Question about Lexmark Pro915 All-In-One Printer/Copier/Scanner/Fax
PRINTER WILL NOT PRINT
PRINTER WILL COPY, SCAN AND FAX, BUT CANNOT GET IT TO PRINT ON ANY COMPUTER ON THE NETWORK.WHAT TO DO TO FIX THIS PROBLEM?
  • Lexmark Master
  • 3,592 Answers
You need to assign an ip address most likely to the printer and hook it up to your wi fi, it will need to know the encryption code for your wi fi router or ethernet and then you need to set it up most likely with the driver setup disc to allocate it an ip address from your network. then each p.c will need to have driver disk run and driver should detect printer on network.
Posted on Apr 15, 2014
Printer will not print or scan from computer. says the computer is not found
You have to run the printers driver CD and go threw the steps to create a network connection.
Jul 17, 2014 | HP Officejet 4620 e-All-in-One Printer,...
Toshiba estudio 255 Cannot usefunctions
you must connect the machine with you're computer.you want the fax you must check the you're photocopy machine have a fax board.you want the scan & printing connect the photocopy machine to the computer.(network cable)
Jan 27, 2014 | Toshiba estudio 255 Copier
Copy result is blurred
Does the printer scan OK?
Is the platen glass clean?
Dec 10, 2013 | Epson ME OFFICE 620F MULTIFUNCTION INKJET...
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
Is lexmark x7170 fax machine wireless compatible
The Lexmark X7170 printer does not support wireless printing. It doesn't have a wireless network adapter to connect to your wireless network.
If you want, you may contact Lexmark Technical Support Center for other printer options. You might find one that will suit your printing needs.
Nov 26, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I have a Lexmark X8300. All was ok till recently. I can print out anything from the computer but can't use the copy feature. Also, all of the lights stay on - the copy light, fax light, scan light,...
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/eO4Y77. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 23, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Hp officejet 4315 how to switch from fax mode to print
There is no "print mode", Fax, Copy and Scan are modes one can enter, printing on the other hand is done when a print job is detected from your computer
DRIVERS to suit download link
Download Manual and Setup guide HERE
Please rate solution as fixed.
Nov 19, 2007 | HP Officejet 4315 All-in-One Printer
Lexmark Pro915 All-In-One Printer/Copier/Scanner/Fax Logo
44 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
