Question about Sharp 29AGM2 29" TV
BLURED; SOUND OUTPUT OK - Sharp 29AGM2 29" TV
    Top Expert:
  • Sharp Master
  • 74,459 Answers
Check and replace the CRT base connecting socket. If it is faulty, focus to the picture will be effected, resulting out of focus picture.
Gopakumar Gopalan Google
Posted on Apr 15, 2014
When tv is powered on tv only displaying channel number and sound -no raster. using video mode displays are ok. sound is also ok
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Dec 06, 2014 | Sharp Televison & Video
Blown up
It sounds that the LOT {Line Output Transformer] to your TV has damaged. Contact any experienced service technician to get it repaired.
Jan 05, 2013 | Samsung LE32B450 32 in. LCD TV
No sound output from the tv to a sound bar.
Hello
Check its speaker or damage. If it is OK, check the audio output section. A commom fault to thie section is audio output IC damage. OK.
Feb 27, 2012 | Panasonic Televison & Video
No sound i check the speaker it's ok what do you think the problem
Hello
If you checked your speaker and found it ok, but if there is no sound output from your Tv, you just connect a headphone to it whether your Tv has a provision for it. If you gets sound from the headphone, it means that your headphone socket is faulty; not bypassing the sound output to your TVs speaker.
If there is no output from the headphone also, your TVs sound output Ic inside has damaged. Open the Tv, locate it and resolder it out, go for a same type and number, replace it will solve the problem. Ok.
Oct 23, 2010 | Sharp 21B-S10 21" TV
Their is no volume
Hello
There is no sound you means? If so what about the picture? If picture is ok and there is no sound either the speaker of your tv or audio output Ic inside your TVs circuit board is faulty.
To check it, place your ear very close to the speaker side of your tv and turn it on. if a "thumb" sound or a "hum" sound is heard from your TVs speaker, the output Ic is faulty. If there is no sound at all, speaker is faulty. If you have any home theater system; and your TV has audio out RCA sockets at the rear or front side of it, connect it to audio system, and swich on both and find if there is sound output or not. If yes you can assure your TVs sound filtering system is ok, and the fault is somewhere between speaker and audio output Ic. Ok.
Oct 19, 2010 | RCA F20640BC 20" TV
The problem of my camera is, when i take picture the output is very blured but when i use the video the output is okay. Please help to solve this one. thanks
The problem with most digital cameras is that there is a slight delay between when you press the shutter and when the picture is actually taken. The only real solution is to continue hold the camera steady for a second or two after you think you've taken the picture. You can check the camera is ok by placing it on a firm, steady surface and using the self timer to take a picture. This picture should turn out ok. The reason that video looks ok is that as it's a moving picture slight movements by you are constantly disguised.
Nov 25, 2009 | Olympus FE-280 Digital Camera
Too blured to record
You have a blue filter inside the lens assembly was decolored by heat and moisture it require a qualifier Tech from Samsung to replace that filter because it must dismantle the lens, in AUSTRALIA it would cost between $80 to $110 to replace it
I hope that give you some ideas
Nov 17, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Phaser 8550DN
dirty or sitting ink left on paper feed and ink cartridges makin first pages blured
try to clean with little rubbing alcohol
May 07, 2008 | Xerox Phaser 8500/DN Printer
Blured viewfinder
Look at the viewfinder on the camera.
Now look on the LEFT side of the viewfinder; just above the swivel-screen.
You will see a little thumb wheel there.
That is the focus for the viewfinder. Move it up and down to bring the viewfinder into focus. (Don't forget to do this while you are looking through the viewfinder so you can see what you are adjusting.)
Easy fix. :)
Sep 29, 2007 | Canon PowerShot S3 IS Digital Camera
Sharp 29AGM2 29" TV Logo
20 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
