Question about Promaster FW26T Featherweight Tripod
3rd shaft lost inside 2nd shaft
The rubber tip fell off a leg and the 3rd section slide back into the 1st/2nd section. Any ideas?
  • 1,522 Answers
Yup.Close all leggs up,tape the other 2 so they don't come out,then shake the tripod like your shaking a thermometer to get the mercury down.That lost leg should slide out easily.Once out,place a small hose clamp on each of the final legs just above the rubber tip and this will NEVER happen again.
Posted on Apr 15, 2014
What is causing transmission to only work in 2nd and 3rd and reverse.? in 2nd and 3rd it feels like its trying to downshift into 1st. In 1st there is a little resistance but it doesnt move
How does your transmission fluid look and smell? If it is dark and smells a little burnt, the transmission is very likely toast. If it is still clear and red, you should let a transmission specialist diagnose it.
Jul 20, 2015 | Cars & Trucks
2003 chevrolet cavalier, manual transmission lost 2nd, 4th and reverse but still has 1st, 3rd and 5th gears.
Sounds like one of the levers inside the transmission is either broken or otherwise disengaged. Remove the shifter to see if you can see any obvious reason.
Aug 25, 2012 | 2003 Chevrolet Cavalier
Ford transmission wines in 1st 2nd 3rd revers, no
It is a 5 speed manual transmission? If it is noisey in all gears except for 4th, then the problem is countershaft bearings.
Apr 16, 2010 | 1995 Ford Aerostar
I having problems with all my gears
if its a manual then you have moved the splined shaft under the car ,just re adjust it ,slacken pinch bolt and look for original marks in the grime to re set it
Jun 11, 2009 | 1997 Volkswagen Jetta
In my 1998 VW golf i lost use of 1st. 2nd. and 5th gear. at the 130000km mark. i think its a linkage problem, is this easy to fix/ cheap to fix?shifter just slides around when in 3rd or 4th as if in...
yes. you have to check the plastic/rubber moulding at the linkages under the hood. maybe one of them is missing (fallen out because of wear)
Mar 21, 2009 | 1999 Volkswagen Golf
Help with puzzle 100 seven squares
first square is the only one that is straight, all the others are at an angle..
1st - top four pins on left hand side
2nd - top row 3rd pin, 3rd row 2nd pin, 4th row 3rd pin (position 4) 2nd row 5th pin
3rd - 1st row 4th pin, 3rd row 1st pin, bottom row 2nd pin, 4th row last pin
4th - 1st row last pin, 2nd row 4th pin, 3rd row 4th pin, 2nd row last pin
5th - 2nd row 3rd pin, 3rd row last pin, bottom row last pin, 5th row 2nd pin
6th - 3rd row 3rd pin, 4th row 2nd pin, 5th row 4th pin, 4th row 3rd pin
7th - 4th row 1st pin, 5th row 1st pin, last row first pin, 5th row 2nd pin.
hope this makes sense!!
Dec 28, 2008 | Nintendo Professor Layton & the Curious...
Cant solve puzzle 100 in professor layton cant go on im desperate
Dec 06, 2008 | Nintendo Professor Layton & the Curious...
3rd gear spends at 1st gear speed with clicking noise
A key is most likley sheared on the center shaft.Take the gears off the center shaft.
Oct 15, 2008 | Hobart A200 Stand Mixer
Hyperlinks in PowerPoint
it is because the compatible MS Office for windows vista is MS Office 2007. if you got a lower version, it is doesn't really work. try to get the latest version of MS Office.
Feb 26, 2008 | Microsoft Windows Vista Ultimate Edition
Promaster FW26T Featherweight Tripod Logo
78 people viewed this question
Top Promaster Photography Experts
Tom Chichester
Rigger
Tony Parsons
Tony Parsons
Are you a Promaster Photography Expert? Answer questions, earn points and help others
