Question about Samsung DVD-V5500 DVD Player/VCR
Dvd player doesn't read lens cleaner disc
How can I get the dvd player to read the lens cleaner disc
VOTIT
  • 2071 Answers
SOURCE: My dvd player Samsung DVD-R135 will not read any disc
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Posted on Sep 06, 2008
  • 98 Answers
SOURCE: player won't read a DVD
Sounds like a bad pick up assy (Laser)
Posted on Nov 25, 2008
  • 7 Answers
SOURCE: dvd player won't play disc
There are a few different cleaning kits out there these days for DVD or CD players. I would recommend one that actually has fibers on it so the it brushes the lense of the DVD player. These cleaning kits can be found just about anywhere. Have you tried to clean it with anything?
Posted on Jan 20, 2009
  • 2187 Answers
SOURCE: My DVD player has stopped reading any discs
If the player does not play even known working discs (both CD and DVD), you may want to try first to have the lens cleaned out with a disc cleaner which should be available in most DVD stores. If that does not work you may want to open the device if it is out of warranty and inspect the drive and the head. See if the lens is actually moving or may need replacement.
Posted on Aug 27, 2009
  • 25 Answers
SOURCE: DVD Player stops reading disc Error message :
usually this happens when lens cannot read the the disc. Due to few reason 1 Your disk is scratched 2 Your DVD lens is covered with dust 3 You need to replace DVD lens
Try another few CD/DVD to rectify whether there is any problem with dvd you are trying to play
if this error occurs on all the dvd you played then the most likely proble is with your DVD lens either its coverd with dust use Disk cleaner if not you got to replace a new DVD lense as per model
Posted on Feb 18, 2010
How can I get my dvd to copy videos when it reads, No Disk? when there's a disk in the player?
hi, possible problem with the dvd, the lens doesn't read the disc or the spindle motor not rotating that is why can not read a disc. try to clean first with a cd lens cleaner, just insert a cleaner to the player to remove dirt and might the lens get sticky. now if still doesn't work, you will need to remove the cover of the player to access the internal part. check for broken part or any obstacle that can block the rotation of the spindle motor.if the motor doesn't rotate anymore you can check the resistance if still there using an analog tester. if no resistance at the pin terminal of the motor, the coil was worn out then you will need to replace the motor.
Jun 08, 2012 | Compaq Computers & Internet
Hts3555 will not read disc
Hi
Is it all discs or just one?
Try several discs and see what happens.
If its all discs,try cleaning the lens using DVD lens cleaners.If this doesn't solve the problem,have the lens replaced or if the machine's still on warrant,have its owning company do it for you.
Hope it helps.
Feb 20, 2012 | Televison & Video
I put a dvd in and it says it is loading and then it says no disc found even though it is in the dvd player. I have tried several different dvd's.
Unfortunately , Some DVD players cant read some DVD s and
then it gives either "loading" or " no disc"..reading on the display...
it generally happens when you want to play "A copied DVD/CD " taken from somewhere else..
Just to make sure that such DVD is ok ,you can try to run them on your laptop.If the disc itself has problem, laptop does not read either..
Since you h
ave not stated,if it is an old player pls Clean your DVD player's LASER lens anyway .. A clean DVD player Lens ensures that your DVD disc would be read properly. Unfortunately, your DVD player's Lens accumulate as much dust and lint as the other parts of the DVD player. There are many available DVD lens cleaner kits that you can purchase and use to clean your DVD player.
YOUR DVD disc itself should be clean and finger prints free as well....
Here are three suggested DVD Lens Cleaner that should do the job of cleaning your DVD Player's lens.
Memorex Laser Lens Cleaner for DVD - This cleaner contains six soft brushes that gently remove dust, dirt and other airborne contaminants from your DVD player's lens. (Price: $6.09)
Maxell DVD-LC DVD Lens Cleaner - This DVD Lens cleaner features the "Thunderon Brush System" and include tests for audio performance including Dolby 5.1 surround sound. It also features an interactive on-screen instructions in 8 languages including system set-up. (Price: $10.81)
Allsop 23321 Carbon-Edge DVD and CD-Drive Cleaner - This DVD Lens Cleaner features an 8 brush carbon-system with carbon edge that removes static build-up from your DVD Players. It prevents skipping and also improves the sound and picture output of your DVD Player. ($13.11)
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 26, 2011 | Proscan 32LB30QD 32 in. LCD TV
My Sony DVD player will accept the DVD but fail to load and play the DVD?
Unfortunately , Some DVD players ,especially brand ones cant read some DVD s and
Since you h
ave not stated,if it is an old player pls Clean your DVD player's LASER lens .. A clean DVD player Lens ensures that your DVD disc would be read properly. Unfortunately, your DVD player's Lens accumulate as much dust and lint as the other parts of the DVD player. There are many available DVD lens cleaner kits that you can purchase and use to clean your DVD player.
Thanks
Jul 25, 2011 | Sony RDR-VX500 DVD Recorder/VCR
After inserting dvd in player it reads no disc
Just in case,quick remedy ,
if this remedy does not help and if your set has still under warranty ,consult to service they may replace the LASER Reader EYE...most of the time Laser Eye malfunctions and does this..
if it is not under warranty ,never ,never have someone repaired it..go buy a new one,It will be cheaper.. ...
Hope this helps! Take care and please Remember to rate/vote and give me
Thanks
Jul 21, 2011 | Daewoo DV-6T834 DVD Player/VCR
Most times (90% or more) I input a DVD, the TV screen says Loading, and seems to be processing the DVD loading procedure, but then doesn't play the DVD -- it stays stuck on the Loading sequence. Any...
then it shows either "loading" or " no disc"..
Thanks
Jul 10, 2011 | Samsung DVD-V4600 DVD Player/VCR
DVD player purchased 8/4/10 will not read disc. Model SD7300. Have used the cleaner disc.
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Regards.
Apr 14, 2011 | Toshiba Televison & Video
Not reading DVD discs
has it been reading DVD discs before? Also, does it read other discs apart from DVD's?
It is possible that your DVD drive's lens (laser) is weak. You can try to use a lens cleaner or cutton board to clean the lens.
Take care.
Mar 07, 2010 | Acer Aspire One PC Notebook
LG V181 DVD player/vcr combo doesn´t read de DVD´s
You need to go inside and clean the lens yourself with Servisol video 40. You might need to wipe it with a cotton bud etc. Allow it to dry before checking. Repeat it several times if it doesn't clear up first time.
PS check the lens for damage with a magnifiying glass! First!!
Jul 13, 2009 | Televison & Video
Aiwa xd-dv370 doesn´t play lens cleaner disc
The lense of the player may have gone week, since you have been using it for a long time. Replacing lense will be a solution to this.
Jul 09, 2008 | Aiwa XD-DV370 DVD Player
Samsung DVD-V5500 DVD Player/VCR Logo
41 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
