Question about Sewing Machines
Setting the tension for a 3 thread wide serger stitch
Sergering with knits. what tension do I use
    Problem Solver:
  • 15 Answers
The tension depends on the thickness of the knits. Have you checked with the manufacturer about this problem? Check their website too, you may find the answer there. I wish I could help more. Good Luck!
Posted on Apr 17, 2014
  • 185 Answers
SOURCE: tension factory settings for Baby Lock serger Model BL400
The factory settings are 4, 4, 4, 4, and width at M. Hope this helps.
Posted on Mar 04, 2008
  • 15 Answers
SOURCE: I have a white superlock 228 jaguar serger problems with right needle
Couple of things I could think of: tension disks need cleaning, there is a site that tells how to clean them, maybe 2 as I recall. Other thing is it is a much older serger, (I have one I am slowly working on to bring up to working level), so it could be that a tension spring internally has lost its tension. It might need a trip to the repair man if that is the case. Another thing is are you using correct needles for the machine? Have you changed them recently? Even new needles can be bad, so if you have to change three times to triple check it can be worth it.
Posted on Sep 09, 2008
SOURCE: my white speedylock serger 1634 thread keeps getting in knots
i have the book and it says thread from inside out, inside looper (upper) then lower, then thread the needles, first right then left.  I have found that it does not matter if you thread the needles or loopers first but that you should try to thread from inside to out.
Posted on Feb 25, 2009
SOURCE: Baby Lock Serger Thread keeps breaking
Mmmm...., maybe NOT the solution, maybe, just a key.
I have a copy of theBaby LKock EA-605 instruction booklet in English, Germann, French and Spanish. NO ideas how it casme into my orbit, but happy to pass it on.
Posted on Mar 06, 2009
SOURCE: I am having problems threading my serger,Brother 920D one of
I have a Brother 920 D I got it fixed Thank you
Posted on Nov 26, 2009
How do I get a balanced tension with my Elna 624 overlocker?
The best way is to thread with 4 separate colors of thread and then studying the stitch result. With the 4 colors, you can easily tell which thread tension is "off" and whether it should be tightened or loosened. However, a serger is not like a sewing machine where you can set the tension and use that setting for most projects. With a serger, a change in one or a couple of thread tensions will create a totally different stitch.
For most machines, there is a mark at the midway point on each tension control that is the "optimal" tension for a 4-thread overlock. HOWEVER, every machine differs, so these settings may need to be tweaked.
Make It Handmade Perfecting Serger Overlocker Tension
The Anatomy of The Best Serger Tension My Tips Bonus Unpick it Serger...
How to Adjust Thread Tension on an Overlocker Singer Australia
Different Serger Stitches and How to Use Them
You may want to download the serger workbooks at this site (Bernina), and work through each of the stitches. Make notes in the workbook as to how you have set up your machine to get the best of each stitch. This will be a great reference manual for many years.
Bernina Mastery Workbooks
Feb 23, 2017 | Elna Sewing Machines
How do I get the correct tension on my Elna 792D 4 thread overlocker?
ALWAYS Raise the presser foot when threading the machine. Give each thread and extra little tug when threading the tension disks so it seats completely. The midway point on the tension disk is the standard factory setting when using the standard thread weight, however, with use, age, and thread weight that setting may change. So, the user can use the midway point as a starting point for the basic overlock stitch but will need to make adjustments to get the correct tension. When testing your tension, it works best to use the 4 thread colors so it is easier to identify which thread is misbehaving. When you become familiar with your machine and how the stitch looks, it is easier to identify which thread is which.
Solving Serger Dilemmas
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=7&ved=0ahUKEwjjhv6Uw4PSAhXJrVQKHQrmCtgQFghBMAY&url=https%3A%2F%2Fwww.bernina.com%2Fen-NZ%2FExperience-NZ%2FSewing%2FSerger-projects%2FUSA-nz%2FSewing-Embroidery-nz%2FTensionHeadaches%2FBERNINA-Serger-StopTensionHeadaches-nz.pdf&usg=AFQjCNEAPID5FKBVa_amKfVmrTKgadlmRw&cad=rja
Remember that the tension settings will also determine the stitch you are trying to create. A basic overlock will generally have the tension set around the midway point, however, when changing to a rolled edge or some other stitch, certain tensions will be increased or decreased in order to create that particular stitch.
Feb 09, 2017 | Elna Sewing Machines
Can serger for about 3 inches on my brother 1354d serger and then thread breaks
Serger thread breaks
1. Is the serger threaded correctly?
2. Is the needles inserted correctly?
3. Is one of the needles bent or damaged?
4. Is the tension adjusted too tightly?
5. Is the tension adjusted to accommodate thickness of thread being used?
6. Are you using inferior quality thread?
7. Is the thread feeding of the cone/spool freely?
8. Is the needle size correct for the type of fabric being used?
9. Are the needles being used the correct one for the serger?
Jan 01, 2013 | Sewing Machines
Correct settings for 804dsp serger to sew a sweater.
Are you wanting to use the serger to sew a hand knitted sweater together? or do you mean a sweat shirt knit or other knit fabric. If it is the first option, I'd say don't bother, as you can't do it with the blades working because it will cut your knitting and the wool will unravel in the seams.
If it is the second option then I would start with the following settings.
Four thread stitch, so both needles and the upper and lower loopers threaded. Set tension on all four dials to 5, stitch length to between 2 and 3, and differential on zero. Move the cutting blade over to the right for a wider seam. Now test stitch on some fabric scraps double layer and see what the seam is looking like.
Now you want to adjust a couple of things: firstly width of the seam. Is it the size you want? If you'd like it a little narrower, then adjust the cutting blade back a little to the left to narrow the seam slightly - just depends on the fabric weight. For example if it is a loose open weave like boucle you would want a wide seam to make sure it holds the fibres fully.
Now you can adjust the upper and lower loopers to get the thread wrapping around the edge looking nice. Look at the seam and the fabric inside it. Is it tunnelling and pulling up the fabric? if so, release tension on both loopers a half number to put more thread into the seam. Test stitch again and see if the loopers are meeting nicely on the cut edge of the fabric. Upper and lower looper threads should be meeting right on the cut edge so if this isn't happening and one showing on the other side, then tighten the looser one by half a number and test again.
If the threads are hanging off the edge then you have the choice of moving the blade to the right to cut less fabric off, or tightening up the looper tensions to pull in the thread.
That's it, hope this helps you to master your serger.
If you'd like some images and further explanations of other stitching you can do with your overlocker, then Debbie Coswell has some great information on line at www.sewing.about.com, just search "overlocker" to find the specific pages.
Good luck
Oct 11, 2011 | Simplicity Serge Pro SW432 Mechanical...
When sewing with the brother serger 1034d, loops of thread stick out beyond the fabric-it is not nice and close like it's supposed to be. the settings from left to right are: 4,4,3,3. this is what my...
Can you wind the lower cutting blade to the right to cut less fabric and therefore fill out the stitching? On most sergers the lower blade position can be adjusted sometimes with a little knob or dial. You need to raise the top blade out of the way first, usually you put pressure onto it to release the spring holding it up against the lower blade, then swing it up to do this. Then wind the adjustment on the lower blade and move it to the right to cut less fabric then test serge. Your manual should give you more specific information on this and should be your first 'go to".
I would adjust my looper tensions to suit the fabric and width of the stitch I'm trying to achieve so yes, the settings you've been given are average tensions but its okay to vary these too. From left to right, I'd set 4, 4, 4, 4 and test serge again and see if this pulls the looper threads in against the fabric if moving the blade hasn't tightened up the stitching.
Sergers are more variable than a straight stitch sewing machine so its okay to move tension knobs a bit, just turn each a half number each time you adjust, then test serge and look at the stitch formation. Your needles tension should be fine at 4, leave them alone.
I'd suggest if you can find one, go to a "Getting to know your serger" type class as there is lots of techniques such as seaming on a curve, turning right angles, both inside and outside and making rolled hem edges that are very helpful serger skills to learn along with making adjustments and troubleshooting. Or go to you-tube and search some of these techniques for videos. Also www.sewing.about.com is a great sewing resource and Debbie has pages on sergers/overlockers here too.
When I'm starting a new dressmaking project I will spend 10 mins on the overlocker/serger, changing the thread colour to suit the garment, then test serging and adjusting the stitch tensions to suit the fabric. I have 4 cones of thread each in white, black, beige, grey, pink and pale blue and these threads will give a suitable finish on most fabric colours and prints. Then there is wooly overlocker thread, this is a fluffy thread that you can use for rolled hems as the thread relaxes once stitched and "fills" out the closely stitched edge covering the rolled fabric edge and is another whole area of fun to try out.
Often I'll just use a three thread to neaten the raw edges of a seam I will press open. Or I will assemble a whole knit garment using the four thread stitch, so much faster then stitching seams, then neatening. Jersey knits and sergers are made for each other.
As an aside the D on your machine model would denote "differential feed" too - briefly differential feed is adjusting the amount that the two feed dogs move under the foot and means you can "hold back" the fabric as it is stitched (0.5), or "stretch" it out (1.5 or 2 setting). Really handy for loose weave fabrics that stretch as you serge them, you can compensate using the differential feed setting. And in reverse, you can create a "lettuce" or wavy edge by turning the differential feed up.
I hope that this helps you out with your Brother 1034D and hasn't just confused you. Good luck.
Aug 01, 2011 | Brother 1034D Mechanical Sewing Machine
I just changed my Kenmore serger's needle and it stopped making the overlock stitch. I rethreaded the machine twice and make sure the position of the needles is correct but it didn't help
Hi
If you have the operators manual for this serger, you should be able to follow the threading from the start successfully. Some machines have a better threading diagram on the machine itself.
The needles should have the groove facing the operator's position. They should also be fully inserted in their mounts. Most sergers do not release the thread tensions when the presser foot is raised, therefore, you must zero the tensions to make sure the threads are fully entered into the tensioners when threading anew. After threading, you must readjust your thread tensions to the desired tensions for the set-up you plan to use. Thread tensions should be recorded for each stitch set-up because each serger tends to be a bit different, and therefore, allows you to quickly adjust for the desired stitch needed. The different stitches are adjust and fine tuned by each individual thread tension.
Hope this helps
Ray
Dec 22, 2010 | Kenmore Sewing Machines
Serger tension is off and I can't get it adjusted properly. I have a Necchi Lock machine that is 25 years old and it's been a gem. Do you know how to adjust the tension?
Do you still have the instruction manual for the machine? If you do, you get a great big gold star!
Unless this model has auto tension, there should be a tension knob or lever on each thread feed.
Open the tensions (set at zero). No access to the tension controls, raise the presser foot and this will open the tensions, if the controls are okay.
Re-thread the serger and then set the tension controls back to mid-range or lower the presser foot to re-set the auto tension function.
With the presser foot down, stitch a chain of threads and if they do not "knit" as the should - the serger needs to visit a repair shop.
Service for a serger usually begins around $100.
It could be just the timing needs to be adjusted.
If the tension controls need new springs or the controls needs to be replaced, this will add to the repair cost.
Mar 29, 2010 | Sewing Machines
How to thread euro pro serger. threads aren'y interlocking
If the thread guide in printed on the side of the door or on the machine, you will need to follow the threading sequence.
Turn off the power.
Raise the thread antenna to it's highest position.
Open the tensions (set at zero). If the serger has automatic tensions, raise the presser foot as this also opens the tensions.
Turn the handwheel so the loopers are at their highest position.
Begin threading from the right to the left - lower looper is usually the first to be threaded.
After threading, set the tensions back to the normal setting and stitch a chain of thread and it should be knitted/interlocking.
Mar 23, 2010 | Euro-Pro Sewing Machines
Need instructions for threading Juki MO 3314
Open the font of the serger and the instructions will be printed on the serger or on the door.
Raise the presser foot and set the tensions to zero when threading.
Turn the hand wheel so the upper looper (curved one) is at it's highest point and thread it first, and then the lower looper.
With some sergers you must thread in a certain sequence. This should be indicated in the instructions on the serger.
Set the tensions back to normal ( 4 - 6), lower the presser foot and run a length of stitching to see if the threads are knitted together as they should before you start serging your project.
Feb 19, 2010 | Juki MO-734DE Mechanical Sewing Machine
Sewing Machines Logo
35 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
