Question about SmartDisk FireLite Computers & Internet
I have a charger for my firelite FWFL60-N but I don't know what voltage to use
When I plug my FireLite into my mac is says there's not enough power. So I have a power adapter that allows you to choose the voltage. what voltage do I use?
  • 1,268 Answers
Power usage is stamed on the case.Don't go over recommended power input.It's also marked on the units power adapter as output.THAT's what you want to find out.Whatever the original adapter says for output on the case,is all that's required to operate.
Posted on Apr 15, 2014
SOURCE: Smartdisk Firelite 80GB-Stopped Working
I had the same problem with my firelite usbflb80-c, and carefully took the case off, 4 screws (one screw under the void if broken warranty sticker) my drive had somehow wiggled it's way out if the connection pins. Figures, with 5 yrs of use, all the traveling and occasional dropping. So I carefully pushed the drive back in place until I couldn't see connection pins any more. I plugged it into my computer before I closed it back up. THANKFULLY an easy fix, but I double checked for breaks or cracks before I closed it up. :o) YAY, I thought I had lost all my files!
Posted on Apr 23, 2009
smartr10U
  • 1305 Answers
SOURCE: Hi, I am using Mac's time machine to back up to my smartdisk firelite model #FWFL80-N. Its 80G, as is my Mac's hard drive. usually Time Machine erases older back ups to make room for new ones, but I
First of all, did you Empty the trash?
If so, then Try a full erase with Disk Utility. It's in your Applications in the Utilities folder... ..
Posted on May 23, 2009
bob_computer
  • 3153 Answers
SOURCE: FireLite FWFL40-N (Firewire) External HD wont turn on PC or MAC
Make sure the poer adaptor you use is rated for the same or better in terms of current. The instruction for the drive tell you what this is but for example it may be 5V 500mA in which case you need either the original power supply that is known to be working or another on that has those ratings (it does not matter if the mA or A is a little higher but never lower.
If its not the PSU then by all means dismantle it take the drive out and fit it into a pc to check the drive itself. If the drive comes up OK then you know for sure it is the enclosure and these are now cheap enough.
Posted on Aug 11, 2009
  • 10406 Answers
SOURCE: Erase Firelite backups so drive is clean and I can start over
Empty the Recycle Bin -- the files that you "erased" were _only_ moved from their location into the Recycle Bin -- they still occupy just as much disk-space.
Posted on Jan 29, 2010
SOURCE: dropped firelite: still spins but is not recognized
Ok same situation happened to me i dropped my Firelite 80Gig, drive would spin no light and the computer would not recognize the drive. All I did was open the case an saw the the internal hardrive had come loose from its pin connection. So all i did was pushed it back in and BAM now it works, hope this helps other people. Thanks C.J.
Posted on Jun 13, 2010
Power supply
Input voltage for the FWFL40 is 33V DC. I hope this helps
Nov 04, 2013 | SmartDisk FireLite 40 GB Hard Drive
I have firelite external and it's not working. There's light but no spinning sound. what can I do?
This a firewire drive and needs to plugged into a firewire port to spin up. If you do not have a firewire port on your computer (most PC's don't) it will not work. I don't believe a firewire to USB connector will pass enough power to the drive to spin it up.
Mar 12, 2012 | SmartDisk FireLite 60 GB Hard Drive
Need to know what AC adapter to use with my Firelite. Have a number of AC adapters but not sure which one goes with my unit
First ..this is an usb disk ..and usually it does not need an external power supply but in special cases when it is plugged in something it can not sustain it ..i understood it does have a power supply plug ..but ..I repeat ..it should work on the usb alone ..and get the power from it ..
If you experience some issues and need to know if ti will work when you power it external ..the values are written on the back of teh drive ..or near the plug ..You will only need to have the right jack ..and the voltage to match ..beware of any higher voltage ..it may damage it right the way ..
Dec 28, 2011 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
What external power does SmartDisk FireLite FWFL120-N take?
Many USB power supplies will have the right plug. I picked one up by buying a cheap USB hub, What you want to look for (most likely on the bottom of the power supply) is VOLTAGE Output: 5.0 VDC, POWER Output: 1.0 amp or (1000ma) and the center hole is the positive side. I have even seen some BluTooth earpiece charges that supply what you need.
Hope that this will help.
AAirwolf
Jul 05, 2010 | SmartDisk FireLite FWFL120 120 GB FireWire...
Smartdisk Firelite 120 GB wont delete
Try to reformat the external hd thru the disk utility.
Sep 03, 2009 | SmartDisk FireLite USBFLB120 120 GB USB...
PowerBook G4 does not seem to recognize. (Worked well on previous Apple lap top)
If your Firelite SmartDisk was formatted for a PC, and you are using the Mac side of the G4 it won't. They use a different format scheme. Need to load Parallel, bootcamp, or another virtual PC program, and then Windows. Using that it will recognize it.
If you know another Mac user that is using both sides (Mac and Virtual PC) is a quick way to retrieve data to move it. Be careful reformatting the FireLite. There are some more complex ways. Hope that this helps.
AAirwolf
PS: I use a 160GB FireLite on my G4, MacBook Pro as well as my Tower and notebook PCs.
May 24, 2009 | FireLite (USBFLB80) Hard Drive
Name and date coming up wrong on Smartdisk
Spyware is very unusual with Mac. Especially with the latest version; 10.12.4
Apr 28, 2017 | SmartDisk FireLite XPress USBFLXP60 60 GB...
Intermitant power
You are describing the symptoms of a classic cable short. My guess is the power plug cable on the A/C power adaptor or the socket it plugs into is damaged. Try holding the plug still and wiggling the power cable back and forth, chances are that will recreate the problem. -If you have basic tools and solder experience you can purchase a replacement plug, cut the old on off and attach the new one. -If you don?t have the time or inclination to fix it you can just purchase a replacement power supply. If it doesn?t appear to be the power (or if you?re not using the A/C power adaptor) it may be the USB cable or its socket. -Try a new cable. -Try a different USB socket; they are surprisingly easy to damage. Let us know if you have any other questions and please don?t forget to rate this post.
Mar 30, 2007 | FireLite (USBFLB80) Hard Drive
Computers & Internet Logo
116 people viewed this question
Top SmartDisk Computers & Internet Experts
 Ian Kayhan
Ian Kayhan
terminalcon
Are you a SmartDisk Computer and Internet Expert? Answer questions, earn points and help others
