Question about Whirlpool Dryers
Whirlpool WED7800XWO heater element replacement
I have a whirlpool WED7800XWO that is maybe two years old and it stopped heating. I have ordered a new element, but does anyone have any experience on how to change this on one of the newer Whirlpools? I have read a few places that these are changed in the front, but there is not a lower plate on this model as described?
watugot
  • 290 Answers
SOURCE: Kenmore Electric Dryer Model # 110.62622101
I think on your machine the lower thermostat connected to one terminal of the element, you have a wire coming from the thermal cut off down to the top terminal of the lower thermostat, a wire from the lower thermostat to the timer, and a wire going to the other terminal of the element.
You probably have the wire from the cut-off correct as it won't reach the other terminals. You have crossed the other 2 wires. This caused 240V to short across the lower thermostat and burned it out.
You will need a new Hi-limit thermostat, which will include the upper cut-off as well. They come as a set part# 279816. This will be a little different because the new hi-limit will not connect directly to the element. There will be all the wire ends and instructions with it that you need to get it hooked up correctly.
There should be a wiring diagram inside the console of the dryer that shows which wires go where, but I am sure you have crossed the 2 wires below the hi-limit switch.
Post back if you need any help.
Thanks/Mike
Posted on Dec 02, 2007
  • 156 Answers
SOURCE: Newer Whirlpool Dryer Heat Element keeps breaking
  • clean out the dryer vent make sure hose behind dryer not pinched close ck the temp comeing out bac k dryer should be around 160
Posted on Mar 06, 2008
canbruce75
  • 1776 Answers
SOURCE: Dryer Stopped Heating
Use a multimeter to check the heating element. You can't always go by looks. Check continuity and if there is none, the element is defective. Another thing to check is the thermal fuse. It is about an inch long and is usually attached to the exhaust duct. Use the meter to check it as well and if defective, replace it. Sure hope this helped and best wishes.
Posted on Jul 28, 2009
jsrock516
  • 5911 Answers
SOURCE: My Whirlpool Imperial Series Dryer is 4 years old. NO Heat.
It may not be the heating element causing your problem. There are other components that can fail that will cause the same symptoms. The following link explains how to troubleshoot a dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer will exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the washer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum. All dryers are not constructed the the same. Regardles of location, the Heating Element is located inside the heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals. If either the TCO or Hi-Limit Thermostat are determined to be bad, replace both components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace. All these parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop around for the best price.
If you have any questions, please let me know. Please inlcude your complete model number (located on a nameplate around the door opening) when asking questions. I hope you find this information helpful.
Posted on Sep 07, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Maytag Performa dryer blowing heating elements
Hi and welcome to FixYa. You should check the dryer vent ducting inside and outside the dryer for restrictions / clogs to include the vent flapper. Poor air flow through the dryer will cause hot spots. If the blower is slipping on the motor shaft this too can cause poor air flow.
When you change the heating element AGAIN... break out the crevice tool and de-lint everything you can access. Also pull out the lint filter and wash it with white vinegar and water then soap and water. Fabric softener sheets material builds up on lint filters. It looks clean but air will not pass through the lint filter.
I think once you get it all ceaned up including all of the ducting to and through the outside wall it will work normally with no problems. I do not think at this time that you have an electrical problem with the outlet supply.
There is one more thing to check and that is the high limit thermostat. It could be STUCK. It will most likely be labeled L180 or L190. That thermostat is suposed to open at either 180 deg or 190 Deg depending on which one is installed. If it does not open then you will keep cooking your elements. We test them with a match and an Ohm Meter. Match under the removed thermostat CLICK. Thermostat opens (no resistance)
Wish ya the best.
Thanks for using FixYa.
Kelly
If anything in the future crops up with this same issue.
Posted on Apr 10, 2010
Water heater heats water and then cuts off. I replaced the lower element with a guaranteed for life element. It still heats up and cuts off. There is a control box on top that allows for an easy reset. ...
1) Bad thermostat or thermistor depending on model.
Whirlpool/Craftmaster/American energy smart has control box on top, and you can order parts from Whirlpool.
2) Copy following links to help identify product.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
3) Add a comment with more detailed information:
You have electric water heater.
Unknown brand, possibly energy-smart.
Unknown control box.
Cut off? Do you mean 'reset' is tripped?
4) Whirlpool energy smart requires 10 gauge wire and 30 amp breaker.
Control panel may not function with undersized electric supply.
Control panel has blinking-light errors ... if no error code then maybe the control box is bad.
Jan 18, 2013 | Water Heaters
To check the elements hot water hearter stop heating.whirlpool electric
While the power is off to the water heater it's safe to remove the access panels. Once the elements are exposed a multimeter that is set on the Ohms can be used. The average reading of a good element is around 12 ohms. This can range a few ohms up or down. If you don't get a good reading the element will need to be replaced.
If the water heater has two elements the top element should be checked first. When a Whirlpool heater has two elements and the top goes out this will cause the water heater not to heat at all.
If both elements show they are good it would be recommended to contact the manufacturer. The technical support line for the Whirlpool water heaters is 1-877-817-6750.
Sep 02, 2010 | Whirlpool Water Heaters
Our Whirlpool Senseon Dryer stopped heating. It's
I had the same problem. I replaced the thermistor,heating element and another part and still didn't correct problem. i finally had a friend come check it and believe it or not it was the 30 amp fuse in my fuse panel of the house.Come to find out the dryer will run and everything works like it should on 1/2 of the 220 plug but the other half runs the heating element.Both fuses must be good. I replaced the 30 amp round fuse and it works and heats perfect. I hope this helps you and saves you some time and money.
Tommy
Mar 16, 2010 | Whirlpool Dryers
Replaced both elements, both thermostats. What else could it be?
no hidden switches!, did you replace bottom elements? and thermostats? one hint...bottom element heats first, then top...never both at one time.
Mar 24, 2009 | Kitchen Appliances - Others
Replace Heater Element for Whirlpool Model GU 1200XTLB1 Dishwashr
Look inside the dishwasher to see where the heating element terminals are. If they are in front you might be able to change it but if the element is in back, you will need to have the dishwasher pulled out to install the element.
http://tclaundryrepair.com/
Feb 20, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Dryer still wont heat
you could remove and bench test the theromostat. my kenmore would not complete the circut to heat at all with a faulty thermostat. Just use a jumper wire to bypass it and test it THERE WILL BE NO SHUT OFF COULD HEAT UP TOO MUCH IF LEFT RUNNING.
Dec 19, 2008 | Whirlpool LGR5634L Gas Dryer
Maytag dryer: pye2300ayw
yes, it will. you should be able to take off the panel on the bottom of the front of the dryer. way in the back is the heating element. do not put your hands in there with the power on, but start the dryer and look in there and you will see if the heating element comes on. it will be like looking inside your toaster.
Oct 27, 2008 | Maytag PYE2300AY Electric Dryer
Dryer doesn't get hot or turn off.
yes very possible timer but my guess on the times i seen the problem would be the heating element are the thermo fuse on the elemnt canister when the heater does not come on the timer will not move ck the heater and the fuses on the heater canister it will fix your problem
Feb 28, 2008 | Whirlpool LER4600 Electric Dryer
Dryers Logo
85 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
