Question about Insignia Digital-to-Analog Converter for Analog TVs
Box was working, tv now back to analog
Hooked up insignia coverter box everything worked great. box is still on everything still hooked up same way - tv sound started to sound full of static then tv went to annalog snow - remote works to turn on and off tv and coverter box but can't get menu up to do anything. Really frustrating!
  • 30 Answers
Sounds like the converter didn't make it. The symptoms you describe sound like the converter was working and then died. You may want to bring it back to store were you got it.
Posted on Jun 21, 2009
Toshiba 20AF42 is the tuner Digital or Analog? Chassis M3K62
This tv is a Analoge tv.Only can be able to used with CABLE,SATALITES or some other pay tv services to able to get a picture.Can't used the alone trying to recieving the DTV free AIR signal,will not work.Only way to get free AIR DTV to work for this tv is.This tv must have a Digital Coverter box hook up.The free AIR broadcasting signal must go through the tv Digital Converter box to be able to watch Free AIR DTV channels broadcasting.
Sep 04, 2011 | Toshiba 20a43 20" TV
I bought a television from a second hand shop, but because theres no manual i cant set it up, its suposed to have built in freeview but we cant work it out
No,all small CRT tube analoge tvs types are getting analoge freeview signal only.U trying to hook this tv up now for for freeview will not work because it are all digital format signal now.Tries websites like Amazon.com,Ebay.com buy a box call Digital Coverter box hook this box betwwen the tv the in incoming freeview AIR broabroast tv signal will able to get a digital signal.Or u must have pay cable or satallite broadcating signal to used a analoge CRT tube tv now.
Jul 28, 2011 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Can't get digital converter box to work with Toshiba TV/VCR Combo
You will need to rescan your stations. On the June cutoff date, they reshuffled and renumbered most of the stations.
Jun 16, 2009 | Insignia Digital-to-Analog Converter for...
Magnavox DTV converter shows no signal
do you have your converter box hooked up to an antenea? If so, if you move the antenea, then you may have to reprogram the channels through the converter box. This happened to us. So, we played around with the antenea until we found the most channels came through and marked the area around the antenea (you can use tape, or if you do not care a permanet marker like us. Note our antenea sits on top of our tv.) We have not had any trouble since. We marked the place for the antenea, in case someone moves it or so we can try to get more channels when the final switch happens. We gain a lot of stations, but lost only one.
Hope this helps,
The Gordons :)
Jan 06, 2009 | Insignia Digital-to-Analog Converter for...
Hooking up converter box when i have a dvd player and direct tv
Hook your Insignia box between your antenna and your television. You still need the antenna.
Jan 01, 2009 | Insignia Digital-to-Analog Converter for...
Need to hook up dvd/vcr combo with converter box
Connect your rabbit ears to the Insignia. Connect the Insignia to the antenna input on the "cvd/vcr combo". Now turn on the television to show the "cvd/vcr combo".
The Insignia simply goes between your antenna and your television. In your case you also have a vcr so if you want the VCR to be able to play and record digital stations you will need the Insignia between the vcr and the antenna.
Dec 28, 2008 | Insignia Digital-to-Analog Converter for...
Hooking actual live coaxial from Cable Co. to Insignia Converter Box ...
Based on the specs that I have read I am going to say you cannot hook up cable to the converter. Best thing to do would be to call cable company that provides service there and see if it was turned off on the billing side they probably just didn't come out and disconnect from the pole. That might give you service but missing some features such as tv guide channel. Now some tv's have tv guide built into them and maybe in the move that feature on the tv was turned off it they were using it that way before. Here is what the specs say about that converter:
Use this digital-to-analog converter to convert digital TV broadcast signals to analog signals on analog TVs with antenna-based reception.
I’m happy to help further over the phone at https://www.6ya.com/expert/brandon_60dfebff379d64bd
Nov 08, 2008 | Insignia Digital-to-Analog Converter for...
No signal
I had a similar problem. I then noticed that my antenna has a RG6 cable. This is good. My TV requires RG6 and requires TV(RF) cable that is also RG6. Insignia comes with a TV(RF) cable that is RG59! That's a cable with a smaller diameter center connector than RG6. Consequently, when that smaller RG59 was run from the converter box to the TV's larger RG6 female connector, no signal connection was completed since the center connector made no physical contact with the TV's female connector. I found a RG6 cable to replace the RG59 cable supplied with converter box and all worked then. Also, you must force the antenna's RG6 male plug into the smaller RG59 female connector, but it'll make it.
May 25, 2008 | Insignia Digital-to-Analog Converter for...
Insignia NS-DXA1 - Digital to Analog converter box
I have had my converter box 5 days now. I hooked it up to the TV and set it up. No Problem. Except there are no instructions on how to set up the VCR/DVD player with it, which we use more than we do watching TV. Everything worked fine until on the second day we had it I read I could program the remote to turn the TV on and off. I followed the instructions and the TV went off. When I turned it back on, my remote went berserk. If I try to change a channel it will quickly flip through all the channels until I turn the converter box off. Same with the volume, it goes up and down, up and down until I shut off the box. The remote does not work unless you are about 1 foot away from the box. And the remote has never turned the TV on or off except that first time I programed it.
May 19, 2008 | Insignia Digital-to-Analog Converter for...
Insignia Digital-to-Analog Converter for Analog TVs Logo
166 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
