Question about NetGear WGT624 Wireless Router
Netgear wireless router keeps droping wifi - NetGear WGT624 Wireless Router
    Genius:
  • 1,061 Answers
kleeper
  • 87 Answers
SOURCE: netgear wireless router keeps asking for password do not have one
Login is admin and password is password are the defaults for this router.
Posted on Oct 31, 2008
  • 20 Answers
SOURCE: NETGEAR WGR614 Wireless Router keeps beeping
try by upgrading the latest firmware version from netgear website
Posted on Dec 16, 2008
cnavarro
  • 2460 Answers
SOURCE: Netgear Wireless Router won't work with my Linksys wired router.
As asked above, why would you want the wired router and the wireless router on the same network?
The direct answer to your question(s) is found on Netgear's website. http://kb.netgear.com/app/answers/detail/a_id/965/kw/wpn824/r_id/166
The key is to turn off the Netgear DHCP, and give it an address that is unreachable by the Linksys DHCP ie if the Linksys gives out IP addresses starting at 100 or 101, you set your IP address to 99, turn off the DHCP, and plug it into the network NOT using the WAN port, ever. We tend to start at 251 or 221 just for clarity's sake.
The point is you answered your own question. The Netgear wired and wireless works fine. One piece of equipment and better reporting statistics....what are you missing?
Carl
Posted on Apr 25, 2009
  • 442 Answers
SOURCE: netgear wireless router wgr614 not transmitting
Yes changing channel will make a diffeence most of the time for this kind of issue. The reason is there could be multiple routers or interference in that area locking to the same frequency.
Posted on Aug 01, 2009
anandg27
  • 1272 Answers
SOURCE: iPhone keeps dropping wifi signal on Netgear DG834G router.
Hi, please perform the below steps to configure settings on the router:
1. Connect a computer to the router using any one of the 4 available ports.
2. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
3. Access the router, usually with http://192.168.0.1 or http://www.routerlogin.com.
4. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
5. Click on WAN setup from left menu. Check the box for 'Disable Dos Protection'.
6. Set the MTU size to 1400. Click apply.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jan 08, 2010
Why did the router ID change when I linked it via the Wps button to the DSTV wifi gadget ?
Here's and excerpt from the Netgear WNR2000 user manual explaining that this is normal behavior for Netgear routers that support WPS..:
  • Keep Existing Wireless Settings. This check box is automatically selected after WPS is enabled to prevent unwanted settings changes, and is also selected if you have already specified wireless security settings or your SSID without using WPS. When this check box is not selected, adding a new wireless client using the push button or the Add WPS Client screen (see "Push Button Configuration" on page 2-14) changes the router's SSID and security passphrase. You might need to clear it if you are using certain registrars, such as for a Windows Vista PC, to configure the router through WPS.
Even if your router is not a WNR2000, it is likely that the configuration interface pretty much the same so you might be helped by looking at Chapter 2 page 17 in the WNR2000 manual here..:
Or else, go to Netgear support (NETGEAR Support Welcome), select Wi-Fi routers and download/display the user manual pdf and search it for "disable router's pin" or "keep existing wireless settings" and verify/change the setting so the router doesn't make changes when you use the WPS button.
May 20, 2016 | NetGear Computers & Internet
What is the code for netgear WGR614v7 to enter to a laptop for wireless wifi?
Connect a LAN cable from the Netgear to the LAN port on your computer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the default admin password and configure the wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security b>
Jan 28, 2013 | NetGear WGR614 Wireless Router
Netgear wifi router
1) does it lock up completely or will it work hard lined when wifi fails?
2) do all devices wireless fail or just a single device?
3) do you lose connection to the wireless completely or keep the connection but lose access to the internet? (confusing but very different to me)
in the end you could narrow down the problem but if you have already reset to factory defaults and set back up again and again then it may be time to retire that old router.
Dec 28, 2012 | NetGear DG834G Router
Not accepting password
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash.Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Dec 09, 2011 | NetGear WNR1000 Router
I have a MiniDell Inspiron Netbook that will connect to the internet through a neighbor's WiFi, but will not connect through my own Netgear router. The router is working fine for 2 other connections. How...
You may want to do a reset on the router by holding down the reset button on the back of your router. That will reset and MAC address filtering or any other security that you might have turned on.
Mar 08, 2011 | NetGear WGT624 Wireless Router
Intenet connection droping repeatadly
Well, if the wireless connection is intermiitent then it is best to change the wireless channel on your wireless router.
Hope this allows you to resolve the issue.
Regards
Anand Gupta
Apr 27, 2010 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Frequent interruption to wireless users:
RF interference is the most common reason why WiFi will drop signal from time to time. First – make sure your wireless router is not next to a source that can cause interruption. I have mine on a shelf about 5 feet off the floor. Also make sure that your wireless home phone is not right next to it. Home phones can cause issues with signal as well.
Keep me posted
Jan 30, 2010 | NetGear Computers & Internet
Had my netgear router for months now and not had a
Solution to intermittent wireless connection is change the wireless channel of the router. Usually the default channel is 6 which is prone to interference. You may try channels 11 and 1. They are the next strongest channel of the router. Try to reset the router first.
Jun 06, 2009 | NetGear DG834G Router
Connection
Connect your broadband router to the netgear router, set your netgear router as "gateway" and put netgear's IP address as your DNS Server and Gateway in your laptop wifi connection.
Mar 21, 2009 | NetGear WGR614 54Mbps Wireless Router...
Open Questions:
See all NetGear WGT624 Wireless Router Questions
NetGear WGT624 Wireless Router Logo
74 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
