The display unit it not working but the icebox and freezer are. what do we need to do to fix this
SOURCE: Ice Dispenser Doesn't work...
sounds like the water coming into the icemaker is spilling over or leaking into the ice despenser bucket.... check for ice build up or plugging of water chut into ice maker
SOURCE: Whirlpool side-by-side refrigerator ice dispenser
First pull out the ice bucket and close the door. Set for cubed ice. Press the button for ice to come out and listen for a loud clunk noise. That is the sound of the solenoid. You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down. Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into. If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work. If solenoid is not working then it will need to be replaced. Let me know what you find.
WHAT IS THE PROBLEM WITH YOUR FRIDGE
MOHAMED
SOURCE: Whirlpool Side by Side Refrigerator Wont dispense ice
if you lift out the ice bucket you will see the "gear" that turns the auger. The gear is metal but the part on the bucket is plastic and this can become stripped out. Also check that there is not ice frozen around the bottom of the bucket where an ice cube may have lodged the chute door partially open and melted some of the ice in the bottom creating a blockage.
SOURCE: Refrigerator Ice maker stopped working after power outage
Check THIS out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
