Question about Videosecu Q See Platinum Series 8 Camera Network Video Recorder Nvr 1 Tb Drive Qc808 1
Blinking blue light
Blue light blinks sometime
My HBS-900 headsets have a blinking red and blue light that blinks when it's on and off, it won't pair with anything, and when I put it on charge it blinks red and blue
Usually this means there may be too many Bluetooth devices in range to connect to and cannot connect so the blue and red flashing lights indicate an error. A second possibility is that the device is broken. This might sound strange but sometimes several sharp firm raps to the side with the charger port and lights along with a few power cycles often snaps it out of error and back into operation. Good luck.
Dec 28, 2016 | Radio Communications
I have a 42 inch philips lcd tv and it will not turn on. Tried unplugging it for 60 seconds and only the light will blink red sometimes and then blue sometimes. Do I change out the power source
Number of TV have a bad batch of capacitors on the power board. If you look like split mushrooms that is a bad sign. But there are kits if you know how to solder.
Oct 25, 2015 | Philips 42PFL7403D/F7 42-Inch 1920 x 1080p...
Fisher tv f32fd01 stuck in stanby mode bliue flashing light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Sep 12, 2015 | Televison & Video
Power light blinks blue
Sometimes this kind of behavior indicates that the TV needs to be reset. Unplugging it overnight should cause a reset. Often the underlying problem returns, however. Good luck!
Jul 30, 2014 | Element Electronics Televison & Video
Why is a blue light blinking on my HP TouchSmart 600-1120 Desktop PC?
If it is in the tray, right-click it, and you can probably see what it is.
Jul 02, 2014 | HP TouchSmart 600-1120 All-in-One PC Black
Screen fluctuate/blinks when press left side keypad's buttons
u know ur phone emi number and send it 2 my sum1kewl_2009@yahoo.com
Apr 12, 2009 | Sony Ericsson K850i Mobile Phone
Olevia TV problem.
If you wish to get some details; visit the site linked here. Pull up older posts.
Apr 10, 2017 | Televison & Video
Blinking blue light
the only blue light that i know blinks is the Kmart blue light special .. we need model of things you're working with to properly diagnose.
is it external drive ? with a blue light blinking ? is it connected in usb ? sounds like if its external drive with blinking light could be bad hard disk or bad controller card inside that translates ide to usb.
Jul 29, 2008 | Computers & Internet
Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Dec 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Videosecu Q See Platinum Series 8 Camera Network Video Recorder Nvr 1 Tb Drive Qc808 1 Logo
83 people viewed this question
Top Videosecu Home Security Experts
Lawrence Oravetz
Are you a Videosecu Home Security Expert? Answer questions, earn points and help others
