Question about Panasonic SC-HT500 System
Speaker wiring which speaker leads go to which conection on back
  • 1,388 Answers
Red to Plus(+) black to Ground(-).That's universal.
Posted on Apr 15, 2014
If speakers of 10" tablet blow who will fix it and how much does that type of repair cost ?
it depends from speaker used in tablet..if it is from china market the speaker cost max 5$..you can replace the speaker it is conected with wires just cut the wires and conect the wires from new speaker..you can find the speaker on ebay
Feb 26, 2015 | Tablets & eReaders
I need to know what wires are what in my dash for my radio in my 2000 grand prix please nothing is labeled like it should be for example it says red wire is accessory I dont have a red wire the closest...
first things first check your fuses and i mean all of them replace all that are bad with proper fuse amprages
you are going to have to do some probing of those wires to find the ones you need you can buy a voltmeter(25$ or less) or a simple test light(2-5$) from a local automotive store
colors to look for are
primary power wires :red,yellow, black for ground
accsesory wire from igntion ,orange or blue with wite stripe and posibly pink(rare)
any wire that has an on and off state from the turn key igntion can be used depending on its gauge/size test the orange one first as this is the most common color to use for the accsesories wire
to test you have the igntion in the on postion if you get a readying of +12 volt and then turn the igntion of and recive a reading of 0 volts this would be an on off wire
note: check the auxsilary postion of the turn key igntion also if there is no power to the wire in the auxzilary postion it is the incorect wire for the radio
BLACK> should be a ground wire
RED>should be an igntion supply wire of a larger diameter
YELLOW> should be a battery supply lead strait from the fuse box battery conection "always on"connect the wire of the stereo labeld battery to the always on battery lead ,this is for the memory function of the radio
ORANGE>(may be pink only seen pink in buick's) should be an on/off wire from the igntion and used for the main power of the radio so it is shut of when the car is turnt of this is also the wire you would hook the amplifyer on off up to if the radio dont supply the blue wire with white stripe aka ant/motor
test the on off state of the wire befor conecting it to the radio
you will conect the red (+ positive) wire to this on/off state wire
cation! disconect the batery ground wire when conecting anything to the main yellow battery wire as it is directly conected thru an exspensive(12$) 30 amp fuse
if you dont know what wires are what for the speakers in the car use a 9 volt batery to find the speaker wire leads (ues a brand new 9 volt)
ntsc standard color pairs are
white and grey front
green & brown for back
i dont remeber the left and right
the black stripe on the speaker leads means the ground or negative side of the speaker
good luck instaling your new radio hope i have helped you out
Feb 24, 2010 | 2000 Pontiac Grand Prix
HELLOOOOOO HOW CAN CONECT MY SUBWOOFER
Your problem is quite simple. The low input is for feeding a lead straight from the output of your receiver IE sub out and the high input is for connecting the sub directly to your speaker output where the alternative is not possible. Hope this helps
Jul 15, 2009 | Wave Audio CS801 Speaker
One of my turntables only has sound coming out of left speaker..
one of your phono leads ether red or white is nakered.plug them in one at a time and see witch ones workin,then youll no the dodgy one.when you pull out leads from your mixer you can sometimes break cables free from the fittings if pulled by the wire.you wanna re soilder a new lead on to deck or pull back the sheath plastic covering the fitting and reconnect the cables(the insulated wire goes to the pin an the uninsulated goes to outside ring)gd luck
Jun 13, 2009 | Technics SL-1210 Turntable
My speaker system only works sporadically
there are a few things that it could be. ok simplest thing is the ground wire yes it has a constant conection but not a good enough conection it has happened to me before. the worst its a problem internaly that is common eather a loose conection on the output serkit also try to push the wires in on the clip on the back. hope this helps you can go to a junk yard and get a replacement or aftermarket.
Jun 02, 2009 | 1996 Honda Accord
When i turn my radio on my sub makes sounds and backfeeds even when the engine is off. i tried switching the remote wire from my radio to different wires but it either doesn't work or still makes the...
Hi It will be an earth problem or even if your speaker wires or rca leads are running along side any power wires from your car, Find the most chunky metal part of your dash, clear all paint away, make the earth wire from your head unit less than 1 foot from you head unit and make sure its not conected to any earth that run back to your cars power system. if it still makes the noise make sure your speaker wires or rca leads are not running along the cars power wire they will pick up feed from them. make sure your head unit is not earthed to your cars arial silly as it sounds the arial plug in is one of your main earths to your cars audio system. hope you work it out
May 06, 2009 | Car Audio & Video
Need to find which is the ground wire for the speakers from aiwa cx-naj14
The ground wire is the one with either the stripe, running the length of same, or the black wire, or the grey
wire or the green wire or whichever of many coding systems in use on your speaker leads and always
designated on the back of the speaker as the (-) negative lead and on the back of the unit, if using RCA
PLUGS as the body, not the tip of the lead.
Apr 17, 2009 | Aiwa Audio Players & Recorders
Wiring car amp up
the rem wire is for switched power from your head unit usually most after market stereos(head units) have an output for the rem wire.......if not use the power antenna wire from the back of the radio (usually blue or blue white) as for the input you need to use one or the other low or phono
Hope this helps..Good Luck!
Dec 13, 2008 | Car Audio & Video
Conection
Find the Audio card of you computer. Mostly audio card jack had label line out or audio. Also audio out jack was light green in color.
Jun 17, 2008 | Boka 81000 Computer Speakers
JVC THP7
you need an optical lead, connect the optical lead from the back of the ps3 and connect it into the dvd players optical in.
I am looking at this one too but dont know whether it has an optical in, could you let me know on, mathewsellar@hotmail.com
thanks bud
May 04, 2007 | JVC SX-XD33 Speaker
Panasonic SC-HT500 System Logo
23 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
