Fan inside air conditioner won't turn on
I hav a Payne Air Conditioner - 4 yrs old- and the fan inside of the unit won't turn on. It's already 82 inside my house and w/ 2 small children I need some help. I can't find a company that can get here soon.
    New Friend:
Mine was the calculator box was bad cost me about 15 bucks for another, because i had the same problem, my air would come on but the fan wouldn't turn. Or their is a wire loose, or dirt inside of it. hope this helps.. and i do know if you run it and the fan won't turn you can burn up the motor, which can cost a few hundred to fix.
Posted on May 24, 2013
  • PAULA CALLOWAY May 24, 2013
    it is the calculator box, mine did the same thing and it cost me 15 bucks to replace, also make sure there is nothing stuck in there or loose wire. hope this helps. don't run the ac if the fan won't turn you will burn it up and that will cost a few hundred to fix.
    A good friend of mine put my calculator box on that's why it only cost me the part.
  • 4 Answers
There are many problems it could be. first off check the breaker box to make sure hasn't tripped. call 254-722-1891 for Dallas area A/C service.
Posted on Jun 18, 2009
Payne Air conditioner and heater Fan won"t turn off
The fan relay is stuck. It needs to be replaced
Nov 28, 2016 | Heating & Cooling
Payne 561cj030-a
New fan motor should have a new capacitor (look on the motor for the mf number and use capacitor that size) .If changing the capacitor fixes it save the old motor, it's still good
Jun 26, 2014 | Bryant 463AAC008BA Air Conditioner
Air conditioner blowing warm inside and cold outside
it's a heat pump in the heat position . Check the thermostat to see if it's in the heat position. If not then the changeover valve on the unit is stuck.
Feb 08, 2013 | Carrier Payne 2.5 Ton Air Conditioner...
Hitachi RAS-09UH Air Conditioner won't turn on
If you can access the pcb inside, check the mini glass fuse
May 18, 2012 | Hitachi RAS-09UH Air Conditioner
My 4 year old Ruud home a/c compressor stopped working. inside fan blows but compressor won't turn on...what can I do prior to calling the gas company who installed the unit...
Ruud parts warranty from factory is 5 years, the capacitor has possible gone out, it will be in the contol compartment on the out side unit and is a dual run capacitor that controls the compressor and fan motor. Recommend if capacitor is bad to replace entire capacitor. As Stated above the parts are under warranty if under five years old. To verify age the date code is in the serial number after the "F" **** week/year of manufacture. Also outside unit has independent power supply so check fuses if any and circuit breaker.
Aug 21, 2011 | Ruud UBHC Air Conditioner
Ihave a fujitsu air conditioner model asta18lcc about 2 yrs old when I turn it on fan works but room wont get cold or hot,red operation light does not stay on but green timer light flashes on. thanks...
The lights on the front panel indicate fault codes dependent on the amount & intervals of the flashes. Fujitsu units carry a 5 year warranty so check with your local Fujitsu store for the agent in your area.
Aug 13, 2010 | Fujitsu 24C1 Air Conditioner
Fan wobbles on coleman MACH3
What is the model number of your current air conditioner? You will usually have to remove the upper shroud, evaporator housing and condenser housing to get all of this out. With that removed, the fan motor should have three or four studs holding it to the plate. Remove the screws from the plate and the whole assembly will lift out.
May 27, 2009 | Coleman Mach III Air Conditioner
Air conditioner blows warm air
Try to check its air filter for dust or check its evaporator for accumulated dirt and its exchanger first. Or if this is an old set try to check if it is not set to heater mode.
Jun 28, 2008 | Goldstar WG5200ER Air Conditioner
Heating & Cooling Logo
590 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
