Question about Ricoh Office Equipment & Supplies
Lanier mp3350 exposure lamp is damage how to change
  • Ricoh Expert
  • 393 Answers
Service call, call your vendor.
Posted on Apr 18, 2014
2 Suggested Answers
santosj27
  • 263 Answers
SOURCE: Funtional code SC101-00 appears on Lanier 5245
Hello!
There you are. You asked the question but you already know the answer.
The exposure lamp are burned so... this error code appears in the display.
You need to change the exposure lamp
Posted on Sep 10, 2011
Funtional code SC101-00 appears on Lanier 5245 copier when turned on. Exposure lamp is burning.
Hello!
Sep 10, 2011 | Ricoh Aficio 450 Copier
Paper is solid black when trying to copy
make sure the top lamp lights when you press the print key if the lamp does not come on check the lamp harnes, the fuse, the lamp and the exposure board replace if either is faulty
Mar 01, 2011 | Lanier Office Equipment & Supplies
Lanier 6514 copier, copies are coming out all black....
exposure lamp open circuit replace or lamp regulator faulty also check thermo fuse 1st thing to check change auto exposure to manual this will tell you if regulator is faulty or not
Oct 21, 2010 | Lanier 1205 Copier
Paper is coming out pure black from the copier
Check thr exposure lamp and exposure lamp thermistor.If it damage change.
Aug 16, 2010 | Ricoh Office Equipment & Supplies
Lanier 5245 scanner light does not come on
Could be the exposure lamp or the lamp control board. You will need a service call or find some place to buy used parts and just swap them out.
Dec 14, 2009 | Lanier 5235 Printer
Prints paper all black
Your problem in the exposure lamp unit.Check the expo lamp,expo thermofuse continuity,and perform the Auto Image Density Sensor control proces after the clean the mirrors and the glass.
Oct 08, 2009 | Lanier 1205 Copier
Error SC101 on copier
No, you can't reset. You'll need a tech. Here's what the manual says: Symptom (SC101) - Exposure lamp error - The standard white level was not detected properly when scanning the white plate. Possible Cause: ? Exposure lamp defective ? Lamp stabilizer defective ? Exposure lamp connector defective ? Standard white plate dirty ? Scanner mirror or scanner lens out of position or dirty ? SBU defective
Jun 10, 2009 | Lanier Office Equipment & Supplies
Minolta copier EP 2030 error code C 04
No, in stand-by the exposure lamp should not switch on. What comes on in regular intervals is the heating lamp inside the fusing roler which can be seen from the exit side of the copies. The exposure lamp is under the glass and only comes on and print button is pressed and copy process begins.
GOOD LUCK.
Nov 04, 2008 | Office Equipment & Supplies
Error code Sc101
SC101 can be caused by a dirty WHITE LEADING EDGE STRIP. This is located under the left side plastic strip that holds down the exposure glass on the left side. Remove the screws, and flip over the glass holder. Clean the white strip with glass cleaner, and reassemble. If SC101 reappears, the scanner drive pulley screws are loose or broken off. A service technician is required for this repair.
Feb 20, 2008 | Lanier 1205 Copier
18 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
