Question about Garden
Differential problem? driving along sounds like the rear end differential is out of oil....is there a place to oil there. Noise is only there in drive not reverse.
  • Garden Master
  • 2,478 Answers
What model?
Posted on Apr 15, 2014
  • 1,522 Answers
If your speaking of hydrostatic drive,not clutch type,after a lot of use this "sound"becomes a normality.The drive motor(hydraulic)is worn.Mine does the same thing,on all thre of my mowers.I don't concern myself with it.Even my drive motors on my Toyota skidsteer make that same noise.But I know they're ok.Just keep changing the filter on the hydraulics every 100 hours or less.If it doesn't bother operation,just you,then i don't believe anything is really bad wrong.As time goes on,with use,things wear.BUT,they're finding there position is all.Their worn into place.You rarely use reverse,thats why it don't make noise in reverse.But if it bothers you that bad,replace the drive motor everytime it starts making that noise,or replace the mower.
2001 f150 jerks really hard when turning
You probably have a limited slip differential. Sounds like the clutch plates in the differential are sticking when you turn corners. I would change the gear oil and add limited slip diferential addative to the diff along with fresh gear oil. If limited slip this will cure your problem.
Sep 03, 2017 | Cars & Trucks
1989 Suzuki Sidekick rear differentials
GET IT TO A MECHANIC!! Something is loose or about to collapse! Remember that vibration and noise can travel away from the source so get the mechanic to start in that corner.
You need to get the following checked!
-Prop shaft mountings at transfer box.
-Prop shaft mountings at differential.
-Prop shaft bearings.
-Differential condition and oil level.
-Drive shafts at differential end.
-Drive shafts at the wheel end.
-All flexing joints in the system including UV joints and CV joints.
Feb 04, 2018 | Suzuki Sidekick Cars & Trucks
I have noticed a clunk type noise/feel in the rear end after taking off from a stop. Tonight a really bad grinding/clunking sound both in drive and reverse, ion gear or neutral. I've been reading...
if the diff is not leaking oil there should be no reason to be low. If you hear a noise in neutral with the truck not moving, its not in the rear end. it may be the trans or transfer case.
Sep 01, 2011 | 1999 Chevrolet Silverado 2500
The problem sounds and looks like its in my rear end when i turn left or right my rear end acks like its locked in and my rear tire sqeel but when im driving foward or back it dont act up. it only does...
Sounds like you have a limited slip or " Posi-Traction" rear differential, if this is the case than go to the GM dealer and ask them for a bottle of friction modifier oil for limited slip differential. This stuff is pure whale oil that helps to lubricate the clutches in the differential. After adding the lube find your self a big empty parking lot or other paved surface and drive the vehicle forwards then backwards in a slow figure 8 patern, turn as tight as you can each way, this will force the clutches to work and help limber them up. The differential might make some crunching sounds, but the noise should quit as the lube gets in and does its job.
Apr 14, 2010 | 2004 Chevrolet TrailBlazer
Rear end noise on 2002 Dodge ram 1500
If you have a positraction differential, you need posi additive along with the new lube. After it's in, take it to a parking lot and make tight left turns then tight right turns to get the lube between the posi plates. That usually frees it up unless there is an actual mechanical problem in the diff.
good luck!
Apr 03, 2010 | 2006 Dodge Ram 2500
My rear end is making a whining noise as I drive
check gear oil and pray the bearing ant mess up because it sound like you fried the bearrings
Jan 26, 2010 | 2005 Ford F-150
Clanging noise rear and rear don't pull
The axle probably lost a keeper ring on the inside of the differential and the pieces may be going through the differential and ring&pinion gearing making the noises you hear. You will need to drain the oil out, find the broken pieces, and inspect all gearing for broken/damaged teeth, and for any noisy bearings. Flush the case out with cleaning solvent. Re-insert the loose axle after cleaning and inspecting it well--especially the interior end. Replace the keeper (new) on the axle end inside the differential spider gearing. Inspect the brakes on the loose axle side for any oil deposits and for any damage that might have been caused when the axle came out. If the differential is badly damaged, it might be cheaper to find another rear end in a wrecking yard. Hope this helps!
Dec 26, 2009 | 1997 GMC Suburban
Rear direrintial
The rear diff. turns the rear wheels. It is located in the middle of the rear axle. It won't last long if you ignore it. May just need dearing's but if it is driven the cog wheels will grind to dust or drop off this can cause the rear axle to seize up and can be a danger because the back wheels will lock up. If you are going to fix it yourself let me know and I will be able to guide you through the process
Aug 10, 2009 | Chevrolet Silverado 2500 Cars & Trucks
Rear end noise when i let off the throttle
Check the U joints, there more common to go bad then the differential, unless you are low on differential fluids. You can take it to a drive line shop and have them replace the u joints and differential fluid and also have them readjust the ring and pin in the differential to give you more life out of the rear end. Good luck and keep me posted. Be glad to answer any questions you may have.
Aug 08, 2009 | 2004 Dodge Ram 1500
Noise coming from rear hub after replacing various fluids
did u use honda fluid and honda friction modifier if not diff will make funny noises worse when turning at a slower pace
Dec 16, 2008 | 2003 Honda Pilot
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
