Question about Garden
Oase sp310g is impeller replacement easy?
  • 1,171 Answers
Yes.Get the new impeller,take the unit apart,remove the impeller and put the new one on.Just do it.You never know tilya find out.Only way to find out is to just DO IT.
Posted on Apr 15, 2014
When I switch my oase pond vac on it switches off immediatly
Sounds like a ground fault or polarity issue with the connection. Check your wiring with the circuit breaker 'Off" and verify it's "off" using an electrician's screwdriver. This will also tell you when you put the power "on" whether the polarity is correct.. red is positive, black is negative, and as always, Green wire is ground.
Apr 24, 2015 | Oase Garden
Replace Impeller How
First we need to know what motor you have. The replacement should be fairly easy. You can find replacement impellers on iboats.com.
Apr 25, 2013 | Boating
Hi got oase filter and everything just stopped working including the pump please could you give me some advice on what it could be thank you
It could be no power, bad wires, bad controller, bad switch, bad pump. You may have something as simple as a tripped Ground Fault Circuit Interupter (GFCI) breaker or receptacle. That is what I would check first. If you reset it and it trips as soon as you turn on the pump switch then you have a ground fault in the pump. I hope this helps.
Aug 30, 2011 | Oase BioTec 10.1 Filter
How do i replace the gasket 2hp
better to just replace whole pump motor will start to squeal soon after
Jun 02, 2010 | Waterway 5 Hp 230 Volt 2 Speed Side...
Water from weep hole under water pump housing. its not the housing gasket. i think its a seal behind the impeler is this a comon problem on the o6 is it easy to fix
hi,you are quite correct,it will be the seal behind the impellor,kawasaki and suzuki are famous for it,simply undo the nut holding the impeller on,remove the impeller,you will have to pry the seal out,when replacing the seal use a "loctite type"sealing compound to reseat the seal,hope thjis helps...cheers
Apr 03, 2010 | 2006 kawasaki KX 450 F
Wash impeller wont rotate on fisher paykel model 603
I suppose you have a double drawer dishwasher and this problem is with one of the drawers.
One cause of the impeller not rotating would be that there is some loose cutlerry lodged between the impeller arm and the base rack. This is easy just remove it.
HOwever, the other option is that the impeller itself is stuck. Try opening the filter base plate and removing the impeller rotor to check if no debris is lying around (usually food scraps).
The instructions to open the filter plate and exposing the impeller is in the user guide. If cleaning does not help then check nothing is stuck in the filter sump and the narrow passage connecting filter sump and the rotor cavity which is preventing the rotor from rotating.
The worst case scenario is the impeller rotor is faulty. You can buy this and replace yourself , ie, if you worked out how to remove it.
Good luck
Nov 17, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
MY OASE PUMP SEEMS TO BE LOW ON POWER, IT PUMPS WATER BUT NOT ENOUGH TO GET TO THE FILTRATION TANK
Check to be sure that the impeller is not clogged in the center of the fins.
Sep 09, 2009 | Garden
OASE fountain pump fluctuates height every other day.
No there is not 2 speeds. That model is asychronous so power fluctuations can affect pumping. How clean is the plug end and how dry is the receptacle? Is there is chance a extension cord is used [code violation almost everywhere] in this hookup? Perhaps it's just debris circulation and restricting intake?
Jun 21, 2009 | Little Giant Submersible Fountain Pump
Mercury 20Hp impeller/water pump location
It is located inside the lower unit housing. They are fairly easy to replace. Most Mercury authorized service stations will charge around $120 for this task.
Triton72
Mar 26, 2009 | Sport & Outdoor - Others
LG Model LD-05AW2 All motors checked and running, Machine goes through a cycle but main pump not spraying.
Impellers in these often break, will need new pump for easy fix or you could try & replace the impeller
Sep 03, 2008 | LG Dishwashers
Garden Logo
215 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
