Question about Ovens
Replace element in Westinghouse freestyle oven POH 6885
Seekin info regarding access to the element. Do i need to take the oven out a remove the back or can it be done from front
  • 4 Answers
SOURCE: What wire goes where for my Westinghouse Freestyle elements?
oven wiring has the same conventions as house wiring.
green = earth, outside coating
brown or white = one of core ends
black = the other end
Posted on Jul 14, 2008
mastatech
  • 478 Answers
SOURCE: replace element in top of oven of an f241 candy cooker.
There should be two screws at the inside back of oven. However, once you have the new element look for the holes in the new one
Posted on Mar 20, 2009
mrfixit3667
  • 262 Answers
SOURCE: Oven not igniting and heating
Without the model number I can only give you basic information. If you are refering to the Glow Ignitor located in the center bottom rear of the oven concted to the burner tube, then this Ignitor could be bad and most tech's will change it first.
Even if it is glowing does not mean it is good.
For more detailed information please include as much information as postible and the Make and Model # off the machine.
Always unplug the machine when trying to service it.
Posted on Jan 10, 2010
SOURCE: Westinghouse Freestyle 668 oven not doing anything , just blinkin
Yes I can help.Hold down the buttoms on the far left at the same and then set the time using the + and - buttons.Cheers
Posted on Jan 17, 2010
  • 177 Answers
SOURCE: i need to replace the
pull the unit out of the housing and rest on a suitable work bench. turn off the power and remove the rear cover you will see the grill element, ring element and the bottom element. depending on whcih one has blown they are relatively straight forward to replace.
as for where to purchase one depends on what country and area you live in. best to search for someone local on line
Posted on Aug 19, 2010
How do you change the oven element on a Westinghouse PAJ143W as the element is hidden
To replace Westinghouse PAJ143W oven element you need to look at the back of oven with a torch etc, and you will see the element ends go into the back through clips on each side. At the top of these clips in the middle there is a bit where you get a screwdriver to push down and lever forward and it will come out a bit you do this on both sides. Then lift the clips and element 'both sides'' together and carefully pull forward making sure you're careful with the wiring and pull out a little making sure you stop the wires slipping back while you swap elements. Make sure you put plate at front back in place to keep element up off the bottom, it has two reswts for element on it.
May 20, 2012 | Sharp Ovens
I am trying to install my oven element. I am replacing old one. Oven is Westinghouse Model POL667S
tand pull the elelment out about 3". The element should lead back to a small plate at the back of the onen. Remove the two screwsi at the back of the oven.
Pull the element out about 3" and this will expose the connecting
wires, dissconnect them and remove the element. To install the new one, Just
do the removal procedure from last to first.
Nov 30, 2010 | Ovens
I need to replace the element on my westinghouse freestyle 808 oven . where can i order one how do i change the element? thanx
Aug 19, 2010 | Ovens
I have a Westinghouse 678 freestyle.the element remains on. It may be due to the setting of the clock or timer. i do not have a manual to regulate either as this was not left by the previous owner. could...
I also have the same oven, it turns itself on at random at heats up, also is the oven door easy to remove for cleaning, I dont have a manual either
Jun 29, 2010 | Ovens
Need an instruction manual for Westinghouse freestyle 745 wall oven, preferably in PDF, having trouble setting the clock. Can you help please?
instructions-manuals.com/search.php?...WESTINGHOUSE%20FREESTYLE...FREESTYLE%20920%20DISHWASHER
safemanuals.com/index_upload.php
www.manualsnguides.com/search.php?...WESTINGHOUSE%20FREESTYLE......
You can copy and paste any of the above links in your internet address bar under a new tab to bring you to your manual
Nov 12, 2009 | Ovens
Apr 20, 2009 | Ovens
Element needs replacing
You need to remove the outer rear panel of oven to gain access to heater on this model.
The element is attached to a panel at the rear of oven , which when removed gives you access to the element..
It cann ot be done from inside the oven.
Plz rate my solution.
Thanks.
Jan 24, 2009 | Candy Ovens
Jul 13, 2008 | Ovens
Hotpoint dy46 x oven
Usually with ovens not heating up the element has gone and needs replacing. A few checks to do before going to the expense and trouble of replacing are to check the House Power Box Fuses to make sure none a blown - especially look for the one relating to the Oven or Range. If blown replace the fuse wire. If it blows again you have a problem with the power point or appliance. Does the Oven Fan work? If so chances are the oven is getting power as is the element and your house electrical lines to the Oven are fine and the element needs replacing. Not knowing the particular Brand you have amkes it difficult say how to remove the element. Some elements are accessible from inside the oven - others you have to remove the oven and get access from behind by removing a panel. Whatever you do if you do decide to remove the element MAKE SURE you TURN OFF THE POWER to the Oven. Hope this helps.
Regards
Bryan
Feb 22, 2008 | Hotpoint DY46 Style Line Stainless Steel...
Ovens Logo
46 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
