Question about Rival SCV702 Slow Cooker
Won't turn on
Worked the last time but this time I plugged it in but no light, no heat. wall socket is ok.
Sounds like something's burned out. Unless you feel qualified to take it apart yourself and see if you can spot a problem like a blown fuse or a separated wire...I'd say it's time to replace it.
Posted on Apr 15, 2014
  • charles chandler Nov 12, 2014
    Well Mac brain this is where you come to get it repaired not an intellegent answer replace it.
    Master:
  • 530 Answers
There is a small part that looks like a bullet coned on one end. this is a thermal fuse. they go bad from time to time and need to be replaced. there is a number on them and mouser electronics has them.
Posted on Nov 12, 2014
When I plug in my pressure cooker in any working outlet the pressure cooker does not light up or turn on.
When the house breaker pops, that usually indicates a shorted heat element. The electronics inside may have a protection fuse on the board that blew too. Look at your warranty card for instructions on returning it for repair if the warranty is still in force.
Mar 20, 2017 | Crock Pots & Slow Cookers
Is there a way to set high with more than 6 hours ? I need to set mine for 20 hours in high.
Not unless there is a delay setting on the machine. You could get a timer plug to put into the wall socket. The type you use to ste lights to come on and off when away from home.
Dec 18, 2010 | Oster 7664-33 6-Quart Slow Cooker
Rival crock pot model number 38501. i dropped the outter part of my crock pot outside on concrete. when i plug it in the light turns on but when pressing the buttons light doesnt move and unit wont heat....
Nope! I guess not
What has happened I supsect is that the element has separated by the fall when you turn it updide down it makes contact to complete the circuit.
I am also of the opinion that this element is not replaceable so I think you are going to have to bite the bullet and buy a new one
Please rate my help++++Thanks for using FIXYA
May 19, 2010 | Rival 38501 Smart Pot 5-Quart
How do I start the cooker on low?
The manual says "When your corningware slow cooker is initially plugged into a wall outlet, the display will show"0". This display indicates the programmed number of hours for which a meal will cook.
The slow cooker can be programmed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears.
If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on HIGH setting. If 7,8,9 or 10 hours are selected, then the slow cooker will operate on the low setting.
To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
When the full cooking cycle is complete, your corningware slow cooker will automatically switch to the warm setting, to keep food at a warm serving temperature."
If, after you plug the slow cooker into the outlet, the COOK TIME button does not work, unplug the cooker, hold both ON/OFF and COOK TIME buttons down, plug into wall socket and wait till the display flashes. Release both buttons and the slow cooker buttons should both work.
Dec 18, 2009 | CorningWare SC60 Slow Cooker
Can't change temperature-stays on "warm"
Push the COOK TIME button, if the time changes then if you leave the number of hours between 1 and 6, and press the ON/OFF button, it will cook on high that many hours. If you leave the number between 7 and 10, and press the ON/OFF button, it will cook on low that many hours. If you leave the number at "0" then the slow cooker will cook on WARM. If the COOK TIME button does not work, unplug the slow cooker, hold both the ON/OFF button and the COOK TIME buttons down and plug it into a wall socket. After the lights flash a few times, release the buttons. the switches should work.
May 19, 2009 | CorningWare SC60 Slow Cooker
Slow cooker turns on but doesn't cook
sounds daft but try changing the fuse in the plug. if this not the case could be the element and time for a new one!
Jun 26, 2008 | Crock Pots & Slow Cookers
It wont heat up and all the lights just keep blinking
I have the same problem EVERY time I want to use the crock pot. My solution has be patience. I find that if I turn it on, and the light blinks, but when i click it it will blink on 4 hours, then go back to the blinking light. By keeping the crock pot plugged in and off for about 10-15 minutes I was then able to set the crockpot up for cooking. As if the capacitors inside the unit needed power stored in them from the wall.
Dec 21, 2007 | Rival 5865-W 6.5-Quart Slow Cooker
When I turn it on I get E01
  1. The thermostat may temporarily lose calibration due to temperature changes resulting in an E01 error message on the display. Repeat the following steps to reset the unit.
  2. 1. Unplug the unit from the wall socket for approximately 10 seconds.
  3. 2. Plug the unit back into the wall socket.
  4. 3. Press the POWER button once. Within one second, press the COOK button once. The unit should now be rese
Dec 19, 2007 | West Bend 84496 6-Quart Slow Cooker
WEST BEND SLOW COOKER
Dec 03, 2007 | West Bend 84496 6-Quart Slow Cooker
Displays E 01
Talked to the nice lady at West Bend. Apparently, the problem comes up when the unit is "cold"... whatever that means. She said to plug it in, wait a second, then push the power button, then "cook" immediately. No pause. Don't hold either button. I tried it, it worked on mine.
Apparently, this a feature for some reason.
May 17, 2007 | West Bend 85146 6-Quart
Rival SCV702 Slow Cooker Logo
168 people viewed this question
Top Rival Crock Pots & Slow Cookers Experts
Jerry Greenberg
Jerry Greenberg
charles
Irene Tulloch
Are you a Rival Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
