Question about Music
Hughes and Kettner WARP 7 Guitar Amp
Patch cord needs to be put in FX Send directly into FX receive so amp will work. Cracking and popping with very low volume if this is not done...Been this way from day one and works perfect if cable is used like this ! However this isn't the correct way for any Amp to work !
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 82 Answers
Sounds like you have a bad FX jack. When the patch plug is removed the audio passes thru the jack. If the contact is dirty or bent and hardly making contact then audio will not pass thru like it should. Inserting the patch bypasses that internal contact.
Posted on Apr 17, 2014
fleshgear
  • 541 Answers
SOURCE: Receiving Intellisync message
for this you need to reconfigure the synchronization settings for your destop organizer proram
please follow the same.
1. connect Blackberry to the computer.
2. open desktop manager and click on SYNCHRONIZE.
3. click on the CONFIGURATION tab
4. click RESET CONFIGURATION
5. click CONFIGURE SYNCH
6. Select a BlackBerry device application (Address Book, Calendar, MemoPad, or Tasks), then click Choose.
7. click BROWSE
8. add the folders you want to synchronize and then click OK
9. click OK to close the chose application window
10. click OK to close the device cinfiguration window
11. synchronize the organizer data on your black berry device.
Posted on Jul 16, 2009
  • 34 Answers
SOURCE: can received & read but cannot send yahoo mail from iphone
First step is try reseting the network settings. You can do this by going to settings/general/reset and reset network settings.
This will drop you off the network and reset your phone. Bringing your phone back up with current network settings.
Try sending mail. If this doesn't work, try changing your outgoing mail server.
Go into settings/mail, contacts, and calendars/(your yahoo account)/Outgoing mail server.
This will bring you to a list of mail servers, your primary server being the yahoo server with the AT&T smtp server under other.
Click on your primary yahoo server and switch this server to off. click the blue smtp arrow on the very top left. This will bring you back to the server list. go to the AT&T smtp server and turn this server on.
Go ahead and exit out either by the arrow or the home button.
Access your yahoo account see if you can send mail.
Posted on Oct 02, 2009
Testimonial: "fabulous! thank you! work perfectly now!"
SOURCE: my iphone wont make calls, send texts & the 3G isnt working, help
check ur phone settings if your firewall state is on it should be off click call firewall state off,sms firewall state off.try n let me know
Posted on Jan 12, 2010
  • 2069 Answers
SOURCE: Hi, I Have a w995 & the ear piece volume is low.
check around the ear piece, make sure that rubber piece is there and properly placed around the ear piece.
regards
Posted on Mar 29, 2010
  • 4 Answers
SOURCE: My Motorola Photon Q will not receive or send texts or calls, what can I do?
I would check with sprint to see if your account is up to date. Otherwise, I would suggest going to your settings and see if you can update your phones's prl and profile. go to settings, tap "About phone", Tap "System updates", then tap each option. Good Luck!
Posted on Dec 05, 2012
How do I install patches?
Download n install 2 softwares for G2 from ZOOM website.
1. USB subsystem. Driver to connect zoom fx to PC/Notebook.
2. EDIT & SHARE. Software to create/copy sound patch.
Connect USB cable from G2 to PC/notebook.
No need adapter power supply, because the power is supply via
USB cable from PC/notebook.
Open EDIT & SHARE. It's easy,like copy,paste,rename,delete etc.
Just open the menu that you want to do and follow the
instructions. Sound patch can be load from files that you
download, or create it in EDIT & SHARE.
Patch can be load one files or group. Right Click the sound that you want to change,copy-paste it from new file/sound.
You can import/export files/patches from/to PC library (downloaded files).
It is recomended that you save/backup your original files,before load new sound.
I hope this helps.
Regards.
Aug 31, 2015 | Zoom G2 MultiEffects Guitar Pedal
Behringer ac 112 guitar amp powers up, display works. dials act normally, but no sound. only static as volume turned down (speaker works). amp was left on for long period
Try putting guitar trough the FX Loop, if there is still no sound, you may have a problem with the Power Supply.
Oct 01, 2013 | Music
Low volume on my marshall
I am very new here and don't know how to answer a question to a specific problem so I will write about the most common problems that I have had over the decades doing guitar amp repairs. If you find that your amp is extremely low in volume and then suddenly comes back to normal- check out the effects return [or power amp in] jack. Especially in Marshall amps-these corrode and your signal dies. If there is loud noise such as hissing and crackling with no guitar patch cord in the input jack- the input jack is likely at fault. They normally have switching contacts that ground part of the input circuit when the 1/4 inch male plug is disconnected. When this in is corroded or too weak to make normal contact, you can get these symptoms. If your amp is a solid state Marshall or Fender and there is a random buzzing sound with no guitar signal connected- hit the side of the amp and listen for the buzz to go away or become louder-if it does, this usually means that the connections are loose at the two large filter capacitors. In one or more Marshall amps, they use a filter circuit in the low voltage power supple for the preamp tubes. If you encounter a dead Marshall[the model escapes me now] remove the circuit board and resolder the four connections at the bottom of the bridge rectifier. If you have any other amplifier repair questions you can email me direct at computerlen@hotmail.com.
Nov 14, 2011 | Marshall Mg100dfx 100-Watt Combo Guitar...
Marshall mg100hdfx head. I get no sound whatsoever plugged into the guitar input but the controls seem to work as I can hear changes in the light ambient static. I will get sound however if I plug directly...
You MAY have a broken input jack. If you can hear changes from the overdrive gain control, that control is just one stage away from the input jack. Also there is a capacitor C60 that is for RF bypassing and if that shorts that will kill the audio. Yes, inout jacks get destroyed by tripping over guitar cables... that is why you run the cord through the amp handle before plugging it in. Of course verify your guitar and cable is good using another amp.
Aug 30, 2011 | Music
My DL4 doesn't sound as it should in my series fx loop. Is there any way possible to solve this problem WITH OUT putting it directly into the amps input? I need help!!! I play my amp wich is class A...
your parallel loop only has input, a series has out and in, you need to patch the out of amp to the in of the pedal, and out of the pedal to the in of the amp fx loop. then you need to make sure your loop is turned on, via switch or footpedal.
Jul 05, 2011 | Line 6 DL4 Delay Modeler Effects Guitar
I'm trying to add a Digitech X Series EX-7
You CANNOT use the Voodoo as it outputs DC voltage and the EX-7 requires an AC voltage and of 9 VAC and also 1.3 amps at that.
May 07, 2011 | Digi-Tech Digitech X-Series Synth Wah...
D10sce will not work when plugged into the amp. the cord is nine ( works with my electric.) battery is new. when you turn up the volume on the controll, you can hear it in the amp, just no pick up sound.t
SUBSTITUTE Change the guitar for a friends to see if the amp is really OK. Try your guitar in a friends amp to see if the guitar is OK If the guitar is at fault its either the battery, the connection cord, the little pre amp in the guitar body (you can't fix that) or you have put nylon strings on the guitar which needs stell strings for the pickup to work. Good luck
Feb 13, 2011 | Washburn WD10SCE Cutaway Acoustic-Electric...
My warlock makes this horrible noise as i plug in the cord. I don' have ANY idea why. I've been messing around with it and still nothing has worked out. It makes the sound as if my amp is turned all the...
If the noise is a pop or click, that's normal. Any other sound could be caused by too long a cord, which will produce noise while on the floor.
If it's not the cord, then you most likely have something wrong with the wiring inside the guitar. Have a luthier (guitar builder and technician) look at it, and s/he should be able to fix the problem.
Hope that helps!
Nov 21, 2010 | B.C. Rich Nt Warlock Electric Guitar
Hiwhat is the best way to connect my DigiTech RP10 to my Marshall MA100H Guitar Amplifier
Read your manuals for both pieces of gear carefully first. You only have one amp so you won't be able to take advantage of all the FX on the Digitech as a lot of them are designed for stereo. The Digitech manual shows guitar into the Digitech and output from the Digitech into input of any guitar amp. Since you have a Marshall and can already get some great sounds by running your guitar straight into the Marshalls input, you would probably be better off using your Digitech in the FX loop. Run a guitar cord out of the send on the loop into the input of the Digitech and a guitar cord out of the left / mono output jack on the Digitech into the effects return jack on the Marshall. Start out with the effects level on the Marshall all the way down. Do the same with the Digitech with both the input and output levels. (Read the manual carefully) I think the choice of the Digitech isn't that great because it is already trying to reproduce a lot of what you can already get with just your Marshall but with a little experimentation and some careful adjustments you should be able to add to the sound of the Marshall. Hope this helps.
Oct 23, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Loud buzzing when amp connects to guitar
Is there a loose connection anywhere?
Jan 03, 2009 | Music
Music Logo
79 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
