Question about Mitsubishi VS-60609 60" Rear Projection Television
My mitsubishi model 60609 does not come on after lightning struck the light comes on and then goes off
The light on the front comes on for about 30 secons the it goes of i checked the fuses in the back but they are all good
SOURCE: Mitsubishi VS-60609 50in. Rear Projection
Hi did you find a solution my 60 " tv has a similar issue.. the green light stays on but nothing.. please help
Posted on Oct 09, 2007
freetek
  • 5568 Answers
SOURCE: No power on 2002 Mitsubishi VS-60609
You've mad the right decison; fuses can fail due to metal fatigue as they flex a little each time current flows through them of ceases but a 2nd fuse is unlikely to fail instantly. This indicates a true problem.
If you found the fuse, it was probably located on the main power supply board and this item has likely failed.
Look for an assembly number on that board and call a Mitsu service company and inquire about repair or replacement cost. Either one can range from ~$75 to $150.
It would be interesting to know if the fuse blew as soon as the unit was plugged back in or only when you tried to turn it on with the remote or power button on the set.
If it blew only by plugging it in, that power board is the culprit. If it blew as you tried to turn it on, it could be a failed 2nd power supply for the CRTs that is often located separate from the main supply where the fuse was.
About any E-tech could ferret out the which of the two is at fault so you might consider having a pro do the repair but if you know the failure sequence you might choose to gamble on making the decision yourself.
Good luck-
Posted on Jun 19, 2009
ginko
  • 19396 Answers
SOURCE: I have a Mitsubishi WS-55711
Hi.
There is a service bulletin. The problem is usually caused by a defective DM power board. Before replacement, the power board must be tested. Rather than replacing the whole board, the repair job is done testing and replacing at component level.
Here from Mitsubishi Bulletin:
Chassis V21 (this TV): Check C9B01, C9B02, C9B03, C9B13, C9B14, C9B17 and C9B18 (1000 uFD, 16V, 105C) on the DM Power PCB located within the DM Assembly. If they are bad, replace them with part # 181P734030 (680 uFD, 16V, 105C).
Here Service Manual - Chassis V21
Here Tv Repair Kit (not necessarily the cure, parts must be tested, the repair involves testing and soldering and must be done by a trained person).
Regards.
Ginko.
Posted on Sep 20, 2010
  • 77 Answers
SOURCE: I have a vs-60609 60"
Sounds like a Picture in Picture screen popping up, but if you do not have a signal from another tuner, it will be blank.
Try hitting the PIP button on your remote to see if it turns it off and on.
Plus go into the tv menu and find the PIP settings.
Posted on Apr 15, 2011
maatmartin7
  • 1229 Answers
SOURCE: i have a mitsubishi 60inch
You will need to replace IC8c00 (STK 393-110) . This is your convergence IC. You will need to measure all of the 6.8 ohm resistors, replace as necessary. These resistors will have blue,gray and gold stripes, there may be sixteen of these. Expect to replace at least three of these if not more. Replace caps C8c05 (25 volts at 100Mf),C8c07 (25 volts at 100Mf). Other caps to replace are C2c86 (25 volt at 10Mf),C2V17 (25 volt at 10 MF) and C601 (350 volt at 1 Mf). you will also need a keen eye to resolder connections behind tuner TU1A02 (says RF). Jumper sockets CE,RG,DM,VU,DP,EL. Check and resolder socket connections KC,KB,AV1,AV2 and resolder IC 2p30. And you will also need to pull the power supply board, resolder jumper connections CE, RG, DM, VU, DP, and EL. Resolder the vertical IC , this IC will be of the LA78XX series,(do not use excess solder and short the pins). Resolder the horizontal transformer, and the flyback transformer. You will need a keen eye to visually inspect bad grounds on power resistors,horizontal transistor, horizontal output transistor any any and all regulator transistors located on heat sinks. This may seem complicated, time and patience will repair this. Spend an hour a day for two weeks to fix this. Thanks for asking and show all hands of support!
Posted on Jun 01, 2011
Testimonial: "thank you for the info. its the best i have gotten. :) "
My tv will not turn on
Does the set if model listed here is correct come on with the green power light for a few seconds and then that goes off?
Dec 22, 2012 | Mitsubishi VS-60609 60" Rear Projection...
What is wrong with my mitsubishi 60609 rear projection tv it got hit by lightning through the cable the light comes on then goes off when did the trouble shooting it blinks 2 tmes then 3 times then 2 times...
two, three is deflection problem------something in the deflection circuit is bad.
I can offer you options (I know these sets well) and if you want endless emails here we can do that or if you have Yahoo IM or Skype IM we can have live talk there.
I do this for free, my intent is to help you.
The ball is in your court, how do you want to proceed?
SD TECH
Jun 04, 2011 | Mitsubishi VS-60609 60" Rear Projection...
Stereo struck by lightning and i need to fix it...
I would have thought it will become obvious from the burnt parts and broken parts inside the amp, if it was struck by lighting, when you take the top off. But clearly unless it has an aerial connection, it will have to be from the mains lead that lighting went in to the unit, so a good look around the power supply section, I think first.
To be honest depending on the damage if you fix this one they should give you top marks!
Many service people would say no-chance!
Feb 05, 2010 | Bose 901 VI Main / Stereo Speaker
Mitsubishi VS-60609 60 in. no pix /has sound
My Mitsubishi TV model VS 60609 is showing double vision on the screen.
Feb 24, 2009 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi VS 60609 60 inch
Hi, I need a Diagram for a Mitsubishi VS-60609 my E-mail: varo9@hotmail.com Thanks!!!
Oct 16, 2007 | Mitsubishi VS-60609 60" Rear Projection...
Jun 09, 2007 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi VS-60609 60" Rear Projection Television Logo
23 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
