence ICs will take care of the problem, but I would recommend getting the service manual from the following link, as they will provide you free support to help you diagnose why it wont start as usually the convergence ICs wont prevent a set from powering up, unless another component in the convergence circuit has failed.
http://servicemanuals.vstore.ca/
Mar 24, 2008 | Televison & Video
Sony Grand Wega 3lcd Kdf-46e2000 46 Projection Rear Logo
54 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
