Question about Admiral Washing Machines
My wash machine tries to fill, but it sounds like the pump is pumping it out as fast as it fills.
    Novelist:
  • 150 Answers
The number one suspect reason for simultaneous fill and drain would be that your washing machine drain hose is inserted into your wall drain too far. The drain stack pipe in the home should be as high on the wall as the top of the washing machine main top/lid, and the hose from the washer inserted no deeper than 10" and properly secured to one of the adjacent water shut offs with a zip tie. If this is your issue, your drain system in the home is creating a siphon through the washer drain hose and literally sucking the water out of the washer. Pleazer Appliance...
Posted on Apr 15, 2014
  • 1294 Answers
SOURCE: Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
Posted on May 18, 2007
  • 38 Answers
SOURCE: Washing Machine Hoover H100M fills too much water in the drum.
this is 1 of 2 solutions  2 this problem the first thing to check is the vacuum system or it is a split in the pressure switch hose
Posted on Mar 05, 2008
  • 1214 Answers
SOURCE: Washing machine won't spin
This site should help -
http://www.washerhelp.co.uk/diy-repair-help_4.html#cl_q2
I am thinking moor brushes, but it could be any one of 3-4 different problems.
Posted on Jan 28, 2009
  • 497 Answers
SOURCE: Hotpoint Aquarius WT540 washing machine. will not fill with water
Sounds like a timer switch malfunction.
Posted on Sep 06, 2009
  • 464 Answers
SOURCE: Washing machine fills with water, but won't begin
Sounds like you may have a bad lid switch and won't acitivate the machine.
Posted on Jan 24, 2010
Intermittently stops and starts pumping water
may have something blocked in the pump outlet valve
your washing machine will let out your water if you put your pump hose on the floor
Jun 23, 2014 | Fisher and Paykel Washing Machines
Haier HLP21N washer won't fill. Water runs right through from the faucet to the drain hose.
Is the hose in the sink or on the floor? If in the sink, it sounds like the pump is running all the time. If the hose is too low, it maybe syphoning out the water as fast as its going in.
Nov 08, 2013 | Haier Washing Machines
My machine start to fill with water and about half way full the water starts running out juswt as fast as it is going in
Check the drain and see if the drain valve or pump is open due to clogging of dirt. If so back flush the drain and reset the unit , drain pump.
Jun 11, 2012 | GE Clothes Washer Model Select Connector -...
Washer doesn't fill with water and begin wash cycle. I can hear it instantly draining out rather than fill, and has ran my well dry. We replaced the water pump a month ago, and it washed a few loads of...
Sounds like siphoning. This can happen if your drain pipe is too low and you run the drain hose right into it, or if there isn't any kind of air gap between the drain hose and pipe. Usually it shows up when trying to fill for the rinse cycle - it drains as fast as it fills. Or it might not fill at all. Order a "siphon break kit". They're cheap and easy to install
May 26, 2010 | Roper RAS6233KQ Top Load Washer
Water drains out as fast as trying to fill
hello, have you checked to see if your drain valve is'nt stuck open ?
Mar 31, 2009 | Washing Machines
Attempts to fill w/ water but won't...
you can check the inlet solenoid coil. maybe there is no power coming to the coils or if there is power, the coil is burnt.
tnx 4 using fixya,
drcool
Oct 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
